Old 05-07-2008, 05:50 PM   #31
huskerfreak's Avatar
Jack you got pm
huskerfreak is offline   Reply With Quote
Old 05-07-2008, 06:01 PM   #32
Jack-
Is Cyrul still designing wheels for you? Has he tested them yet? Just wanted his imput into the design. Just had a few questions for him.
slewis is offline   Reply With Quote
Old 05-07-2008, 06:01 PM   #33
captian's Avatar
Originally Posted by Jack Rimer View Post
Yes, they will be coming next month.
are those the rims that josh was testing at the race and are they going to have camber in them as well ?
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 05-07-2008, 06:18 PM   #34
Josh Cyrul's Avatar
slewis - Yes, I am still doing all the rim design work for Jaco. I have not tested them yet though as tires went out to the other drivers to test. I only recieved samples to make sure the molds were produced correctly.
As a side note, the rear rims are just under the legal 50mm max diameter while the fronts are 49mm. This gives a slightly smaller front rim (as was done on the Prism 1/12 tires) to keep the balance of foam more similar from front to rear as most nitro TC's now always run the 2mm split. This yields more steering to match the extra rear traction the 1.5 taper and revised flex of the rear rim generates.
Due to the constraints in the rules in 1/8 (max O.D. limit) and the fact that the cars are maxed out as far as I.D. clearance, we weren't able to use the taper on the 1/8 rims. With the TC's, there was some room to work with the taper, front face stiffness and back edge flex that all worked out pretty spot on.
I'm sure once everyone has an oppertunity to test out this concept first hand that they will be very happy with the performance and especially the increased stability and consistancy that will be generated. Not to mention these rims are quite a bit lighter and they are made from very strong material that will be next to impossible to break or damage.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 05-07-2008, 07:14 PM   #35
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by E.Rocha View Post
hmmm i though you know everything
Hmmm...how's that crow taste smart ass...
At least have a set and use your real name if you want to TRY and make dumb comments.
EA
EAMotorsports is offline   Reply With Quote
Old 05-07-2008, 10:01 PM   #36
Roger's Avatar
Hey Jack. Maybe you should've got those rims for your Maserati . Drew Dawg told me the story .
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 05-08-2008, 08:51 AM   #37
Brazilct's Avatar
josh are those new rims coming in 2 mm off-set for the RRR ? Renato
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
MAXY's PRO RACING FUEL & MODIFIED MOTORS
Brazilct is offline   Reply With Quote
Old 05-08-2008, 09:43 AM   #38
richey's Avatar
Send a message via MSN to richey
EA
The roach never has anything constructive to say just ignore him everyone else does. Hopefully he will get his just reward the bottom of a shoe.
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 05-08-2008, 12:50 PM   #39
Correct me if I am wrong but does this mean the front and rear tires would come with an almost 2mm split, without having to true the tires?
jelayne is offline   Reply With Quote
Old 05-12-2008, 03:03 AM   #40
Where can we order these tires on-line ?
Paul D. is offline   Reply With Quote
Old 05-12-2008, 04:24 PM   #41
Brazilct's Avatar
guys i just got off the phone whit Richie from BROOKLYN HOBBIES.COM and hes going to have the new " Prism 1.5 " sedan tires available at the end of this month "may" in time for the capitol classic
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
Old 05-19-2008, 06:51 AM   #42
mcsquish's Avatar
Josh, I'll let you know.............
mcsquish is offline   Reply With Quote
Old 06-07-2008, 12:04 PM   #43
A number of "new" tires were released at the Capital Classic. However, it was the JACO 1.5 Prism sedan tires that impressed the most with a 1-2 qualifying performance. Ralph Burch and Josh Cyrul took the top spots at this fantastic event with the new Prism sedan tires. Both drivers felt the added rear traction resulting from the tapered wheel allowed them to remove rear toe-in, thus resulting in higher top speed. Mains are tomorrow.
Jack Rimer is offline   Reply With Quote
Old 06-08-2008, 09:32 PM   #44
Congrats to Ralph Burch on his win in sedan with the new wheels. Ralph won by well over a full lap in the main. Also, Mike Blackstock ran the fastest lap in the main on the Prism 1.5 tires. Half of the cars in the A-main were on the new Prism wheels and all ran without any tire problems.
Old 06-08-2008, 11:03 PM   #45
just a few questions regarding these tyres;
what sort of foam is used? Japanese (high rubber content), american (low rubber content) or european ("wet" heavy foam type)??
also where can you buy them online?
TomB is offline   Reply With Quote
** CHEAP ** Jaco Sedan Foams Jaco 1/12 Foams New in Package 20+ pairs rc36deuce R/C Items: For Sale/Trade 23 10-07-2008 06:47 PM
2008 CAPITOL CLASSIC @ 301 RACEWAY June 4-8 Chewdogg Nitro On-Road 615 06-17-2008 08:55 PM
Capitol City Classic: Race For Autism Awarness vines Kansas/Missouri Racing 116 06-10-2008 04:37 PM
2007 Capitol Classic @ 301 Raceway Chewdogg Nitro On-Road 616 08-10-2007 04:48 PM
Foam Tire Sedan vs Rubber Tire Sedan RCGaryK Electric On-Road 57 01-25-2004 04:27 PM
