Old 07-19-2004, 07:12 AM   #2206
Send a message via ICQ to vaspey
Originally posted by ziggy12345
The centre conversion is a set of front and rear steel machined bevel gears. The kit is 40T bevel with 13T crown gear. the conversion is front 45/17 rear 46/17.
It changes the drive ratio so that the highest kit gears 45/27 now is equal to the lowest 46/25 and gives you front overdrive for stability.
New drive shafts and end caps are included. you will need to drill a small hole in your dif case, no big deal
Cheers
y do we have to drill a small hole in the diff case, in what condition do i need to? when uses centre conversion kawahara???????
or kyosho itself parts???????
plz comment on this
vaspey is offline   Reply With Quote
Old 07-19-2004, 07:14 AM   #2207
what model no. is this?? from kawahara??????
Old 07-19-2004, 07:20 AM   #2208
BrainTeased's Avatar
Cheers
thanks for input agan ziggy
So this conversion is done in the diff gears? i hope i got this conversion. i got a whole new car to learn on again i feel my head is gonna ache soon!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-19-2004, 07:58 AM   #2209
ziggy12345's Avatar
plz comment on this
Only when you get the centre conversion. It comes with a small thrust bearing with a plastic ring. The ring has a groove in it which locates into a screw that is screwed into the diff case where you have drilled the hole. This is to stop it rotating inside the diff case and wearing the housing
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-19-2004, 08:05 AM   #2210
ziggy12345's Avatar
After i sorted the gearing problem I changed out the rear hubs to MTX-3 and the camber links to V-1-RR. this had a dramatic effect on the rear grip. I can floor it from 1/2 way round a corner, even with my JP engine with no loss of grip or spin.
I am on the power seconds before the guy infront and with the fast pick up and high top end blast past like they stand still!
Truly awsome to see!
Sponsored by:
Norfolk and Chance
Old 07-19-2004, 06:00 PM   #2211
Update: After 2 days at the track this weekend I found something that has me kickin my own butt. Some of you may remember I have been fighting the understeer problem...well after doing a few breaking/tuning runs with the body off, I found that the problem is actually a body induced understeer. With the body off the car turns in fast and lively on every corner and is a totally different car. I currently am using the new mazda 6 body and am wondering what bodies others are using and to what results.
thanks
rcosmax is offline   Reply With Quote
Old 07-19-2004, 06:08 PM   #2212
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Understeer
thanks
The Protoform Alfa gives much more steering than the Mazda, try that. If you dont like it try the RD Logics Stratus.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-19-2004, 08:50 PM   #2213
Default Set up
Here is Josh C. set up for Vegas April 2004
Old 07-19-2004, 09:01 PM   #2214
Default set ups
Josh C`s set up
Old 07-19-2004, 09:05 PM   #2215
Default Sorry
http://www.cefx.net/products//bodies/DeltaLola/
Here is a direct link to his site, click on the set up`s bar and click on what you want to see.
Old 07-19-2004, 11:02 PM   #2216
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: set ups
Originally posted by Slotmachine
Josh C`s set up
here is josh set up that i posted a few pages back
Old 07-20-2004, 04:19 AM   #2217
thats how i want my car to drive!!! to be able to accelerate mid-way thorugh a corner and not loose traction! but i guess it also depends on the track's traction. My track is small and twisty with low traction and the surface aint that flat either. also ziggy may i ask why you use VoneRR camber links and not the mtx-3 ones since your using the rear uprights. may i also ask what diff oil is in the back diff and i suppose your also runing the car with a one way diff in the front?
thanks in advance
Old 07-20-2004, 04:35 AM   #2218
esham's Avatar
Ziggy, Can you share with us your final car setup as it now? Thanks.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 07-20-2004, 05:37 AM   #2219
ziggy12345's Avatar
Front
One way
Black springs
35wt oil
most angled shocks
2 deg camber
0 toe
Flat roll bar
5.5mm ride height
3mm droop
61mm tyres
40 Shore GQ
196mm track
Back
10,000wt dif oil
Gold Springs
35wt oil
upright shocks
No roll bar!
MTX-3 Hubs
V-1-RR camber links
Most spacers in
Lower position
Lowest swing are pivots
3 deg camber
3 deg toe in
9mm droop (most you can have)
199mm track
63mm tyres
40 shore GQ
General
JP FX T05 engine
7mm Kyosho exhaust
25% Tornado fuel
C6 TGF plug
Lola shell
Gurney strip 10 mm up
Adjustable drag brake
Centre conversion
21/26 gearing
1.7mm clutch ith 0.5mm float
Kawahara front conversion
3racing aluminium centre bulk head
3racing chasis
Make sure there is absolutely no hint of stiffness in the swing arms. Put an accurate digital scal under the susension and lower the swing arms gently onto the scale and read what it says. Then push down on the swing arms and lift off slowly and take a reading. (no roll bar or shocks attached!)
The difference in the 2 readings should be no more than 5 grams
Sponsored by:
Norfolk and Chance
Old 07-20-2004, 05:42 AM   #2220
ziggy12345's Avatar
also ziggy may i ask why you use VoneRR camber links and not the mtx-3 ones since your using the rear uprights. ....
I havent seen the MTX-3 camber links but the V-1-RR links have no lateral movement only up and down and it stops the hubs flexing back and forth under power and on a bumpy track.
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
