Old 07-18-2004, 06:11 PM   #2191
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: pinion gear
Originally posted by vaspey
can u provide some online shop for me to buy those?
coz towerhobbies doesnt have 23/28 pinions
Sorry, I just saw it in a hobby shop in HK and picked it up. It's part number VZ116-28. I don't know where you can get it online but you can try and ask your LHS to order for you.
jeffreylin is offline   Reply With Quote
Old 07-18-2004, 08:19 PM   #2192
Joehwee's Avatar
Anybody interested in a set of one race old kawahara gears with additional centre shaft (NIB)?
Joehwee is offline   Reply With Quote
Old 07-18-2004, 08:25 PM   #2193
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
what size gears?
Old 07-18-2004, 09:51 PM   #2194
Send a message via ICQ to vaspey
Default Re: Re: Re: Re: pinion gear
oh, that is quite troublesome, maybe i need to wait a bit more
coz i'm a overseas student in Australia. i'm a Macau citizen
maybe just wandering through hobby shop in hk when i go back to Macau
vaspey is offline   Reply With Quote
Old 07-18-2004, 10:13 PM   #2195
Registered User
maverick's Avatar
tuned pipe?
to fw05 gurus,
which is the better choice, the 5.2mm tuned pipe that comes with the VSW008 or the polished 6.0mm ones VSW033?
would appreciate if state the pros and cons of each. at the moment these are the options available to me.
tia
maverick is offline   Reply With Quote
Old 07-19-2004, 12:29 AM   #2196
jeffreylin's Avatar
Default Re: tuned pipe?
Originally posted by maverick
to fw05 gurus,
tia
no guru here, but have experience with both. the 5.2 has tons of low end with decent top end while the 6.0 has more top end but less low end. there is also a 7.0 that is suppose to give you even more top end. i like the 6.0 as it offers a good compromise but some places have rules on the size of pipe you can use.
Old 07-19-2004, 12:39 AM   #2197
cyba888's Avatar
Jeffery back to LA already? You lucky SOB! Do me a favor when you get back next time. Get me one of those Dynamite fuel guns next time you get back. Thanks man, ill give you rupiah when you get back...haha
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-19-2004, 01:46 AM   #2198
ziggy12345's Avatar
Had the car running yesterday with the JP FX engine. I was at a very fast track and managed to get decent lap times.
They improved even more when I figured out i never had first gear!. Just shows the torque this engine has and how free the car is
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-19-2004, 02:05 AM   #2199
Joehwee's Avatar
The gear I have for sale is the internal crown for front and rear from Kawahara.
Old 07-19-2004, 02:35 AM   #2200
BrainTeased's Avatar
it also has the carbon upper deck and the shimo chassis as well.
Anything else may i ask? what about CVD's any sites that show the comparison between the standard and hopped up edition?
Also is this true
Standard= rubber tyre kit
Hopped up = Foam tyre kit?
Thanks guys!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-19-2004, 02:38 AM   #2201
jeffreylin's Avatar
Also is this true
Thanks guys!
no CVDs
Standard = 31581A (rubber) or 31581B (foam)
Hopped up = 31582 (foam with one way, carbon upper deck, and shimo chassis).
Old 07-19-2004, 03:01 AM   #2202
no CVDs
Thanks once again jeff!!!
i thought there would be more included o well.
Old 07-19-2004, 05:53 AM   #2203
ziggy12345's Avatar
You will then need as a minimum
Bearings for the servo saver
Centre conversion (I think its a must have!)
Delrin pivot ball cups
Get the hardened pinion gears when the kit ones wear out (very quick!)
Cheers
Sponsored by:
Norfolk and Chance
Old 07-19-2004, 06:20 AM   #2204
Cheers
Thanks Ziggy!
Do i also need the steel crown gears in the diffs? cant believe the servo saver doesnt have bearings even in the hopped up kit!!! are the bearing sizes on the manual? or could someone please tell me what bearing sizes i need for the servo saver so i can order them in thanks guys
Whats included in a centre conversion as i think the car im getting comes with karahawa centre conversion!
Old 07-19-2004, 06:27 AM   #2205
ziggy12345's Avatar
The centre conversion is a set of front and rear steel machined bevel gears. The kit is 40T bevel with 13T crown gear. the conversion is front 45/17 rear 46/17.
It changes the drive ratio so that the highest kit gears 45/27 now is equal to the lowest 46/25 and gives you front overdrive for stability.
New drive shafts and end caps are included. you will need to drill a small hole in your dif case, no big deal
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
