Like Tree2Likes
Kyosho FW-05R
Old 05-26-2004, 09:30 PM
  #1501
Tech Legend
Marcos.J's Avatar
Trader Rating: 203 (100%+)
Default fw-05r
here is my finished FW-05R
(using the latest Monotuning products:header gasket,fuel line and foam tires)
Marcos.J is offline
Old 05-26-2004, 09:34 PM
  #1502
ojo
thanks jeffreylin & mikecatts.
i am now using the 5.2 pipe.
from wat i heard, bigger dia means bigger fuel consumption, higher temp but higher speed as well.
so, will a 6.0 dia do? or should i just stick with the 5.2?
thanks again.
ojo is offline
Old 05-26-2004, 09:43 PM
  #1503
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default cooling
hi.
i use the 11 fin head instead of the 9. and a low profile air filter..."magic"..brand.
mikecatts is offline
Old 05-26-2004, 09:55 PM
  #1504
Hi. I am a new owner of an fw and would like to know what pinion/spur combination do I need to use on a really tight track.
Thanks for any help you guys can give me.
JPRacing is offline
Old 05-26-2004, 09:58 PM
  #1505
Tech Legend
Marcos.J's Avatar
stock should be fine, but i will be testing mine in the next couple of days one in a tight technical track and then on a large high speed track(probably will have to gear up for the large track)
Marcos.J is offline
Old 05-26-2004, 10:06 PM
  #1506
Racing4Evo's Avatar
Hello everyone. Can everyone please list where you run your FW-05R
*how long your straight is
*what pipe you are using
*what your engine temperature is after the qualifier
Thank You
I'll start
Revelation Raceway
160 Ft
RD Logic
255 degrees F
Racing4Evo is offline
Old 05-26-2004, 10:07 PM
  #1507
Tech Legend
Marcos.J's Avatar
Thank You
I'll start
Revelation Raceway
160 Ft
RD Logic
255 degrees F
i will know by monday
By the way are you using stock gears at revelation?
Marcos.J is offline
Old 05-26-2004, 10:10 PM
  #1508
FW-05RR's Avatar
nice ride marcos what gearing are you going to use
FW-05RR is offline
Old 05-26-2004, 10:11 PM
  #1509
Racing4Evo's Avatar
No, I am using 22/27 pinions 51/45 spur gears and the 39t ring gears.
Old 05-26-2004, 10:12 PM
  #1510
Tech Legend
Marcos.J's Avatar
i have the stock for now but for the larger track im going to try 27/45 combo for second gear and see how that works then my next step is to change the diffs from 40t to 39t.
Marcos.J is offline
Old 05-26-2004, 10:13 PM
  #1511
Tech Legend
Marcos.J's Avatar
how is the mesh you have a 73 gear combo in first and 72 in second!
Marcos.J is offline
Old 05-26-2004, 10:15 PM
  #1512
Racing4Evo's Avatar
You shouldn't even bother with the 40t. The 39t ring gears still have enough punch out of the corners but really mellows out the power band. It is going to be a must for FT speedway. What pipe are you using?
Old 05-26-2004, 10:16 PM
  #1513
Tech Legend
Marcos.J's Avatar
i have the novamega TP-04
Marcos.J is offline
  #1514
jeffreylin's Avatar
Thank You
I'll start
Revelation Raceway
160 Ft
RD Logic
255 degrees F
Revelation
160 ft
Kyosho
210?F
jeffreylin is offline
Old 05-26-2004, 10:18 PM
  #1515
Racing4Evo's Avatar
Oh sorry about that. 50t spur gear, the smaller one and the 45 second gear.
