Old 10-26-2003, 06:06 PM   #136
tomkelley's Avatar
Shaft and belt drive cars have both advantages and disadvantages. I wont relist what has already been talked about ad nauseum. However there is no one "best" system, if there were everybody would be running that system.
AMG- Could you please point me to some discussion boards of this debate? In the GT4 thread its is rumored Yokomo is on a prototype, possibly shaft, so I just want to hear all the arguments over it for my own amusement.
Thanks,
TK
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 10-27-2003, 02:55 PM   #137
coldeye's Avatar
Default want one
I want this car . Anybody know where to get a deal. I read earlier 295.00 usd with shipping. I can use the help.
coldeye is offline   Reply With Quote
Old 10-27-2003, 06:10 PM   #138
Registered User
OB42TC3's Avatar
Anyone who has this what is the lowest (numerically) 2nd gear available; can it go as low as 4.4:1??
OB42TC3 is offline   Reply With Quote
Old 10-28-2003, 12:09 AM   #139
Default Re: want one
How much are you looking to spend?? I've got a fully hopped up FW-05R which I am consider of selling.... Need money for a 15" PowerBook G4.
The car is brand new with the following brand new hop-ups
1. Kyosho TCD Gear set
2. Kyosho Carbon Upper Deck
3. Kyosho Caron Front Shock Tower
4. Kyosho Carbon Rear Shock Tower
5. One-Piece RD Logic Turbo Pipe
6. Kyosho Red Clutch Pad
7. Front Streering Turnbuckle
8. Squat Steering bearing
9. Kyosho Front One Way
10. Wide rear wheel shaft
cvccsi is offline   Reply With Quote
Old 10-28-2003, 09:11 AM   #140
coldeye's Avatar
Post
CCVCSI sent you PM. If you didn't recieve it I am interested in the car.
Old 10-31-2003, 01:02 AM   #141
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
to all who own this car, I was wondering how is the durablilty. Do the settings go out of wack if you tap the boards as with the ntc3? would you guys reccomend the car??
thanks J.
jscamry is offline   Reply With Quote
Old 10-31-2003, 01:06 AM   #142
Sp Racer's Avatar
.......definitely get one, they can take a fair whack and stay in one piece...just like a VoneR.
About the only gripe that I have is the highish wear on the gearbox internal gears, but i'm sure that will be addressed soon by Kyosho.
Sp Racer is offline   Reply With Quote
Old 10-31-2003, 10:00 AM   #143
Default FW05R Steering
Did any of you guys experience some steering slop on the FW? Mine doesnt center its steering even after I let go of the wheel. Any tips would be greatly appreciated
JPRacing is offline   Reply With Quote
Old 10-31-2003, 10:03 AM   #144
Joehwee's Avatar
You may want to try to tighten the servo saver spring, if not you can change the harder servo saver spring, they are the same size as the clutch spring.
Joehwee is offline   Reply With Quote
Old 11-01-2003, 02:08 AM   #145
SioKoy's Avatar
Send a message via ICQ to SioKoy Send a message via Yahoo to SioKoy
Default 2nd Gear Adjustment
Hey guys anyone can teach me how to adjust the gearbox or should i say 2nd gear without removing the whole gearbox thing? Based on the manual you have to adjust the grab screws to 1.5 turn which is actually it doesn't shift to 2nd gear.
SioKoy is offline   Reply With Quote
Old 11-01-2003, 04:20 AM   #146
Default FW steering
Joehwee: Thanks I tightened the servo saver from the bottom and it worked. No more slop and it now centers. I wish all rc problems are that easy to fix Thanks again
Old 11-02-2003, 07:14 PM   #147
Joehwee's Avatar
Siokoy:
Do not follow the instruction, there seem to be some error on that part. Anyway unscrew the two speed adjustment 3 turns (both the 2.6mm screw), your 2 speed should enaged and now you can adjust it according to your track. The followings are what I have done to my 2 speed;
1) I have grind off about half the head and taper the 2.6mm screw cos when at 3-3.5 turn out, they are some slight contact with the 2nd gear. But make sure you left enough for your 2mm allen key to make adjustment.
2) Make sure your 2nd speed clutch spin freely in the 2nd gear
3) The hole on the 2nd speed is pretty small and try to enlarge it slightly so that you can access and see the adjustment screw easier. Hudy 2mm ball allen key is a good tool for adjusting the 2 speed as the shaft is smaller.
Hope the above will help.
Regards
Joe
Old 11-03-2003, 01:17 AM   #148
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
universal shaft
question guys, would the kyosho power universals or the k-factory universal shaft would fit with this kit? thanks.......
buboy28 is offline   Reply With Quote
Old 11-03-2003, 02:51 AM   #149
Joehwee's Avatar
Buboy28: You are not able to use the UJ from the V1R/RR/Evo on the FW05R as they are about 10mm longer (both the front and rear). So far only Kyosho come out with the FW05R UJ and you will also require a different UJ if you are running one- way. The part number for the UJ are as follows;
VSW006 - Universal Swing Shaft (Front for Diff)
VSW007 - Universal Swing Shaft (Rear for Wide Axle)
VSW015 - Universal Swing Shaft (For One-Way)
Old 11-03-2003, 06:31 AM   #150
SioKoy's Avatar
Joehwee;
thanks for the info
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
