Old 06-06-2004, 12:40 AM   #1711
Send a message via AIM to Profoxcg
i ran my FW-05R today at the region 4 race in Fullthrottle speedway with the kyosho 2nd gear combo 27/45 with the 40 ring gear and had penty of speed at the end of the straight away. this car is awsome
hey Marcos what happened to your 710? can you post some pics of you FW05R?
Profoxcg is offline   Reply With Quote
Old 06-06-2004, 01:06 PM   #1712
ziggy12345's Avatar
Hi
Just tried the FW with te centre conversion. Dont bother trying overdirve to the rear. Its like the car is 2wd only. The rear end was on fire!
After i swapped it around to overdrive to the front it was like a rocket!!
Cant wait for the first race!!
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-06-2004, 01:39 PM   #1713
NiMo's Avatar
After blowing 5 plugs in 3 tanks I decided that my NS12S3 was about to blow so I had to stick in the down-on-power STS Dragon S3.
Rnd 1 - Blew plug after 3 laps in NS12
Rnd 2 - STS was bogging badly due to wrong clutch set up, also it struggled to change gear.
Rnd 3 - Clutch was better, so was the lower change up, car still felt slow but I set my 1st 20 lapper and took FTD.
Rnd 4 - over set clutch, just kept spinning the wheels, track felt slow but my 19 lap time was still faster than 2nd on grid.
Final - led every lap of the 10 minutes bar one, that being my pit stop lap.
Just a shame I wasn't able to race the NS12 as it is a much faster motor, but I did learn how much the clutch can affect the cars performance, I wont have it biting so late in future.
NiMo is offline   Reply With Quote
Old 06-06-2004, 05:32 PM   #1714
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default roll bar/ spares
hi all.
heres a pic off a roll bar i just recieved..its excellant...gives you a handle to grab..and it rotects the motor...where i see you all asking!
E-BAY...ask me for the link to him..
second thing...
go to. 'pro-shop futaba' japan..you have to email them for info...they have all the kawaharra parts at great prices..the cheapest in the world so far........
frieghts the killer though..( 4 me any way)......
i have some part numbers...contact me
mike
happy racing..
i use the 39 front, 40 rear..its the best i found..been testing now for 3 months..
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 06-06-2004, 05:47 PM   #1715
mikecatts's Avatar
Default pic
here it is fitted...i putthe wrong way first. derrrrrrrrrr...
it faces forward..
mike
Old 06-06-2004, 05:50 PM   #1716
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
i sold the serpent but here is my fw-05r
(using the latest Monotuning products:header gasket,fuel line and foam tires)
Old 06-06-2004, 06:40 PM   #1717
FW-05RR's Avatar
FW-05RR is offline   Reply With Quote
Old 06-07-2004, 02:07 AM   #1718
ziggy12345's Avatar
Default Re: roll bar/ spares
Originally posted by mikecatts
hi all.
second thing...
mike
happy racing..
I use the 46 rear 45 front from the centre conversion. I cant believe the handeling!
The 39 - 40t split equates to a tyre size from fron to rear of 2.1mm to have the front going wheels going the same speed as the back.
With 45-46 equates to 1.4mm so i dont have to shave off too much from the front tyres!
Sponsored by:
Norfolk and Chance
Old 06-07-2004, 02:29 AM   #1719
thefuzzclub's Avatar
Default stock gearing
can someone tell me the stock gearing (pinions n gears) of fw-05r. i heard that the gears can also be used in r,rr and evo. thanks
thefuzzclub is offline   Reply With Quote
Old 06-07-2004, 07:39 AM   #1720
NiMo's Avatar
Default Re: stock gearing
Pinion gears for the FW05R, Evo & RR are the same 0.8 gears, they can be fitted to the R if you change the spur gears.
FW05 Spur gears do not fit the V1 models
Old 06-07-2004, 07:57 AM   #1721
NiMo's Avatar
Coming soon from Kyosho:
No.VZ115-23 (0.8M/23T)
No.VZ116-28 (0.8M/28T)
Old 06-07-2004, 09:20 AM   #1722
Nitro Tech
dino.tw's Avatar
turning radius
Do you find your car has different turning radius between left turn and right turn? especially when on-power the car turn right more easy but pushing on left turn? or my car has some problem?
dino.tw is offline   Reply With Quote
Old 06-07-2004, 09:41 AM   #1723
cyba888's Avatar
Default Re: turning radius
Dino long time no see Are you running a FW05R?
Havent got a chance to race at Wanban but I look forward to be there soon.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-07-2004, 09:55 AM   #1724
jeffreylin's Avatar
R/C Tech Charter Subscriber
Mine does the same, although it's nothing I couldn't get use to and perhaps even take advantage of sometimes. I think it's a combination of tweak and torque steer, inherent characteristics of a shaft car. With the engine and fuel tank on one side, it could never acheive the weight balance of center mounted engine and fuel tank.
jeffreylin is offline   Reply With Quote
Old 06-07-2004, 09:57 AM   #1725
Nitro Tech
dino.tw's Avatar
Default Re: Re: turning radius
Yep,long time no see you. I guessed you give it up...kaka....
I just got a FW05R. Still need more time to get with it.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
