Like Tree2Likes
Kyosho FW-05R
Old 07-01-2004, 08:43 PM
  #2011
Tech Legend
Marcos.J's Avatar
Trader Rating: 192 (100%+)
Originally posted by InitialD
1st gear
6.9 (20/51), 6.57 (21/51), 6.27 (22/51), 6.77 (20/50), 6.44 (21/50) and 6.15 (22/50).
2nd gear
4.98 (25/46), 4.79 (26/46), 4.61 (27/46), 4.45 (28/46), 4.87 (25/45), 4.68 (26/45), 4.51 (27/45) and 4.35 (28/45).
Thanks "D" thats exactlly what i was looking for!!
Marcos.J is offline
Old 07-01-2004, 08:52 PM
  #2012
jeffreylin's Avatar
what's up D. it's been so long since you posted here I thought you left the thread. welcome back!
jeffreylin is offline
Old 07-01-2004, 09:03 PM
  #2013
InitialD's Avatar
Long? I have always been "here". Just lurking around.
InitialD is offline
Old 07-01-2004, 10:56 PM
  #2014
Default Kawahara Center Conversion?
Yes ..just finished installing it and I got a question to those who running this set-up....
1. The slop by the new center drive cup....is that normal? Seems like the stock set-up has less slop.
2. Should I put the o-ring back to the center drive cup(Front) or leave it out?
3. Anything on that Japanese installation instruction that I miss...that is very important?
Thanks!
adlawoo is offline
Old 07-01-2004, 11:05 PM
  #2015
Racing4Evo's Avatar
I don't have the Kawahara Center Conversion yet but I did see another racer with it. He did have the o-ring in the front cup and the slop was also there.
Racing4Evo is offline
Old 07-01-2004, 11:18 PM
  #2016
Thanks Evo!
I have to put that o-ring back then...it's just there's not that much space in there - that is why I decided to leave it out --- again Thanks!
adlawoo is offline
Old 07-02-2004, 02:34 AM
  #2017
ziggy12345's Avatar
Default Re: LRP Nitro Masters 2004 Luxembourg
Originally posted by Marcos.S710
The Kyosho car of teamdriver Takuya Ito from Japan
Takuya Ito finish in 2nd at the LRP Nitro Masters 2004 Luxembourg. From the looks of the picture the car is using all Kyosho parts. I guess the car works good with out using different conversions.
Are they Mugen rear hubs or the new RRR? They look like RR top links. Also the pipe is really short
Cheers
ziggy12345 is offline
Old 07-02-2004, 02:40 AM
  #2018
ziggy12345's Avatar
Default Re: Kawahara Center Conversion?
Thanks!
I found the bearing to be loose at the back in the housing. I added a few shim washers to the drive shaft to move the cup forward to remove the slop and still support the bearing.
I also thought the clamp screws that go through the upper deck did not clamp firm enough so replaced them with bolt and nut to be able to tighten the housing down on the bearing without stripping the thread.
Also use good lock tight on the grub screw. Loss of rear drive cost me the C final last race. (I wouldnt have won but didnt even start!)
Cheers
Old 07-02-2004, 06:09 AM
  #2019
Tech Legend
Marcos.J's Avatar
Default Re: Re: Kawahara Center Conversion?
Cheers
you got e-mail!!
Marcos.J is offline
Old 07-02-2004, 08:49 AM
  #2020
ziggy12345's Avatar
The bevel drives are different. One has a groove in it and should only be matched with the right bevel gear (cant remeber which one!)
Cheers
Old 07-02-2004, 09:35 AM
  #2021
Tech Legend
Marcos.J's Avatar
Default Re: Re: LRP Nitro Masters 2004 Luxembourg
Cheers
i though that they were mugen but i recall Josh Cyrul was testing new rear arms on his FW-05R.
Marcos.J is offline
Old 07-02-2004, 10:35 AM
  #2022
Default Re: Re: Re: Kawahara Center Conversion?
Cheers
Yup...that one goes to the front diff. How about the those Japanese scripts, by any chance?
Cheers
Good idea Zig!! Just wondering how hard would be the install of the nut?? I'm gonna take a look on my car later...probably it is not that hard than I thought....
adlawoo is offline
Old 07-02-2004, 10:49 AM
  #2023
NiMo's Avatar
Default Re: Re: Re: Re: Kawahara Center Conversion?
Already sussed that one (and done it) as I got fed up with stripping the threads in the gearbox case.
Cut down a Hex key to a size that can fit an Hex screw between the chassis and gearbox, then place a hex screw through the bottom, then use the hex key to hold the screw when you fit the nut.
NiMo is offline
Old 07-02-2004, 11:55 AM
  #2024
Tech Legend
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: Kawahara Center Conversion?
it seem like a lot of work to get the conversion to work!
Marcos.J is offline
Old 07-02-2004, 12:01 PM
  #2025
NiMo's Avatar
Default Re: Re: Re: Re: Re: Re: Kawahara Center Conversion?
This is not only on the conversion, it is on the standard kit.
Mainly where the main shaft enters the rear gearbox (bearing area) , it pushes apart under load and has caused two other racers to strip their rear diffs, one of them an out the box FW05S with GS15R and single speed.
NiMo is offline
