Old 06-03-2004, 02:55 PM   #1666
ziggy12345's Avatar
You got any pics of yours Nimo?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-03-2004, 02:55 PM   #1667
NiMo's Avatar
Originally posted by Marcos.S710
is that the kyosho gears 27/45 ? thats what i got with the 21/51 for first
I used to run a 22/50 1st gear and pulled a good few rev before changing up, but now the 1st gear is longer and I can change up at much lower revs and appear to get less bogging down effect, but once it hits 2nd it just goes.
Performance wise I would greatly recommened the Centre conversion, just have to wait a while to check the wear rate.
NiMo is offline   Reply With Quote
Old 06-03-2004, 03:01 PM   #1668
NiMo's Avatar
Cheers
none more recent than this not quiet finished version
Old 06-03-2004, 04:06 PM   #1669
ziggy12345's Avatar
This is the MTX-3 rear hubs on the FW-05M!
The dogbones need to be a bit longer but i put an o ring in the diff cup and the axle to centre it.
You can see that if you roll the car wheel stays at the same angle all the time.
I havent set the toe in or camber right yet
Cheers
Sponsored by:
Norfolk and Chance
Old 06-03-2004, 05:48 PM   #1670
ojo
Thanks Nimo for the help.
BTW, wat pipe and manifold r u using with your full conv.?
ojo is offline   Reply With Quote
Old 06-03-2004, 05:57 PM   #1671
Sow&Steady's Avatar
Originally posted by NiMo
none more recent than this not quiet finished version...
Nice one NiMo, looking forward to seeing it on the track
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-03-2004, 10:58 PM   #1672
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Cheers
thats really good , did you use Kyosho bearings and axle?
Old 06-04-2004, 01:55 AM   #1673
ziggy12345's Avatar
You can use the innerbearing but need the Mugen outer bearing. I used the wide tyre axle but found this to be 210mm wide. I will change it for the normal one.
You will also need the pivot balls and the end caps. I also fitted the spacers at the top link connection (small silver washers in pic)
The centre conversion goes on today!! then down to the track for a test!!
Sponsored by:
Norfolk and Chance
Old 06-04-2004, 06:28 AM   #1674
NiMo's Avatar
RDLogics FW05 Manifold (large bore) / Nova Rossi 5.2mm pipe.
Old 06-04-2004, 06:55 AM   #1675
Super Moderator
Marcos.J's Avatar
let us know
Old 06-04-2004, 09:01 AM   #1676
Nitro Tech
dino.tw's Avatar
let us know!!
You want to know what? My first breaking part??
dino.tw is offline   Reply With Quote
Old 06-04-2004, 09:04 AM   #1677
Ares17's Avatar
Default Set-Up Board
Hi guys, do i really need a set-up board when building the car? Is there a maker for full set up system that caters to 1/8th and 1/10th? Or what is really necessary when building the car? I got the ride height gauge and the camber gauge. Is there anyting else I need? Thanx in advance.
Ares17 is offline   Reply With Quote
Old 06-04-2004, 09:35 AM   #1678
Super Moderator
Marcos.J's Avatar
is that the kawahara conversion? how did that happen?
Old 06-04-2004, 10:15 AM   #1679
NiMo's Avatar
Default Re: Set-Up Board
You don't need anything but your life will be so much easier if you have the set up equipment.
A sheet of glass can be used instead of a proper board.
The Hudy guages can become scratched and hard to read in poor light, I sold mine and got some alloy ones.
You may want to look at a 'Tweak Station' as well so you know your car actually sits flat on the road under its own weight.
I don't use my ride height guages as I tend to go by look and feel.
Old 06-04-2004, 10:17 AM   #1680
ziggy12345's Avatar
let us know
Just back from the car park!!. I put the 20/51 first and the 25/46 second. the lowest gearing for the conversion. The carpark had zero grip so it wasnt a good test. Its about 200ft long but i didnt have enough room to get into 2nd for more than a brief moment.
I changed from 16% to 25% nitro and the car rockets off off the line!
I will try it at the track nxt week. I suspect the lowest gear is still slightly too tall for our track.
We shall see
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
