Old 12-21-2003, 06:29 PM   #1186
Moderator
Jpilone's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Jpilone
here's a pic of my car shortly after it was built 2 weeks ago. I did a little photo spread for advertising the kit on a hobby shop website:
-Jarrod Pilone
Pro R/C Photographer
http://www.jpsportspics.com
Jpilone is offline   Reply With Quote
Old 12-21-2003, 06:31 PM   #1187
Here's a link to Hara's setup. http://www.hpiracing.com/setups/su-r40a.htm
RTolle is offline   Reply With Quote
Old 12-21-2003, 09:40 PM   #1188
Coxy's Avatar
Can anybody help out and tell me what the internal ratio is on the R40. It will just save me counting the teeth.
Coxy.
Coxy is offline   Reply With Quote
Old 12-21-2003, 11:20 PM   #1189
InitialD's Avatar
Coxy.
46/19 = 2.421
Old 12-22-2003, 09:17 AM   #1190
Regional Moderator
Darkseid's Avatar
Had a little setback with the car. For some reason I can't figure, the diffs started leaking. It just started?!? This, after I had the car assembled for about two weeks with no leakage.
Anyway, I went back in, cleaned everything up and gave it the 24 hour sealant treatment. I used enough sealant on the gasket and diff cases, that I'm pretty sure the leak will never happen again.
Engine should be here tomorrow, then the waiting for warm weather begins.
TLR 22...Tamiya F104...
Old 12-22-2003, 11:56 AM   #1191
Default Re: Weight concerns
Originally posted by Darkseid
My car came in at 3lbs. 14oz -> 62oz -> 1757g
So, ummm.......wheres the weight problem? Thats less than a Team Only ReflexNT.
I don't know what RCCA had on the car when they came up with 1910.
Did you include body, foams and electronics?
johan is offline   Reply With Quote
Old 12-22-2003, 12:36 PM   #1192
Regional Moderator
Darkseid's Avatar
Default Re: Re: Weight concerns
Uhhhh.....yeah, the car had the foams and electronics on it. Why would I weigh a car without anything on it?
Old 12-22-2003, 12:43 PM   #1193
Regional Moderator
Darkseid's Avatar
As for the body, it seems to be a toss up as to whether people weigh the cars with or without the body. I most often see them listed as "weight RTR w/o body". So thats how I weighed mine.
Old 12-22-2003, 05:16 PM   #1194
Thanks...
Since the cars are weighted with body at races, I would think that would be natural standard. But it doesnt matter in reality. Minimum weight is 1725 (including body). The body adds about 100 grams. Your r40 would weigh in at about 1855...
And yes, I am math-genius
Old 12-22-2003, 08:07 PM   #1195
Regional Moderator
Darkseid's Avatar
Yeah, at the races the cars are weighed with the bodies, but when magazines or sites do reviews, they generally weigh the car without the body. This is because body choice and paint style(how many colors used, how many coats) can vary greatly, which would throw off the weight as listed in reviews.
This is why most people, outside race directors, usually list a cars weight without the body.
In any case, what I was saying is that there is some kind of oddity in the way that RCCA weighed the R40. For them to get 1910g for this car, while getting 1760g-1795g for other cars says that they did something different than what they did when they weighed the other cars. Cause even with the body, theres no way my car makes it to 1900+ grams.
Old 12-23-2003, 03:14 AM   #1196
Coxy's Avatar
any of you guys played around with different gearing from 1st to 2nd gear. I have written a speadsheet to know my options in different rollouts for different changes using different sets from each colour of gears.
Just wanted to know if you guys have changed this as I think a larger change is needed.
Coxy.
Old 12-23-2003, 10:04 PM   #1197
Merry Christmas
Is Santa bringing anyone some lightweight hop up parts for Christmas??
All I'm getting is a hangover which will be fun when I start work on Christmas day
renjie is offline   Reply With Quote
Old 12-24-2003, 07:32 AM   #1198
Chewdogg's Avatar
Unhappy
No lightweight parts
(already have the shafts though)
But I'm gettin a ton of R40 spares from tower and a Kyosho Mad Force
hmmmm.....wonder if I could talk santa into bringing me a mugen X12
Chewdogg is offline   Reply With Quote
Old 12-24-2003, 03:11 PM   #1199
tranced's Avatar
Santa brought me a front CF shocktower.. i think hes still manufacturing the rear ones
tranced is offline   Reply With Quote
Old 12-24-2003, 05:14 PM   #1200
tranced's Avatar
TIP for the rear body mounts.
The HPI Upper Arm/Body Mount Tree for the Super Nitro contains 2x short posts. Trim them down and also Trim the 3 hole Body Mount Cap for a perfect rear mount!
http://www2.towerhobbies.com/cgi-bin...?&I=LXLV92&P=7
If you need even lower mounting, you can drill holes into the mounting cap above the first, then trim the first hole off, and trim the rear post lower to compensate.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
