Like Tree2Likes
Kyosho FW-05R
Old 07-20-2004, 05:14 AM
  #2221
rjl
rjl's Avatar
Ziggi, did you do the rear conversion?
rjl is offline
Old 07-20-2004, 05:59 AM
  #2222
ziggy12345's Avatar
Is there a Kawahare rear conversion? If so what is it?
I put on the MTX-3 hubs if thats what you mean
Cheers
ziggy12345 is offline
Old 07-20-2004, 06:03 AM
  #2223
ziggy12345's Avatar
I did a search and only found the Front and Centre Kawhara conversion
Cheers
Old 07-20-2004, 06:48 AM
  #2224
NiMo's Avatar
There is a rear conversion but in your case (Ziggy) I think the conversion you have done is a better one for foam tyre use.
NiMo is offline
Old 07-20-2004, 07:06 AM
  #2225
ziggy12345's Avatar
Nimo
What does it convert?
Cheers
Old 07-20-2004, 07:11 AM
  #2226
Got 'em, but still in the bag....
Hey RJL...Thanks for the Kawa Part Item Description a few threads back. I got another one for you.... the pivot balls that came with the Kawa Rear - is that Steel or Titanium? I read somewhere saying those where Titanium - but it doesn't look though. And also on the Kawa Front...where do you put the caster clips...one on each side or 2 up front?
Update on that grub screw (Kawa Center)...I'm using a Permatex Red "high strength" not the permanent ones and it stays there now..
adlawoo is offline
Old 07-20-2004, 07:24 AM
  #2227
NiMo's Avatar
Originally posted by ziggy12345
Nimo
Cheers
Less than your conversion. And you will need to cut the ends from your swing arms which would make them even shorter.
NiMo is offline
Old 07-20-2004, 07:55 AM
  #2228
esham's Avatar
Thanks Ziggy for the setup.
esham is offline
Old 07-20-2004, 08:45 AM
  #2229
Here's the install......
adlawoo is offline
Old 07-20-2004, 10:31 AM
  #2230
ziggy12345's Avatar
I cant see why you would want to shorten the rear swing arms on the FW-05. One of the benefits of the car is the long swing arms.
It does angle the top camber link up more if you do this but this can be done with taller hubs ala MTX-3's
Oh well.. Ours is not to reason why. Ours is to but spend and try..Or something like that..
Cheers
Old 07-20-2004, 10:52 AM
  #2231
Tech Legend
Marcos.J's Avatar
Trader Rating: 192 (100%+)
is that what the rear conversion does?
Marcos.J is offline
Old 07-20-2004, 12:33 PM
  #2232
Slotmachine's Avatar
Default Reciever pack?
My car is on the way, what reciever pack does it use? 5 AAA, 5AA, OR The old style shorties? Maybe you could post a picture.
Thanks............................
Slotmachine is offline
Old 07-20-2004, 01:15 PM
  #2233
ziggy12345's Avatar
anybody know where i can get a Nova Rossi RR12L5 and has them in stock?
Cheers
Old 07-20-2004, 02:20 PM
  #2234
Sow&Steady's Avatar
Cheers
Why? What happened to the JP FX-T05?
Sow&Steady is offline
Old 07-20-2004, 03:28 PM
  #2235
ziggy12345's Avatar
My friend was looking for one. I had one until the PL went then i got the JP. The RR12L5 is pretty awsome for small tracks
I still have the V-1-RR with the NSR in it. I got a new PL off of a guy on here. Its a different design with different material. no need to worry about temp as i have had it at 325 and it was still ok.
Cheers
