Old 07-04-2004, 10:55 PM   #2056
rjl
rjl's Avatar
The part No. in that blow up is VZ013, this is the same as the one you have. You want the wheel shafts from the VoneRR.
rjl is offline   Reply With Quote
Old 07-04-2004, 10:59 PM   #2057
rjl
rjl's Avatar
For the guys running the Kawahara centre conversion, be mindful of the altered ratio. With 20-25 pinions the gearing is about right for larger tracks, for shorter tracks you will be looking for 19-24 pinions.
Old 07-05-2004, 02:14 AM   #2058
ziggy12345's Avatar
Originally posted by rcosmax
Well I finally had a full day at my track to test the changes and new setup on my car. (i was fighting the turn in understeer) Here is what i did to try and fix it (recomended by great folks on this site)
flat front sway bar
black long spring front
gold long spring back
0 front droop
4 mm rear droop
reset rear sway bar
front suspension layed down( tried standing the shocks up but the understeer got worse)
after a massive testing session on different tires and shore with the understeer still there I finally tried a slight rear brake drag. What a difference! It drives where i want it to now!
After all that messing around fixxing the problem was as simple as adjusting the brakes a tiny bit.......Rear brake drag was the way to go! This car just roll too freely without a slight brake drag. I realized this when i ran out of fuel halfway down the back straight and coasted around 4 corners and all the way into my pits.
Anyway thanks for eveyones help!
My os tr te was still underpowered so i bought a new novarossi IDM 3 port has anyone tried this engine yet?
Thats how I drive my car. Drag brake is the way to go.
Is the IDM engine .15?
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-05-2004, 02:21 AM   #2059
ziggy12345's Avatar
Originally posted by SupermaxxRich
DAMN! Where do you see the part number for the spacers in that mess? Also I here that the stock pivot ball retainers are junk because there almost completely flat where it touches the pivoy ball. They say to run the Delrin retianers, anyone got part numbers for these items? Sorry for all the questions guys, I just want all my eggs in one basket before I go and start assembling my new beast! I do appreciate all the helpful input.
Ok here' s the list of hop up required
Ball cups with delring inserts for MTX 3
Steel 39t Bevel gears for front and rear diffs OR... Kawahara Centre conversion (I got the conversion its much better)
MTX-3 rear hubs and axles
V-1-RR rear camber links
If you have a powerfull engine get the K factory centre bulk head
Swap the self tapping screws that hold the top plate on at the front and rear for nuts and bolts (see earlier posts)
Everything else is eye candy!
Cheers
Sponsored by:
Norfolk and Chance
Old 07-05-2004, 02:37 AM   #2060
InitialD's Avatar
The engine is a .12.
Old 07-05-2004, 02:38 AM   #2061
InitialD's Avatar
How much budget (estimations) needs to be set aside for the above parts?
Old 07-05-2004, 02:51 AM   #2062
ziggy12345's Avatar
100-150 bucks
Cheers
Sponsored by:
Norfolk and Chance
Old 07-05-2004, 02:53 AM   #2063
InitialD's Avatar
Does that price include the Kawahara Center conversion?
Old 07-05-2004, 03:48 AM   #2064
esham's Avatar
rcosmax, Novarossi IDM 3/5 port design - Is it a standard design for all novarossi engine now..? Do you break in it yet? How the performance?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 07-05-2004, 04:12 AM   #2065
ziggy12345's Avatar
No for the 39 ring gears only. Add 50 bucks for that
Cheers
Sponsored by:
Norfolk and Chance
Old 07-05-2004, 09:32 AM   #2066
It was great day yesterday running the car w/ the Kawahara Center Conversion. But then that rear grub screw fell off and wasn't able to run my 3rd qualifying. Made me start 2nd to the mains.
Made a quick look after the mains.....finding out that I have this CRACK on that rear center drive cup!!!
You guys where I can get this part?
adlawoo is offline   Reply With Quote
Old 07-05-2004, 09:48 AM   #2067
ziggy12345's Avatar
Same thing happened to me!
Cheers
Sponsored by:
Norfolk and Chance
Old 07-05-2004, 09:56 AM   #2068
NiMo's Avatar
This sort of crack where the grub screw goes?
NiMo is offline   Reply With Quote
Old 07-05-2004, 09:58 AM   #2069
Hey Zig....can you Please tell me where did you get that part? Did hold though for the mains. But have to get a couple spares for it for next Sunday and also I'm thinking of using Red loctite instead of Blue. Coz, did put a lot of blue and still feel off.
Old 07-05-2004, 10:12 AM   #2070
Same problem - just on the end by the diif side, the crack line I got - goes along nearby the grub screw. And that sound sound from the diff...seems louder than the stock steel gears.
But the car is ballistic w/ this set-up.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
