Old 09-17-2007, 07:23 AM   #11656
Hi guys,need your expert opinion.I just got r40, the thing is that the car would spin or turn right or left when i hard brake. is this normal?was told by the shop owner that its normal for this car.is it true or some adjustment needed. thanks
ice98 is offline   Reply With Quote
Old 09-17-2007, 07:56 AM   #11657
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
are you running a one way?...if so, its normal......
if not, the car is tweaked, its got a bad bearing, one of the cvd's is broken, one wheel hex is stripped,.....any of the above.....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-17-2007, 08:26 AM   #11658
sorry ,what is meant by running one way? will check the condition of the items mentioned. thanks
Old 09-17-2007, 12:21 PM   #11659
fastharry™'s Avatar
what type of diff is in the front?...
Old 09-17-2007, 02:00 PM   #11660
ICE98 if the front diff looks like this then it is a one way that will cause you to spin out of control when hard braking. Soften the brake a little.
Also, check to make sure your pullies in the front are intact, and that your ride height is not too high or else the car will handle poorly.
SasonRC is offline   Reply With Quote
Old 09-17-2007, 03:28 PM   #11661
thanks guys for the tips and advise.will try to set up on the track.i'm so used to my old tamiya car handling need to adapt to hpi now.
Old 09-17-2007, 06:41 PM   #11662
Rapid Roy's Avatar
So do you have a oneway front diff? Which version of the R40 did you get? Also give us information on how you are setting up your car. That way we can help better.
Welcome to the world of R40
Rapid Roy is offline   Reply With Quote
Old 09-18-2007, 03:31 AM   #11663
hooked_on's Avatar
BTW, do you know why I said to put 4 reg phillips heads in the back of the chass, instead of the Ti screws?...
No sorry...maybe as chassis drags in the rear?
hooked_on is offline   Reply With Quote
Old 09-18-2007, 08:08 AM   #11664
yes i have one way front diff. So dismantle it? don't know which version ,should be 2003 definately not hara edition.is there anything else I should take note of?
Old 09-18-2007, 08:14 AM   #11665
fastharry™'s Avatar
exactly....and you wont be able to get the allan wrench in there in about 2 races....
Old 09-18-2007, 08:16 AM   #11666
fastharry™'s Avatar
you have an asian edition kit...they came with the one way...
I would try a front diff, or a solid axle....they will both give you front end braking, and will stabilize the car under braking...
Old 09-29-2007, 03:22 PM   #11667
do you guys use original hpi belt or aftermarket belting from hardware belt shop cause mine easily shows sign of tear after 1 track practice maybe cause the track not maintained from fallen dead leaves.
Old 09-29-2007, 05:04 PM   #11668
fastharry™'s Avatar
you answered your own question....I've raced my car for 4 years.....haven't replaced 5 belts......any of these pro style cars are designed for maintained tracks...
Old 10-01-2007, 01:02 AM   #11669
Rapid Roy's Avatar
I haven't had any belt problems either. Make sure your gears are cleaned out throughly. I use a sharp metal probe to clean everything out in the low spots. The crud that gets in there is just as black as the gear.
Old 10-01-2007, 03:30 AM   #11670
CraigM's Avatar
Trader Rating: 34 (100%+)
I broke a front belt, i think a rock got in there, and i stripped a rear belt which wore the pulley down. Otherwise I had no belt woes either
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
