HPI R40 Nitro Car Forum >
Old 10-01-2007, 01:43 PM
  #11671
bxpitbull's Avatar
Speaking of belts, one of my belts feels a bit loose. The one that runs the length of the car. Belt tensioner is at the bottom of the brace, but the belt feels a little on the flimsy side. It hasnt skipped that I can tell, but how can I be sure if its as tight as it should be?
bxpitbull is offline
Old 10-01-2007, 05:35 PM
  #11672
CraigM's Avatar
Trader Rating: 34 (100%+)
they stretch, so it sounds like it's time to replace it if the tensioner is all the way down, so long as the belt isn't over tightened. If this is the case the car wont roll very freely, so just check that. Otherwise there is just enough slack if you cant remove the belt from the pulley without taking it off the tensioner first, and the car rolls freely if pushed along the ground
CraigM is offline
Old 10-02-2007, 09:01 AM
  #11673
bxpitbull's Avatar
I'll do that. I can remove the belt with the tensioner on, but it does require a little bit of effort. I guess it struck me as odd to see that much slack and feeling it by hand, expecting it to skip.
Old 10-03-2007, 02:42 AM
  #11674
bxpitbull's Avatar
Is there something to the OS .12 TZ (5 port) and the R40's clutch kit? I had the same clutch kit on my JL red dot, no problems. I installed the clutch set the same way and there were a few issues. Everything went on and when I hand roll the flywheel, it loosens the clutchnut. I used blue threadlock, let it set for hours and when I hand test the compression, loosens again! I dare not install the motor into the car because if it (the clutch nut) loosens by hand, the starterbox will loosen it with ease...HELP!
Old 10-03-2007, 06:01 AM
  #11675
CraigM's Avatar
Which collar did you use? with the HPI one my flywheel didnt pinch, so I had to use the one that came with the TZ. You need to use a cross wrench to tighten the nut too - i had to drill mine out to fit. If the engine is new make sure you heat it up before trying to start it. The TZ's pinch so tightly at the top when that your flywheel will loosen the nut regardless if they aren't heated up - mine came loose 3-4 times when i broke in my TZ
no such issue with the CRF and its straight, silky cylinder
CraigM is offline
Old 10-03-2007, 07:23 AM
  #11676
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
if anyone wants that r40 hara....
its 225 plus shipping through the weekend.....
here's the pics..
http://www.rctech.net/forum/showthread.php?t=167565
fastharry™ is offline
Old 10-03-2007, 07:50 AM
  #11677
bxpitbull's Avatar
I figured from your avatar you'd be the one to answer. I have to buy a cross-wrench because all of the others I have wont make it over the shaft. Using need nose to tighten is a pain. I thought it was tight and then bang, loosen loosen. Thanks man.
Old 10-10-2007, 08:48 PM
  #11678
Default wheels
I've seen a few pictures of an R40 with rubbber mounted chrome wheels. It looked like it had 26mm in front and 30mm in the rear. My question is, where can I purchase 30mm wheels with rubber tires?
brownlo75 is offline
Old 10-11-2007, 12:11 AM
  #11679
Rapid Roy's Avatar
HPI has them
You can see them on their web site
Okay, I can't seem to post pictures. Here's the link.
Rapid Roy is offline
Old 10-11-2007, 12:21 AM
  #11680
Rapid Roy's Avatar
Originally Posted by Rapid Roy View Post
HPI has them
http://www.hpiracing.com/graphics/pa.../34104_01t.jpg
http://www.hpiracing.com/graphics/pa...7/3815_04t.jpg
Old 10-21-2007, 08:00 PM
  #11681
Default help on my r40 please..
hi guys, i would like to ask something about the r40..i just bought one and its my first time on nitro cars.first of,am i able to put a hara edition on my r40 without modifiyind the car?does the hara trany include everything needed for the convertion?and what's the largest engine i can put on th r40 w/o cutting the car up?thanks in advance guys.
gwapogi is offline
Old 10-21-2007, 10:18 PM
  #11682
keavze's Avatar
the largest engine that u could fit is a small block .18...
but why would u want to fit a larger engine than .12?
keavze is offline
Old 10-22-2007, 12:21 AM
  #11683
Rapid Roy's Avatar
Check with the local tracks you plan to run at. They might have motor restrictions. If you are just bashing, go for the OS .18 TZ and let her rip.
Old 10-22-2007, 05:31 AM
  #11684
fastharry™'s Avatar
yes, the hara .08 module 2 speed will fit your car......
and if I remember correctly, adding that not only made a difference, it made more difference as far as smoothness and punch than any hop up I added.......
Old 10-22-2007, 06:37 PM
  #11685
Smile thanks a lot guys!!
thanks keavze, rapid roy, and fast harry..yeah im just planning to bash around..hehehe.so the hara tranny really does make a lot of diffrence huh..ive also read that putting in a larger engine does not guaranty performance bump.so what would be the best engine to put.novarossi is off my budget since its very expensive.an os .12 speed tuned or a .18?which is the better of the two?again thanks in advance guys for the help..you guys are really helping me a lot here..ehehehhee.
gwapogi is offline
