Like Tree2Likes
Kyosho FW-05R
Old 05-26-2004, 11:17 PM
  #1531
B
I would not be surprised if an update for this car will be announced relatively soon.~
B is offline
Old 05-26-2004, 11:25 PM
  #1532
Trader Rating: 37 (100%+)
Default Re: Kawahara Front end conversion
Originally posted by dameetz
What are the parts listed in this package? I m temted to buy one but not sure if this front conversion can be directly bolt on to my stock upper deck. Or do I need to buy the whole center conversion as well?
you don't need the whole center conversion. it will bolt up to the stock upper deck. it consists of a metal bracket that relocates the upper hinge pin slightly downward and outward (shortens the upper arm). it also has new upper hinge pins, carbon fiber front shock tower with inserts to capture the front of the new hinge pin, plastic rear hinge pin holder with carbon fiber bracket to bolt up to the stock upper deck. its a pricy conversion but it made a definite improvement in steering.
Buggy Master is offline
Old 05-27-2004, 03:46 AM
  #1533
dameetz's Avatar
Thanks for the info Buggy Master.
dameetz is offline
Old 05-27-2004, 03:54 AM
  #1534
Ares17's Avatar
Originally posted by jeffreylin
I think the guy is trying to sell you a VOne RR Evo. There is no FW-05RR Evo.
I thougth so too..but the fella insist thats its a fw05rr evo....
but..anyhway....pardon me for 'shouting'
I JUST GOT MY FW05R TODAY!!!!!! Yipppeeeeeeee.....dun know when will i have the time to build it....
been reading this threads but cannot remember what are the essential hop up i need to make the car bomb proof....so can anyone post the essential hop up needed for the car please...
1)
2)
3)
Ares17 is offline
Old 05-27-2004, 05:26 AM
  #1535
1)
2)
3)
Definitely get steel gears for the differentials. The ones that come with the car will not withstand hard racing.
JPRacing is offline
Old 05-27-2004, 05:37 AM
  #1536
I haven't had any issues with stock gears. I've been using them for 3-4 months now.. (Yes racing and practices every weekend,,)
GUNPOWDER is offline
Old 05-27-2004, 05:54 AM
  #1537
Tech Legend
Marcos.J's Avatar
Trader Rating: 192 (100%+)
Originally posted by dougday
Marcos, I'll be looking out for that purple bomb at FT. I have been watching this forum because of my interest in the FW05R. I am looking forward to see how it performs
i will do my best!!
Marcos.J is offline
  #1538
Ares17's Avatar
Thank you. Keep it coming guys...
Ares17 is offline
Old 05-27-2004, 09:41 AM
  #1539
Tech Legend
Marcos.J's Avatar
Originally posted by Racing4Evo
Yes, I borrowed my friend's.
how did it perform?
Marcos.J is offline
Old 05-27-2004, 10:26 AM
  #1540
ziggy12345's Avatar
1)
2)
3)
Mugen clutch bell and the 28 and 29T pinion gears. Also change the 46 and 51t spurs that come with the kit to 45 and 50.
What engine and pipe have you got?
Cheers
ziggy12345 is offline
Old 05-27-2004, 10:45 AM
  #1541
jeffreylin's Avatar
1)
2)
3)
1. Kyosho manifold and pipe.
2. 3Racing front aluminum bulkhead
3. Square titanium center shaft
jeffreylin is offline
Old 05-27-2004, 10:38 PM
  #1542
Ares17's Avatar
Cheers
Most probably i'll be using OS TR with Kyosho pipe and manifold...but havent decide which to get...the 5.2,6 or 7mm.
Ares17 is offline
Old 05-28-2004, 12:47 AM
  #1543
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default front conversion
hi all
about the kawahara front conversion....yes is does work ,but when you order, get a spare "nylon" top hinge pin holder...it doesnt take much to break..
mike
check out my pics...
mikecatts is offline
Old 05-28-2004, 03:44 AM
  #1544
rjl
rjl's Avatar
Default Re: front conversion
Originally posted by mikecatts
hi all
mike
Do you have a part No. Mike?
rjl is offline
Old 05-28-2004, 04:18 AM
  #1545
esham's Avatar
Ok almost 3 weeks now i didn't touch my FW05R. I need to do post mortem. Last run i had oversteer on power into corner. I will trouble shoot it tommorrow..
esham is offline
