Old 12-09-2003, 04:56 PM   #1126
Trader Rating: 16 (100%+)
Yeah, those familiar with the Proceed can remember how that was rolled out.. Then they created updates, and now there is lots of info.. I think the R40 is the Proceeds little bro. LOL!
I actually posted a pretty detailed question to both the US and Europe HPI forums with no response as of yet, that was about a week ago I believe.. No hurry really, I am sure there aren't many R40's getting track time with the cold/wet weather. But I sure hope to have a pretty good handle on this car before I hit the track, so I can find a setup that works without too much trial and error.
NitroLeadFinger is offline   Reply With Quote
Old 12-09-2003, 05:31 PM   #1127
Send a message via AIM to Gped0124 Send a message via Yahoo to Gped0124
For the 2 speed clutch, what should the spacing be between the shoes? I couldn't see to get a even gap throughout the whole shoe.
Gped0124 is offline   Reply With Quote
Old 12-09-2003, 05:33 PM   #1128
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the gap should be adjusted before you assemble the 2 sp..
fastharry™ is offline   Reply With Quote
Old 12-09-2003, 05:35 PM   #1129
I know, I am adjusting it right now, I havn't built the 2 speed yet.
Old 12-09-2003, 05:41 PM   #1130
fastharry™'s Avatar
OK..so when you are screwing the 2 allens in(and its best to pre thread those holes with teh allens BEFORE you assemble the shoes onto 87085 holder)...screw them in so the shoes just start to come apart and leave a small gap..VERY small..
Old 12-09-2003, 06:10 PM   #1131
Regional Moderator
Darkseid's Avatar
Another thing to notice with the 2-speed is that the aluminum 'bell' (87081) that the 2-speed shoes will spin in, may have some flashings left on it that will cause the shoes to drag once the 2-speed is assembled. The access hole(for adjusting the 2-speed) may also have a flashing or two left on it. I had this on both my ReflexNT and on my R40. Just run your finger around the inside of the 'bell' to make sure that everything is smooth. If not, a nice sharp X-acto blade is perfect for removing the flashings.
TLR 22...Tamiya F104...
Old 12-09-2003, 06:13 PM   #1132
Regional Moderator
Darkseid's Avatar
Well I'm glad you guys mentioned the thrust bearing thing. I may have hated the suppliments that Trinity stuck all over the ReflexNT manual, but I would rather they be there as suppliments rather than be totally omited.
Old 12-09-2003, 08:31 PM   #1133
rodrigo1508's Avatar
I am also glad about what you said of that thrust bearing I would never have thought of lubing it(Its my first "pro" kit). If I use some speed bearing lube is that ok?( I used that for the bearings of my skates)
rodrigo1508 is offline   Reply With Quote
Old 12-09-2003, 09:33 PM   #1134
Rapid Roy's Avatar
That lube might be too thin. Black grease would stay on the bearing better.
Rapid Roy is offline   Reply With Quote
Old 12-09-2003, 10:31 PM   #1135
Regional Moderator
Darkseid's Avatar
NO, I don't think that will be good enough. See, the thing is, the grease is not only there to provide lubrication. The thrust bearing rotates at very, VERY high speeds. Anything moving that fast not only needs lubrication, but.........you guessed it......cooling. The lube helps to keep the temperature down as well as providing lubrication.
That is of course if the thrust bearing in the endbell works anything like the thrust bearing in the typical ball diff.
Just for the sake of safety, I would say pick up a pack of Associated black grease to lube it with. Or ask around, most of the people who have ever run Associated or Yokomo kits have about a dozen of the packs just laying around!
Old 12-09-2003, 10:46 PM   #1136
FREAKAH's Avatar
Paris "Ronnie" grease works really well for thrust bearings and such. It's sticky and stays put and doesn't burn off easily.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 12-10-2003, 09:58 AM   #1137
Rapid Roy's Avatar
The rotating speed of the thrust bearing is not that fast. It's only spinning until the clutch shoes engage the clutch bell. At that point the clutch bell, shoes, pinion gears and drive shaft spin as one unit.
Old 12-10-2003, 11:14 AM   #1138
Regional Moderator
Darkseid's Avatar
Thanks for clearing that up.
So it appears the thrust bearing in the clutch bell doesn't require the same pertection that the thrust bearing in the diff does.
I still plan on using the AE black grease, but I wont pack it in like I do with my diffs.
Old 12-10-2003, 05:32 PM   #1139
InitialD's Avatar
The thrust bearing should not and will not spin and rotate as fast as the engine RPM when the clutch shoes engage the clutchbell when the thrust bearing is set correct which is to put the thrust bearing washer with the larger inner diameter first into the engine.
If the smaller inner diameter of the thrust bearing washer is wrongly put in first into the engine, the thrust bearing will rotate at the same speed as the clutch permits the clutchbell to rotate and this burns out the thrust bearing fast.
Old 12-10-2003, 05:49 PM   #1140
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I'm getting my R40 tomorrow, anything I need to know to assemble it correctly? Like any extra tips, or something?
Nrctc3 is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
