Old 06-19-2004, 12:30 PM   #1891
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Josh...
Originally posted by FW-05S Racer
I feel awfully embaressed to admit to this... But I am running the kit/standard FW-05S exahaust...
YES! Exhaust is number one on my list of upgrades!!!
Any suggestions?
Thanks Aaron
I will try 37 shore
try the kyosho pipe set it is awsome
Old 06-19-2004, 06:09 PM   #1892
FW-05S Racer's Avatar
Talking Exhaust choice....
These are my main choices of exhaust... (If any one has any better ides feel free to tell me!)
VSW010 Tuned Silencer (5.2)
VSW011 Tuned Silencer (7.0)
VSW017 Tuned Silencer (5.2mm/Polished)
VSW033 Tuned Silencer (6.0mm) Polished
Pictures of exhaust are shown on the linked web address...
Please gimme your thoughts.
http://www.kyosho.co.jp/main-e.html
Thanks Aaron
FW-05S Racer is offline   Reply With Quote
Old 06-19-2004, 06:16 PM   #1893
Thumbs down Thanks...
Esham, thanks for the setup guide...
I know that this is not a for sale thread, but it is so hard to get any one to notice a thread on that busy thread....
Does anyone have a spare setup station for sale????
I really need one that will work for FW-05S tourer...
Thanks Aaron
http://www.bodybuilding.com/fun/aaron.htm
Old 06-20-2004, 01:14 AM   #1894
Super Moderator
Marcos.J's Avatar
Default Re: Thanks...
Thanks Aaron
i use the integy set up gages on mine and it works great
Old 06-20-2004, 06:58 PM   #1895
Thanks to everyone that helped!
Well I was able to sneak out for some testing between massive rains.... The car is much better now. the turn in push is much reduced but still there but better.... I noticed that if I feathered the brakes a tiny bit the steering became very lively so I am going to try a slight brake drag. Also the problem might have been fixxed but the track was extreemly slick due to the humidity and oils on the track (my race track had 2 inches of water so i had to use a practice track 1st time there) The cars were all loose on that track so I dont think mine was worse than anyone elses. The front tire size makes a huge difference on this car... I started with a 61 but as it was worn down to 60 and below the handling improved more. In addition to the setting changes I think a part of my problem was tires. The hard part now is waiting for next saturday .
Thanks again guys!
rcosmax is offline   Reply With Quote
Old 06-20-2004, 07:27 PM   #1896
Super Moderator
Marcos.J's Avatar
Thanks again guys!
on my fw-05r i usually run a smaller size in the front than the rear and it seems to work pretty good (60mm front , 61mm rear)
Old 06-20-2004, 11:43 PM   #1897
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
If your main is 20min or more then run a 2mm split. Josh Cyruls' setup is a lot like my current one, biggest difference being the front toe, diff oil and rear trackwidth.
Racing4Evo is offline   Reply With Quote
Old 06-20-2004, 11:49 PM   #1898
Send a message via Yahoo to JackPot
pete,
can you give me josh cyrul's set up? thanks.
jp
JackPot is offline   Reply With Quote
Old 06-20-2004, 11:54 PM   #1899
Originally posted by ziggy12345
Yup. Here it is on mine. It made a eal difference to the stability of the back end
Cheers
ziggy,
i tried the mugen rear hubs...the rear grip/handling is better..
anyway,i noticed that the inner bearing of the hub is loose..is this suppose to be like this? unlike the kyosho the inner bearing fits perfectly..do you have the same problem?
Old 06-21-2004, 12:18 AM   #1900
Racing4Evo's Avatar
It was posted on page 64 by Marcos S710. Tell me how it works for you with that new rear end. My car will be resting until after the O'Donnel race. Until then, the 710 will take me to the A-main, NOT.
Old 06-21-2004, 01:33 AM   #1901
ziggy12345's Avatar
Originally posted by JackPot
ziggy,
No i didnt have a problem with the bearings. I did use the Mugen axles though.
Did you use the spacers for the top connection? I found that I only have to run 2 deg of camber and still get the outer to inner cone shape on the outside wheel.
The tyres last a lot longer as well
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-21-2004, 06:34 AM   #1902
rjl
rjl's Avatar
Kyosho bearing is 6X12 and mugen is 6X13 you must use the mugen bearing size in the Mugen rear upright.
rjl is offline   Reply With Quote
Old 06-21-2004, 07:12 AM   #1903
Super Moderator
Marcos.J's Avatar
pete,
jp
here is the set-up!!
Old 06-21-2004, 08:01 AM   #1904
ziggy,
yes i did put spacers..and i am running 2 degree camber only and it works...
rjl,
i will double check the size of the bearing that i have..
thanks guys.
Old 06-21-2004, 10:20 AM   #1905
ziggy12345's Avatar
ziggy,
rjl,
thanks guys.
I changed one of the bearings. The other is the Kyosho one. (cant remember which one!).
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
