Kyosho FW-05R
#2147
no, becoz have a bit space
and do i need to use plier to force the spring nut screw in on the flywheel nut?
coz just now i tried and a bit came out, but not yet 1.5mm
and i used spring FANTOM and spring holder FANTOM
#2148
Super Moderator
#2149
i can get to 1.6mm, need to use plier to force it in
but the clearance is 0.4mm
what the clearance is the best ???
as the book says 0.5mm
step 29 in manual
thx
step 29 in manual
thx
#2150
Re: Re: Re: Choosing of Starter box
would u plz tell me how u made to urs????
coz i want to get more information y i cant do that!!!!
i dont believe i cant make it!
please
please
#2151
Super Moderator
step 29 in manual
thx
step 29 in manual
thx
#2152
got all fixed, thx to all pros
#2153
Anybody know the part # for those delrin or whatever they are pivot ball retainers that have the proper spherical end that goes towards the pivot ball. I just don't like the way the stock pivot ball retainers make the steering seem notchy. Don't know why they would ever make them flat???
#2154
I used the dremel with a round stone bit on mine when I put the car together. Works pretty nice.
#2155
Super Moderator
http://www.mytsn.com/products/product.asp?prid=408
those are the nylon ball-cups and these are the Alu.adjusting nuts
http://www.mytsn.com/products/product.asp?prid=410
#2156
#2157
Originally posted by NiMo
Square SFW-10
Square SFW-10
#2158
Unfortunately I didn't have a failsafe. It was the one time I dusted off my KO Mars radio to use. I normally use a 3PK PCM. I so wish I was using that radio! The car coast so much to fix I just went out and bought a Delta XP-4 since I got a really good deal.
#2160
You would think that with the 46t Kawahara conversion you would have to run the smallest pinion, right?
Well I've just installed a JP FX12 T03 and a 21t pinion, and after 3 tanks of running in I feel it will require the 22t pinion to prevent wheelspin.
Just how much torque does a JP have?
(the STS Dragon could not pull a 21t pinion)
