HPI R40 Nitro Car Forum
#1216
Sorry about that, that was a mistake in speaking on my part.
If your happy with the 21/43 on your 2nd gear ratio, then just drop down to a 16T 1st gear pinion and stick with your 48T 1st gear spur. That should allow you to get your gear mesh perfect.
Sorry about the mix up!
Sleeper: thx for clarify that, i know there's a talk about gearing early on this thread, i'm just too lazy to find it
#1217
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
you can use any FIRST GEAR PINION and SPUR gear combo with ANY second gear pinion and combo...
Look in the back of your manual...all the part numbers are there,as well as the combo's gear ratios....
I can't see why this is still an issue...
#1218
Regional Moderator
Its an issue because he asked and none of the 'experts' around here answered. So I answered the best I could.
Personally, I still don't see how its "physically" possible to run "ANY" combo, but if you guys say so I'll take your word for it.
And since he is having gear mesh problems with his combo, I would guess that "ANY" combo isn't possible.
But again, if I'm wrong, no problem, I was just trying to help him!
Jezzzzzzzz........
Jezzzzzzzz........
#1219
#1220
Regional Moderator
Originally posted by InitialD
You can. Other cars have already been able to do this on their gearing selections before the R40 came out...
I think front1wayFreak mentioned that he has a Mugen clutch on his R40. Perhaps that is the reason for his meshing problem... Else, everything should work fine as fastharry mentioned.
#1221
I just picked one up today. Quite a few of the 1/8 scale guys here in the Midwest are going to be running them this year. I was told the car was designed at least in part by Delta(who also did the proceed). The gear thing is one of the nice features of the car. I like a lot of the little things in the design that I think will make it bullet-proof. Oh well hurry up USPS.
#1222
#1223
Originally posted by B
did you get your friend a R-40 equilavent present ??
renjie:
i've known my friend since 1st grade and he is like family to me. regardless whether he buys me an R40 or just an X mas card its the thought that counts.
i hope everyone had a great holiday and a happy new year.
oh yeah, and on the gear thing, i think how they can pull it off with proper gear mesh if the diameter of the different spurs are the same and ditto for the pinions. the actual teeth of the gears between the different spurs would have to be slightly different in order to accomodate for the same diameter.
#1224
Not playing devil's advocate here, I thought you mentioned previously that you were looking for cars that would do at least 4.4 thereabouts on the 2nd final drive ratio. If that's the case, the R40 would not even cut it at 4.957.
I think you guys are gonna be suprised with some upcoming parts for the r40......
HPI is really committed to this car(as well as the PRO4)...
Gearing issues will be adressed.....
#1226
#1227
BTW, R40 been out for a while and i'm surprised not too many aftermarket companies make hopups for it (unlike the racer generation). Do you know if HPI will come up with rear blade type sway bar?
#1228
Regional Moderator
front1wayfreak: Actually, just about EVERY major aftermarket company has a line of hopups for the R40. Not to mention the stuff from HPI.
3racing
Integy
Kawahara
HPI
all make hopups. Most of them just haven't made it to the market yet. Most are listed as "Coming Soon".
HPI Japan has a rear adjustable dual blade type sway bar for the rear on their site. Don't know when/if it will reach the states though.
http://www.hpiracing.co.jp/
Just type in R40 into the search bar, then start clicking links. You'll eventually run across the hop ups page.
3racing
Integy
Kawahara
HPI
