Like Tree2Likes
Kyosho FW-05R
Old 07-07-2004, 07:28 AM
  #2086
ziggy12345's Avatar
Originally posted by rjl
KF-1041 is the carbon shock tower for the front conversion.
KF-1044 is the sus. pin bracket.
Do you have a link to buy online?
Cheers
ziggy12345 is offline
Old 07-07-2004, 07:38 AM
  #2087
Super Moderator
Marcos.J's Avatar
Trader Rating: 199 (100%+)
Originally posted by SupermaxxRich
The FW05R that I'm getting is the rubber tire version I believe becaue it comes with a front diff. Does that sound right to you? It also comes with the upgraded Shimo Chassis and Carbon Fibre Upper deck plate. What I was wondering is there any difference between the rubber tire cars and the foam tire cars besides the fact that the foam tire cars come with a one-way? I was wondering if there is anything I have to do to run foams on my car? I don't think so but somebody told me I would have to change driveshafts? That didn't sound right to me so I thought I would ask the experts.
you are going to need a few parts here is the link for them from tower hobbies!!http://www2.towerhobbies.com/cgi-bin...=++&search3=Go , for $8.99!!and the swing shafts
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go ,for $8.99 also!!
Marcos.J is offline
Old 07-07-2004, 07:43 AM
  #2088
Super Moderator
Marcos.J's Avatar
and also when you build the rear hubs dont go by the instructions setting of 3.8mm on page 17 you need to set them at 1.8mm!!! to get the correct track width.
Marcos.J is offline
Old 07-07-2004, 09:38 AM
  #2089
Super Moderator
Marcos.J's Avatar
Does anyone have a part number for these 2mm spacers?
they are in the above post!!!^^^^
Marcos.J is offline
Old 07-07-2004, 02:40 PM
  #2090
ziggy12345's Avatar
Where can I get the 19T and 24T pinions for the FW-05 after you have fitted the Cenre conversion? I think they are a KAWAHARA part.
Cheers
Old 07-07-2004, 03:24 PM
  #2091
NiMo's Avatar
Not sure if this can help:
Power Clutch Kit, 4 Shoe, 21T/27T
LD3, MTX3, NTC3
PART# 38620
http://www.ofna.com/LD3options-08.html
LD3, MTX3, NTC3, all same part number ?
NiMo is offline
Old 07-07-2004, 03:54 PM
  #2092
NiMo's Avatar
Anyone know about GPM parts ?
It's just that I have found the following:
TFW5237 TITANIUM UNIVERSAL MAIN SHAFT -1PR [email protected]
TFW5620T1 TITANIUM CLUTCH PINION FIRST GEAR(20T) -1PC [email protected]
TFW5621T1 TITANIUM CLUTCH PINION FIRST GEAR(21T) -1PC [email protected]
TFW5622T1 TITANIUM CLUTCH PINION FIRST GEAR(22T) -1PC [email protected]
TFW5625T2 TITANIUM CLUTCH PINION SECOND GEAR(25T) - 1PC [email protected]
TFW5626T2 TITANIUM CLUTCH PINION SECOND GEAR(26T) - 1PC [email protected]
TFW5627T2 TITANIUM CLUTCH PINION SECOND GEAR(27T) - 1PC [email protected]
DFW5008 DELRIN ADJUSTING SCREW NUTS FOR PILLOW BALL - 8PCS
DFW5021 DELRIN FRONT STEERING KNUCKLE ARM SET -1PR [email protected]
DFW5022 DELRIN REAR HUB - 1PR [email protected]
DFW5054 DELRIN FRONT UPPER ARM SET -1PR [email protected]
DFW5055 DELRIN FRONT LOWER ARM SET - 1PR [email protected]
DFW5056 DELRIN REAR LOWER ARM SET -1PR [email protected]
DFW5649T1 DELRIN 2SPEED FIRST GEAR(49T) - 1PC [email protected]
DFW5650T1 DELRIN 2SPEED FIRST GEAR(50T) - 1PC [email protected]
DFW5651T1 DELRIN 2SPEED FIRST GEAR(51T) - 1PC [email protected]
DFW5644T2 DELRIN 2SPEED SECOND GEAR(44T) -1PC [email protected]
DFW5645T2 DELRIN 2SPEED SECOND GEAR(45T) -1PC [email protected]
DFW5646T2 DELRIN 2SPEED SECOND GEAR(46T) -1PC
There is loads more in the list
NiMo is offline
Old 07-07-2004, 06:19 PM
  #2093
jeffreylin's Avatar
This is a HK company who is know for their hop-ups for Mini-Z. I knew they made stuff for FW05R too but last I checked it was silly stuff like aluminum arms so I have not paid much attention. I will check them out when I go to HK next week.
jeffreylin is offline
Old 07-07-2004, 09:07 PM
  #2094
Super Moderator
Marcos.J's Avatar
Default Integy parts for FW-05R
check out this link for integy catalog for the FW-05R
http://integy.automated-shops.com/cg...40104003022.e1
Marcos.J is offline
Old 07-08-2004, 09:59 AM
  #2095
Super Moderator
Marcos.J's Avatar
LD3, MTX3, NTC3
PART# 38620
maybe the pinion gears can work
Marcos.J is offline
Old 07-08-2004, 01:57 PM
  #2096
NiMo's Avatar
I've had a few pm's asking for more details so here they are:
http://www.gpmracing.com.hk/car/page/fw05r.html
http://www.gpmracing.com.hk/catalogue/fw05.jpg
NiMo is offline
Old 07-09-2004, 07:46 PM
  #2097
FW-05RR's Avatar
alot of "bling"
FW-05RR is offline
Old 07-10-2004, 02:08 AM
  #2098
Sacker's Avatar
Default FW-05 turbo outlaw pipe
more info
Sacker is offline
Old 07-10-2004, 10:44 AM
  #2099
dameetz's Avatar
Default Re: FW-05 turbo outlaw pipe
Originally posted by Sacker
more info
That pipe looks good. How much its cost? The link doesn't give and price info.
dameetz is offline
Old 07-10-2004, 10:48 AM
  #2100
dameetz's Avatar
Just picked up the latest Touring Car Mag today. FW won the shootout contest between all the the other top brand. I just feel proud to own it.
dameetz is offline
