Old 07-10-2007, 03:49 PM   #11581
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
hey guys...not sure if this has been asked before (sorry if it has), but...
has anyone tried using the "HPI Rear Solid Axel" in the front of their cars?? I'm debating about trying a solid spool in the front and was looking for alternatives to a one way...I'm thinking the new track by me can "handle" a oneway, but if not, a spool would/could work
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-10-2007, 04:28 PM   #11582
Rapid Roy's Avatar
Yes the plug works in the front diff. You just need to adjust your suspension for a bit more turn in
Rapid Roy is offline   Reply With Quote
Old 07-11-2007, 11:42 AM   #11583
Joe Tanto's Avatar
Default gearing
Hi just bought an R40 and I am using an STS D3R engine on it. The car is still with its stock gearing and it's not the Hara edition.
The track i am racing on, it has a short straight with technical corners. It is not a flowing track.
What I am seeing is that the car is suffering from acceleration and it picks late, I think i am geared high. What gearing do you suggest please? In all the car is handling excilent. Engine and clutch are tuned well.
Joe F
Joe Tanto is offline   Reply With Quote
Old 07-11-2007, 12:02 PM   #11584
Rapid Roy's Avatar
try dropping a tooth on both pinions unless you are topping out on the back straight. If you are, go lower on only the 1st gear pinion. You can also try leaning out your low end needle and richening up the high just a bit.
Old 07-17-2007, 09:19 PM   #11585
CraigM's Avatar
Trader Rating: 34 (100%+)
Joe F
It's probably more the tune than your gearing, even with stock gearing you should have enough snap to light up all 4 wheels out of a corner. Are you using the stock clutch? If you're running on that track all the time you should consider a pipe tuned for more torque down low. I've never used that engine so can't really recommend one sorry
In other news, I recently tried the kyosho clutch trick on my r40 and it worked a treat. They shim the clutch bell .4mm out from the shoe and then run with very little endplay (.1mm). My clutch take up is progressive but strong and works a treat on all the tracks I race on
Has anyone used sealed bearings in their r40s? I picked up a set but they seem to drag a lot more than the standard bearings so I think I'll just use them for the thinner bearings on the diff outdrives and uprights
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-17-2007, 10:46 PM   #11586
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
and which Kyosho clutch trick would that be?....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-18-2007, 01:00 AM   #11587
CraigM's Avatar
the one i explained? you shim the whole clutch bell out from the shoe/flywheel assembly, so you place shims on the crank before the large (b023) bearing. Mine took 0.2mm of shims before the shoe would spin freely with the car standing on its side (so gravity pulling the bell down), then I added a further 0.4mm. Following this i placed the bell on with the flange and thrust, and then added .1mm shims until the assembly no longer spun freely, then removed the last shim i put on to give an endplay of 0.1mm. This would trick would probably save you from cutting down the flywheel pins too, provided they didnt stick out by more than .4mm. Anyway my clutch is great now, I went back to the HPI spring and still using the mugen grey shoe
Old 07-18-2007, 07:32 AM   #11588
fastharry™'s Avatar
and where are you putting these shims?...
Old 07-18-2007, 05:11 PM   #11589
CraigM's Avatar
between the thrust and the collar thing, the normal way you shim endplay
this probably explains it better... I put the inner shims on the other side of the B023 bearing seeing as the r40 only has a 2 bearing clutch
Old 07-24-2007, 01:34 AM   #11590
coolson's Avatar
i have breaking a few bearing a few times. I think i will try to follow your instruction to place the shim.
Btw, how come you got two bearings closer to the flywheel in your diagram?
also, do you guys have problem with those 4 poles coming out from the flywheel? I do......
coolson is offline   Reply With Quote
Old 07-24-2007, 10:01 AM   #11591
edward Haywood's Avatar
Just a question 1. How is the durability of the R40 some say that it is fragile. 2. Also is this car still competitive with the 720,s ,mTX-4,NT1 Xray Now I know with Hara driving it probally is but I'am talking about the average driver thats staying off the walls and being somewhat consistent...any replys would help...... And I know that , I ask 2 questions
Mtx-4.....Rolling baby/Blue Diamond /West Chester/
Magneto X-Woodawson/FX/Nitro forever/
edward Haywood is offline   Reply With Quote
Old 07-24-2007, 02:52 PM   #11592
stefanos's Avatar
i cant say about the second part of your question....but as for fragile LOL i crush my hara maybe 5 times till now (2 of the super hard the car whent 4 meters of the air LOL)and still nothing is broken i mean realy i cant bealeve it :P
and even if something brakes its easy to fix ,most of the time with simble glue
HPI R40 2003 with Rx12 HPI engine and exust
Hpi R40 Hara edition with STS E12exr and Skyline Exust
Futaba 2PL
stefanos is offline   Reply With Quote
Old 07-24-2007, 02:59 PM   #11593
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
ok Q 1 In my Opinion the car is not fragile at all it can take a few hits before something fails. the one part I find to be the weakest link are the steering knuckles after a few hits they will crack and pop off the pivot balls while you can pop them back on they will pop off again with just about any hit to the front end. other wise the car is pretty solid. then again you hit anything hard enough it will break sooner or later
Q 2 as for being competative I still compete with mine and i'm nowhere near pro level just a few steps above rank amatuer and I can keep up with the mugens and the serpents and even the new xray nt1. granted a better driver could do much better with the R40 then me but every so often I get asked what car is that and I still get a kick out of the surprised reactions when I tell them it's a R40.
so far the only mods I 've done so far is the carbon fiber shock towers, CVD's up front, light weight 2 speed and hollow shafts, carbon fiber upper bumper plate and carbon fiber steering plate and an aluminum rear brace and brake arm, and it the original R40 not the hara edition still with the stock plastic shocks and black springs.
regg151 is offline   Reply With Quote
Old 07-25-2007, 12:28 AM   #11594
fastharry™'s Avatar
after those glowing reviews(and i love mine also),remember I have a brand new in box hara r40 I won at the HPI challenge in oct......FOR SALE
PM me..
Old 07-26-2007, 03:49 AM   #11595
stefanos's Avatar
lol still fastharry? :PP if you ship to greece i might ask a friend :P
Futaba 2PL
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
