Old 12-12-2003, 10:59 PM   #1156
treky11's Avatar
no, the car should roll no problem.
treky11 is offline   Reply With Quote
Old 12-13-2003, 01:37 AM   #1157
The Sleeper's Avatar
Originally posted by Gped0124
Is it normal, for when the diffs are new. To be really draggy? It takes some effort to get them spinning, like, if I don't apply pressure to the chassis, the tires will just slide across my garage. Does this go away as the diffs wear?
Like it has been said already, no your problem is not normal.
First thing I would check is the brakes. Make sure they are free. Next I would check the tires. See if the inside rim is rubbing on the uprights.
If you still have the problem then start removing belts. Your problem should be easy to find with a simple process of elimination.
The Sleeper is offline   Reply With Quote
Old 12-13-2003, 07:57 AM   #1158
Regional Moderator
Darkseid's Avatar
They've covered most of it......but I would aslo check to make sure that the special cam style diff mounts for the rear, are both in the same hole. This could cause some drag if they aren't.
First, I would check out the brakes though. Make sure they are free, and that neithe pad has seperated from the calipers or anything. When your done, and everything is right, your car should roll easily along. The drive train on this car is VERY free right out of the box.
TLR 22...Tamiya F104...
Old 12-13-2003, 12:41 PM   #1159
rodrigo1508's Avatar
Hi well I have just had a death match with my clutch bell and pinions and firtunatly or unfortunatly I won but now my clutch is dead. I have seen before that you say that a mugen centax would fit so my question is wich and also if there is another centax that fits the r40
rodrigo1508 is offline   Reply With Quote
Old 12-13-2003, 12:43 PM   #1160
Regional Moderator
Darkseid's Avatar
What happened to your clutch bell and pinions?
Old 12-13-2003, 12:47 PM   #1161
well I was changing them for the green ones and well they got a little upset sor they hold on to the clutch bell Until I thought to my self they wont win son in a moment of madness and thirst for metal got my dremel out and slay them among witha little pice of the bell. now I am more relax but now I cant run my car
Old 12-13-2003, 01:07 PM   #1162
could I use a 1rst gear of16T-48T and a 2nd gear of 21T-43T?
Old 12-13-2003, 05:06 PM   #1163
icon's Avatar
Send a message via AIM to icon
LMAO. god forbid you ever need to change the flywheel and the crankshaft gets sentimental and refused to let the flywheel go ...
icon is offline   Reply With Quote
Old 12-13-2003, 11:47 PM   #1164
Send a message via AIM to Gped0124 Send a message via Yahoo to Gped0124
I found my diff problem. I had been tinkering around and isolated the problem, it was the diff itself. I had screwed in one of the 4 screws just a bit to much, causing the whole thing to bend and get crooked. Doh, now I have to wait for new parts...
Gped0124 is offline   Reply With Quote
Old 12-14-2003, 01:15 AM   #1165
Talking
LOL man Its only that I have been reading voltaire and I got a little inspired
Old 12-15-2003, 09:28 AM   #1166
Regional Moderator
Darkseid's Avatar
Man, it was so tough screwing in those diff case screws with a No. 0 screw driver, that once they stopped, I was happy to be done. I wasn't about to screw them in any further than they wanted to go! I was quite happy to stop twisting!
Old 12-15-2003, 12:33 PM   #1167
Regional Moderator
Darkseid's Avatar
For anyone who didn't know, TowerHobbies now has the super chassis IN STOCK but in limited quantities.
Old 12-15-2003, 01:08 PM   #1168
microRCshop's Avatar
hi guys,
just wanna pass along a news, that we have kawahara r40 parts in stock
vince
microRCshop is offline   Reply With Quote
Old 12-16-2003, 05:11 AM   #1169
tranced's Avatar
Here are two pics of the things that came in for me!
tranced is offline   Reply With Quote
Old 12-16-2003, 05:11 PM   #1170
icon's Avatar
this may be a dumb question, but what is the equivalent of #1 and #2 phillips screwdriver in metric? i want some hudy tools for x mas and dont know what size to buy for my r/c cars .
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
