Old 07-05-2004, 10:39 AM   #2071
NiMo's Avatar
Originally posted by adlawoo
Same problem - just on the end by the diif side, the crack line I got - goes along nearby the grub screw. And that sound sound from the diff...seems louder than the stock steel gears.
But the car is ballistic w/ this set-up.
I found that with the diff noise too, but it sounds good under heavy braking.
I've now gone back to the Kyosho chassis as I could not find a cure for the snapping rear end of the Kawahara chassis, I think it's only meant for foam tire use, but I forgot how much understeer the 05 chassis had.
LSD front diff is a no go, the lighter oil gave great turn in but braking and on power spin outs sometimes bit, set up is great when you have the track but is not good for fighting through traffic.
NiMo is offline   Reply With Quote
Old 07-05-2004, 10:46 AM   #2072
jeffreylin's Avatar
R/C Tech Charter Subscriber
How about just the front conversion? Wouldn't that give you the steering without the drivetrain and rear end problems?
jeffreylin is offline   Reply With Quote
Old 07-05-2004, 11:00 AM   #2073
NiMo's Avatar
I've kept the drivetrain but ditched the chassis, maybe when (or if) the UK Foam class goes to Touring shells I might try the chassis again.
I've also found a way to use a standard muffler on the 05 chassis with no clearance problems (photo to follow soon).
Old 07-05-2004, 02:32 PM   #2074
ziggy12345's Avatar
I dont have understeer problems! I use only foam tyres though!
I had the front conversion. It gave me a lot of steering but I damaged the shock mounts and need a new one
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-05-2004, 08:47 PM   #2075
Ares17's Avatar
Default Nova RS S5
hi guys, i'm planning to buy a 2nd hand engine due to budget concern. The engine I'm planning to get is the Nova RS S5. How does it performs compare to NS S5? And if anyone know the factory carb setting for this engine is really appreciated. Thank you.
Ares17 is offline   Reply With Quote
Old 07-05-2004, 10:37 PM   #2076
Default Kawahara Center Conversion?
Just want to double check with the part no. of that center drive cup......
that's ZF-123 - right?
and how about ZF-124 & ZF125 - what are these part nos?
Thanks!
adlawoo is offline   Reply With Quote
Old 07-06-2004, 01:50 AM   #2077
ziggy12345's Avatar
Default Re: Nova RS S5
Check the engine section. I have a Rossi Pixy Black for sale if you want?
Cheers
Sponsored by:
Norfolk and Chance
Old 07-06-2004, 02:49 AM   #2078
Ares17's Avatar
Default Re: Re: Nova RS S5
Cheers
Ziggy, thanx for the offer. But I'm getting the engine dirt cheap...just for trashing. Planning to buy a brand new sirio evo once I've saved enough.
Old 07-06-2004, 10:19 AM   #2079
ziggy12345's Avatar
Is the brake disk for the FW-05 and the RR the same part? The RR has a larger dia shaft so the brake disk is sloppy on the FW shaft.
I just changed mine out and the holes were all elongated suggesting some real wear going on.
Am i missing something?
Cheers
Sponsored by:
Norfolk and Chance
Old 07-06-2004, 10:29 AM   #2080
jeffreylin's Avatar
Cheers
The holes on the stock brake disk for the FW05R wears pretty fast. Since there is only one set of holes, you will need to replace it once the holes wears too big.
I use the optional VZW015 brake disk. It is thicker so it does not wear as fast. It also has 3 sets of the holes so if one starts to wear you can switch to another set of holes.
Old 07-06-2004, 10:39 AM   #2081
NiMo's Avatar
The kit disc wears badly and buckles when it gets hot.
I'm using one from Square (SFW-15), it again has six holes, but it doesn't appear to be wearing.
Old 07-06-2004, 05:42 PM   #2082
rjl
rjl's Avatar
Default Re: Kawahara Center Conversion?
Thanks!
ZF- 124 is centre swing shaft 2 pieces.
ZF- 125 is bearing adaptor
rjl is offline   Reply With Quote
Old 07-06-2004, 06:49 PM   #2083
Originally posted by esham
rcosmax, Novarossi IDM 3/5 port design - Is it a standard design for all novarossi engine now..? Do you break in it yet? How the performance?
Esham...I think the idm sleeve is different from the new novarossi engines but dont quote me as i havent compared side by side.
here is some info for those of you that want it (from idm manual)
this is the 3 port info
displacement- 2.1
power- 1.54hp
rpm- 41000
stroke-14.04
bore-13.8
sleeve-abc
ports-3
crank- modified red dot crank
piston-microcasted
case- new idm case
oh yeah and an Ielasis engraved head
This engine has insane compression and a wicked pinch! I got it stuck a bunch before actually getting it to run so make sure you heat it up loosen the plug and have fully charged batteries and youll be ok. It was all i could do to free it up by hand with the engine pulled. Just dont let it stall on the first couple of tanks and youll be fine. I cant wait to fully breakin this engine as already it sounds beautiful! I must have patience.
rcosmax is offline   Reply With Quote
Old 07-07-2004, 02:11 AM   #2084
ziggy12345's Avatar
Default Re: Re: Kawahara Center Conversion?
Where can i get spares for the conversions. Ineed the shock mount for the front conversion
Cheers
Sponsored by:
Norfolk and Chance
Old 07-07-2004, 03:11 AM   #2085
rjl
rjl's Avatar
KF-1041 is the carbon shock tower for the front conversion.
KF-1044 is the sus. pin bracket.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
