Old 07-23-2004, 05:39 AM   #2266
Send a message via ICQ to vaspey
becoz it's quite hard to overcome, if i push down to the starter box, the wheel of the starter box can even stop
terrible, the binding force is huge, i need to use hand to overcome it several times, but still hard
any solution other from that, please help, really get headache!!!!
thx
vaspey is offline   Reply With Quote
Old 07-23-2004, 06:17 AM   #2267
ziggy12345's Avatar
thx
When a car engine is new the piston is a tight fit in the liner. The liner is designed so as the piston goes up it gets tighter and tighter. This is called the PINCH.
As the engine gets used the piston and liner wear to a point where its a perfect fit. This usually takes 3-20 tanks, depending on your engine and this period is called RUNNING IN.
During the run in you need to run the engine rich (more fuel to air mixture).
For the first start it is difficult to get the engine to spin on the starter box. The engine will stick at Top Dead Centre (TDC). If it does this just use a screw driver on the flywheel and loosen it off again.
For first starting heat the engine to around 160 deg f and then try.
Once started go through the run in sequence of tick over for 2 tanks and then slow running around for 3 tanks before opening the throttle and leaning the engine out.
If your at the track and the starter box wont turn your engine then remove the plug and spin the engine over. As its spining replace the plug and start without taking the car off of the starter box. This takes 2 people.
Hope this helps
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-23-2004, 06:58 AM   #2268
NiMo's Avatar
When you are running in, try not to let the tank run dry, and as soon as the motor stops rotate the flywheel so the piston is at BDC otherwise is will jam as the motor cools.
My new JP took 7 tanks before the jamming thing was overcome, and that is with 19T motors in my starter box.
NiMo is offline   Reply With Quote
Old 07-23-2004, 07:11 AM   #2269
sure, i know it now, but the thing is the engine still cant rotate at that pt so that it cant start and run in
damn, rally no idea y it binds so hard
the starter box cant even move it
i tried to loose and it binds
many times, really frustrated, y me????
Old 07-23-2004, 07:27 AM   #2270
Any good motor will stick at Top Dead Center. A few things to try are: heat the engine with a hair blower, loosen the glow plug a little to get the engine to start and then tighten while running. It also helps to take out the plug and spin the engine over until fuel gets to the engine so that is done before you try and start. If it sticks you have to move it with a screw driver on the flywheel, kinda messes it up but there is nothing else to do.
Ted Flack is offline   Reply With Quote
Old 07-23-2004, 08:18 AM   #2271
jeffreylin's Avatar
R/C Tech Charter Subscriber
take your engine out of the car, loosen it, than put it back in the car and heat up the head before you try again.
jeffreylin is offline   Reply With Quote
Old 07-23-2004, 09:01 AM   #2272
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hey a really like your avatar!!!!
Old 07-23-2004, 09:42 AM   #2273
i'll try but actually this makes my starter wheel to wear pretty quick
so u can think of the binding force is huge that the starter wheel get worn out quick
Old 07-23-2004, 10:11 AM   #2274
ziggy12345's Avatar
Hey!! I got my avatar to work!!
Sponsored by:
Norfolk and Chance
Old 07-23-2004, 09:11 PM   #2275
thanks to all pros, i got it started 10 seconds, but stalls immediately, y is that like???????
comment on this please!!!
Old 07-23-2004, 09:17 PM   #2276
BrainTeased's Avatar
you need to check the needle settings
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-23-2004, 09:20 PM   #2277
but actually it's brand new before starting, do i need to heat up the engine first before setting the needles up????
Old 07-23-2004, 09:21 PM   #2278
hey guys im getting my FW-05R soon its been sent already i wanted to get my front diff parts ready so i need your help
Does the foam tyre version with the one way come with the front diff housing?
Also what parts do i need to have my FW-05R ready to run with a front diff? thanks guys!
P.S i went to my local hobby shop today and they showed me a packet which has a crown wheel (silver) and i think 2 small gears is this what i need or do i need the steel big brown gear?
Old 07-23-2004, 09:26 PM   #2279
you have to setup the needle settings first as it is no use heating up an engine then spending 2 to 5 mins setting up the needles you set the needles to factory settings so you can start the engine and have it idle. i have no idea what the new jp fx factory settings are. You should of brought the JP FX engine that has been broken in already!
Old 07-23-2004, 09:34 PM   #2280
cool, then i will try it then, thx brainteased!!!!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
