Old 12-06-2003, 10:38 AM   #226
InitialD's Avatar
Originally posted by vones
I'm still waiting for the 39 T crown teeth....chk with ur ste up sheet..shuld tell u the gear ratio for spur n pinion...
I tried to find the internal ratio of the car... Does anybody know what it is?
Old 12-06-2003, 01:23 PM   #227
vones's Avatar
Hmmm..tot I saw it somewhere.....???saw it was 3.07 or something...but when I work back the math it gives me something like 2.936
(51/21)x2.936=7.13
(46/26)x2.9=5.13
vones is offline   Reply With Quote
Old 12-06-2003, 06:36 PM   #228
coldeye's Avatar
Thought I read it was around 2.9 as well. I thought the stock gearing was undergeared for tracks like revelation. I too am waiting for the 27 pinion. I was told that the mugen gear would work. Has anybody investigated this?
coldeye is offline   Reply With Quote
Old 12-06-2003, 07:53 PM   #229
Dose anyone know when the foam tire with front one way and grafite upper deck car is comming out?
mugenracer is offline   Reply With Quote
Old 12-06-2003, 08:48 PM   #230
Joehwee's Avatar
The internal gear ratio for FW05R;
40/13 = 3.07
39/13 = 3.00
There is discussion on internal ratio affect the car top speed, click the link below;
http://www.rctech.net/forum/showthre...threadid=28693
Joehwee is offline   Reply With Quote
Old 12-06-2003, 08:51 PM   #231
B
I thought it is out already??
B is offline   Reply With Quote
Old 12-06-2003, 09:54 PM   #232
vones's Avatar
Joehwee, is the 39 T crown gear out yet...?oh yeah....how the Tamiya ceramic grease doing is it good? where did you get it..? from nigel?
Old 12-06-2003, 11:14 PM   #233
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Okay, I was just concerned that changing to bigger pinions would cause tight gear mesh if I didn't change the spurs as well.
On another note, I bought the one-way but failed to recall that new outdrives are needed. Since mugen parts are redily available in my area, is it possible to use the outdrives from the MTX-3? Oh, and I have to add that the phillips head screws that are used to secure the engine mounts to the chassis absolutely BLOW. I have to figure out how to remove 2 stripped screws and find a suitable replacement. Any suggestions?
Racing4Evo is offline   Reply With Quote
Old 12-07-2003, 08:05 AM   #234
Joehwee's Avatar
Vones: The 39T Crown steel gear should be here middle of the month, just nice for the Danga Bay race. As for the ceramic grease you can get them from Nigel or Tai Seng.
Racing4evo: Changing the pinon will not affect the clearance much, and the engine can be move a little side way.
Old 12-07-2003, 08:13 AM   #235
vones's Avatar
ok...THX....
Old 12-07-2003, 09:51 AM   #236
InitialD's Avatar
Thanks for the internal drive ratio info Joehwee.
Anyway, I thought that the FW05 pinions and spurs are the same as the V1RR EVO? If they are indeed the same, then changing to any spur or pinion does not make any problems with regards to gear meshing because the respective diameters for 1st speed spurs and 1st speed pinions are equal. Likewise for the 2nd speed spurs and pinions. Correct me if I'm wrong...
Old 12-07-2003, 07:08 PM   #237
vones's Avatar
pinions are the same, but the PCD of the spurs gears are different.....FW-05R is smaller......
Old 12-07-2003, 07:45 PM   #238
InitialD's Avatar
Thanks for the info and correction vones. Say are all the 2nd gear spurs set on the FW05 come in the same diameter? The same for the 1st gear spurs set?
If they are, then you can always jump 3 teeth on the pinion while perhaps 5 teeth on the spurs.
Old 12-07-2003, 09:58 PM   #239
Racing4Evo's Avatar
Good question? I'm thinking they're not exactly the same diameter but pretty close.
Old 12-07-2003, 11:58 PM   #240
vones's Avatar
Hmmm....don't quite understand what u mean...like tis....?
pinion gears: 22 (FG) with 25(SG)
spur :50 (FG) with 45 (SG)
then won't u car hve a lot of torque but no top speed?
I think if the above is wat u mean then running it, is ok...cos with 0.8 module the teeth is finer comparing it with the 1.0 gear module ....tats wat I think. Basically FW-05R is already very torquey with the stock gearing...tats y I went for the pinion 22T n 27T with spur 45T n 50T giving me reasonable pick up n top speed...still waiting for the crown gears 39T to try on FW-05 n see wats the result....glad to c exchange of ideas here as tis car is still very new to us hobby players n not much of ideas being brought forward....hve you or anyone tried the TCD gears on tis FW...?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
