Old 06-04-2004, 10:18 AM   #1681
ziggy12345's Avatar
Originally posted by dino.tw
You want to know what? My first breaking part??
That looks bad. I suspected that would be a weak area. Ill order the replacements before racing
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-04-2004, 10:27 AM   #1682
Nitro Tech
dino.tw's Avatar
Originally posted by Marcos.S710
is that the kawahara conversion? how did that happen?
The steering servo turn too much and locked by the steering block... so I hit the wall..... ... I should listen to Manticore's tip ...
dino.tw is offline   Reply With Quote
Old 06-04-2004, 10:29 AM   #1683
Nitro Tech
dino.tw's Avatar
I think it's strong enough if you don't hit the wall....
Old 06-04-2004, 10:30 AM   #1684
ziggy12345's Avatar
Whas it a crash where you expected to break something or a small shunt where you would have expected to get away with it?
Cheers
Sponsored by:
Norfolk and Chance
Old 06-04-2004, 10:34 AM   #1685
RichChang's Avatar
I am curious -- what was Manticore's tip?
-Rich
RichChang is offline   Reply With Quote
Old 06-04-2004, 10:34 AM   #1686
ziggy12345's Avatar
Dave Splashet was talking about the FW-05 in Radio Racer Mag this month. He had good things to say about it.
He mentioned the setup he used at the nationals... 3deg camber at the front and 5deg camber at the back
Better stability and lower tyre wear!!
Sponsored by:
Norfolk and Chance
Old 06-04-2004, 10:50 AM   #1687
Nitro Tech
dino.tw's Avatar
Cheers
If you believe GOD,God will bless you...
Old 06-04-2004, 10:55 AM   #1688
Nitro Tech
dino.tw's Avatar
Default Manticore's tip
-Rich
He said:
add a stand off on top of the steering ball cap
it will stopped by the arm from going in further
your case is that the steering arm went into it but cannot come out
Old 06-04-2004, 11:00 AM   #1689
NiMo's Avatar
Just back from the car park!!. I put the 20/51 first and the 25/46 second. the lowest gearing for the conversion. The carpark had zero grip so it wasnt a good test. Its about 200ft long but i didnt have enough room to get into 2nd for more than a brief moment.
I changed from 16% to 25% nitro and the car rockets off off the line!
I will try it at the track nxt week. I suspect the lowest gear is still slightly too tall for our track.
We shall see
I think you might be surprised just how much it will pull out of the corners.
I ran yesterday at the track, firstly on 32's and the car was gripless and spun the wheels all to easily, but when I put on the 27's the car came alive and the 21/51 was bang on (i even rear ended a foam shod MTX3 out of the race control hairpin).
NiMo is offline   Reply With Quote
Old 06-04-2004, 11:02 AM   #1690
Nitro Tech
dino.tw's Avatar
Yes,my camber setup is F 3/R 5 at present. But still not stable enough when on-power. Maybe my rear diff is to tight...#30,000 now... But I have to wait for the part now so can't keep on testing this weekend...
Old 06-04-2004, 11:05 AM   #1691
jeffreylin's Avatar
R/C Tech Charter Subscriber
Well Dino, how do you like the car before it met the wall?
I have the front conversion kit as well but I have yet to install it because of this reason. The nylon part looks like something will break in a crash. As you know, you've got to finish to win.
By the way, I broke my front bulkhead too the first time out with it. I did not anticipate the car to roll so freely and I did not let off and break in time at the end of the straight.
jeffreylin is offline   Reply With Quote
Old 06-04-2004, 11:15 AM   #1692
jeffreylin's Avatar
Dino, if you ran at Silverstone, you will need +4 camber in the rear for sure with this chassis. Otherwise the tire will wear like a reverse cone. I ran 2.5 in the front and it wore okay.
Old 06-04-2004, 11:27 AM   #1693
Nitro Tech
dino.tw's Avatar
Still do not have enough time to adapt this car...
My setup isn't good ... easy to lose rear grip when I leave the corner ... but it has very good acceleration ... a strange car
Give me more days,I will let you know more
Old 06-04-2004, 11:33 AM   #1694
Nitro Tech
dino.tw's Avatar
Thanks for your suggestion,buddy. I will try it later.
Old 06-04-2004, 12:52 PM   #1695
ziggy12345's Avatar
Are you running the same gearing as me?
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
