Old 03-01-2011, 10:32 AM   #11956
JLock's Avatar
Originally Posted by stefanos View Post
hi guys after long time ;P
i have teh R40 hara and it keeps always destroying the 2nd gear ....and still i dont get why ....also it gets hard and harder to find gears on ebay for the hara edition clutch ...anyone know how to find or where they might have ???
must find ppl to send to greece basicly ;P
thnx in advance
steve
You have three things that may be causing the gear to strip:
1. Bad bearing in your 2-spd housing
2. Slightly bent 2-spd shaft
3. Loose mesh of your gears
Check those three things before you proceed further. When meshing the gears, start with the 2nd gear first. The bearing in the 2nd speed housing does get dirty and may have some debris in it which is causing the bearing not to spin freely. With the 2-spd shaft, you will have to take it out of the car and roll it on a flat, level surface. If you have no issues with the above, then check to see if your engine is secure and not shifting on the chassis (not tight enough) or shifting on the engine mounts (not tight or broken mount bolt). Hope this helps.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 03-01-2011, 05:54 PM   #11957
fastharryDOTcom's Avatar
Thats better than my answer.... I would have said my R40 is using it's same set of gears, haven't changed them in 6 years, so something is wrong with your set-up or parts...LOL
visit fastharry.com We are always updating the site with new cars and cool rc stuff.
old user name "fastharry"Posts: 2,845 Original join date 2001..HPI Challenge Winner.
fastharryDOTcom is offline   Reply With Quote
Old 03-01-2011, 07:16 PM   #11958
JRGTR's Avatar
Send a message via MSN to JRGTR
hello guys
Istill have and R40 Hara edition plus a few spare parts including the original chassis, the car have the complete centax if any one want this treasure pm me!
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 03-03-2011, 12:20 PM   #11959
bxpitbull's Avatar
Default Coming out of the woodwork
Been out the game for a MINUTE. Last I ran, I was running a .12 Picco Red Dot....SICK! I see that engine is still expensive. Whats good for the R40 without breaking the bank? Just got a house, so I have to approach with financial caution.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 03-03-2011, 03:06 PM   #11960
JLock's Avatar
I never had that issue with my R40 when I had it. However, I have a stripping gear issue with my Mugen MTX4 and previous MTX3 and had to go through a process of elimination to figure out the issue. Those were the things I stumbled across and figured since all these cars are similiar in design, then the fixes to anyone that may have the issue of this tread should be similar across the cars.
Texas 5
Old 03-03-2011, 03:46 PM   #11961
rcrevolution's Avatar
Send a message via AIM to rcrevolution
wow the r40 is still kicking after all these years! I think its it the oldest pro quality kit that has had 0 revisions.
rcrevolution is offline   Reply With Quote
Old 03-06-2011, 07:23 PM   #11962
S710_Nut's Avatar
No wouldn't that award go to the Nitro TC3 for AE?
S710_Nut is offline   Reply With Quote
Old 03-06-2011, 07:36 PM   #11963
well one, the HARA edition....
Here is my R40 with japanese HPI upgrades..
fastharry R40
Old 03-22-2011, 03:32 AM   #11964
stefanos's Avatar
edit :
yea the thing is the bell of the engine have lot of sluck i think ...(moving lot) but still it would destroy both gears insted of only one ,right?
HPI R40 2003 with Rx12 HPI engine and exust
Hpi R40 Hara edition with STS E12exr and Skyline Exust
Futaba 2PL
stefanos is offline   Reply With Quote
Old 06-08-2011, 05:31 AM   #11965
Trader Rating: 28 (100%+)
Hi guys,
I'm new to nitro and have just purchased a new built R40 for a bargain price. I know the car is old, but seemingly parts are stll available and I imagine it's reasonably competetive with the current crop of cars.
Could someone suggest what spares would be best to stock up on? .I'd rather stockpile them now whilst still available. I plan to race, but only occasionally (say every 1 to 2 months). Would you say the car is reasonable durable and reliable?
Thanks in advance.
Steve
stephenianjames is offline   Reply With Quote
Old 06-08-2011, 07:05 AM   #11966
Smile
Originally Posted by stephenianjames View Post
Hi guys,
Thanks in advance.
Steve
The rear belt worn out pretty fast. I used to have couple of that in my tool box.
wangcc61 is offline   Reply With Quote
Old 06-11-2011, 04:14 PM   #11967
Thanks mate. Any other parts I should get in particular?
Is the car pretty tough overall, or should I stock up on plenty of arms etc?
Cheers,
Steve
Old 06-28-2011, 09:14 PM   #11968
SpeedTeamLosi's Avatar
I have just completed new built kit Hara R40 ....
Got one problem ! what receiver battery fits in that little space..
any suggestions as to what brand ! thanx David
SpeedTeamLosi is offline   Reply With Quote
Old 06-29-2011, 06:49 AM   #11969
hey....
you need a small triple a type receiver pack...Trinity used to make them as well as others....
here is a pic of my Hara with that battery installed..
http://fastharry.com/wp-content/uplo...8/IMG_1373.JPG
but I looked online and it looks like the mainstream RC guys aren't making them anymore...which means you might have to do a little searching for a small li po receiver pack...
UPDATE!! Problem solved, LOL...
http://www.amazon.com/Cell-800mAh-Ni.../dp/B0006O7M1U
the product dimensions say 4 inches, but that has to be wrong...if its a triple aaa pack it is way smaller and the same as my car..You might want to write ofna and ask them for the dimensions..the battery is also on their site...but no dimensions
BTW, I think I have a set an extra set of yellow seal Boca ceramic bearings for the r40...and a few other way out of production japan only options.....if interested, let me know...
Old 06-29-2011, 10:12 AM   #11970
Thanks alot Fastharry! ..could you give me the measurements on that battery you have installed on your car .. goin to have a custom battery made for it ... .. as for the japan parts i have all of them installed on my car ... the kit i bought on ebay was new needed to be put together and had everything from japan and u.s production model with a sirio .12 , and novarossi NSRS3S .12 all new in the packages and boxes .6 set of extra belts etc.. 365.00 THANK GOODNESS FOR EBAY !!!! HE sent me A copy of the receipt for the all the stiff he had bought for the car .. it totaled over 1100 thats kit , parts, motors, ...i was so stoked to get it ....gonna post pics soon! .... what milliamp is that battery you have in your r40 pictured..
thanx David
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
