Old 06-15-2007, 07:05 PM   #11566
Simon M's Avatar
Originally Posted by CraigM View Post
know anywhere i can order one?
Save your money and get a 720
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.serpentradiocontrolcars.com.au
www.smaracing.org
Simon M is offline   Reply With Quote
Old 06-15-2007, 07:53 PM   #11567
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
check the camber on the rear left tyre, my car did this after i stripped the ball cup and the camber rod fell out
http://shopping.rcmodel.hk/product_i...oducts_id=3619
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-15-2007, 08:16 PM   #11568
fastharry™'s Avatar
thanks for sharing........
Old 06-15-2007, 08:18 PM   #11569
fastharry™'s Avatar
So it goes less well on treated surfaces? I'm racing a mix of both at the moment but still finding my feet on the treated purpose built track. So far I'm as quick as my mates with MTX4s who have also just started racing there, but there's a decent gap between us and the top guys who are racing a mix of MTX4s and V1RRR's.
Have you got a setup sheet harry? I recently tried my mates Associated NTC3 and was shocked at how much more nimble it is than my r40, especially it's turn in. My car tends to push into the corner then oversteers on the way out, it's still quick but if it turned like my mates car it'd be muuuch faster
I'll work on the sheet.....
Old 06-17-2007, 03:40 AM   #11570
CraigM's Avatar
Trader Rating: 34 (100%+)
maybe after you beat me
Awesome on both counts man
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-17-2007, 04:53 AM   #11571
fastharry™'s Avatar
I know..
listen,as long as you are ordering,see if you can pick up the 3 racing brake lever arm.....it uses a small 2-56 ball end(i think asociated and HPI have them.......a good hobby shop should also,.,,),,,,by putting a ball end there instead of that wire slip through plastic BS,it REALLY firms up the braking.....very precise.....also,see if they have the optional SS brake disc
Old 06-17-2007, 05:32 AM   #11572
CraigM's Avatar
Originally Posted by fastharry View Post
I know..
oh good call, my breaks are a bit inconsistent at the moment so I'll give them a go... I'm pretty sure rcmart have those parts if rcmodel don't
Old 06-17-2007, 01:26 PM   #11573
stefanos's Avatar
lol fastharry :PP A.I. is the A.I. of the forums here :PP and he almost had it at 90% the car even teh servos was on when he send it to me.
so to answer to other questions no i dont use same things radio,servos etc.
i just tryed again today and notice that teh real problem is on my 2003 car, the hara you can slightly notice that it oversteer more from one side than the other.
anyway screw this my 2003 is not even a back up i have to test things on this :PP
thxn for your replys anyway guys
can some one tell that this are real carbon grifite and they are not the normals we have?and if they are from CG why they are so cheap ?
http://shopping.rcmodel.hk/product_i...84d4266a428a08
HPI R40 2003 with Rx12 HPI engine and exust
Hpi R40 Hara edition with STS E12exr and Skyline Exust
Futaba 2PL
stefanos is offline   Reply With Quote
Old 06-17-2007, 07:45 PM   #11574
bucknuts's Avatar
I put my R40 down at Toledo this weekend for the heck of it, and it was running really well. I had made some pretty aggressive changes to the setup and like everyone is saying here it is still plenty capable.
bucknuts is offline   Reply With Quote
Old 06-17-2007, 08:35 PM   #11575
fastharry™'s Avatar
I know the car is capable.....but its got that HPI name......I've had a brand new hara,NIB for sale for 300....can't get a bite.....thats below dealer cost...
shame....
Old 06-17-2007, 10:34 PM   #11576
CraigM's Avatar
when you fit the mtx3 clutch do you use the mugen clutch bell/gears or the hpi ones? I take it since everyone is fitting the mtx3 clutch the mtx4 doesnt fit?
Old 06-18-2007, 06:31 PM   #11577
CraigM's Avatar
also, are they the mugen light blue springs on surikarns car?
Old 06-18-2007, 10:08 PM   #11578
CraigM's Avatar
if anyone else is looking for setups i'll save you some time, just scoured the thread and found these ones (is it just me or has thread seach dissappeared?)
Harry
I build all my cars the same way.....50 st oil,#3 pistons,ride height of 6 mm rear,5.5 mm front with 61 mm tires in back,59 in front,black springs all the way around,3 degree toe in back,1 degree toe out in front,middle caster,1 d camber in front,2 in back...I run the 4gear diff in back with 30,000 weight,and a one way in front....If I run a diff in front,I'll start with 50,000....and no spacers under the uprights.......and here's the key...I always run 1 shore SOFTER tire in front.......
AI
Also I ran 50wt with black springs in the rear , silver in the front , spool in front , 10k 4 gear diff in the rear , 5mm front , 5.5mm rear , then I tweaked it on some scale (made left and right even in weight distribution) installed a mugen clutch , w yellow pad , 40 shore front , 37 shore rear twister tires and the car was on rails.
RapidRoy
In general, I found I need more rear grip, so I use either black or silver springs in the rear with the black fronts, 50 Wt shock oil with stock pistons all around. 5mm/ 5.5mm f/r ride height (ya my chassis is really scraped up) 1.5/2 deg camber f/r, 0/3 toe f/r. I use the 4 gear rear diff and a 2 gear front dif with 30000 rear and 100000 front. Both diffs 3/4 full.
and for reference, CraigM
60Wt front, 50Wt rear, stock pistons, black springs all round, same shore tyres (37 for parking lot, 40 for permanent), 2 gear front diff with 50000 wt oil, 4 gear rear with 30000 wt oil, 5-6mm ride height, 1 deg toe out front, 3 deg toe in rear, 1/2 f/r camber, and a wider than stock front track by about 2mm. I cant remember the droop settings My car understeers a bit so i'm going down to 50wt front oil and will try silver front springs if i need more steering after that.
<end triple post>
Old 06-18-2007, 10:42 PM   #11579
fastharry™'s Avatar
Harry
AI
RapidRoy
<end triple post>
thread search is at the top right,by user control panel
Old 06-19-2007, 12:50 AM   #11580
CraigM's Avatar
unless there is some serious user error going on over here that's forum search, you used to be able to search just within this (or any other) thread
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
