Old 04-07-2007, 10:47 PM   #11356
Talking
Originally Posted by fastharry
kamikaze has them but they are out of stock
PRO HOBBY has them cheaper....and they are in stock..
http://cgi.ebay.com/Skyline-VR12-Plu...QQcmdZViewItem
ill order this on wednesday , im still broke .
tower screwed my order sent 40 shock oil instead of my 2 speed screws
2.5x 12mm . any one need a new 40 shock oil pm me ,ill send it for free.
LORD SHADO is offline   Reply With Quote
Old 04-07-2007, 10:48 PM   #11357
Default fasst
does the fasst reciever work with non digital servo . the instruction does not say this. also what the best body for the r40.
Old 04-08-2007, 11:52 PM   #11358
Default tires
Twister Racing Foam Tires
http://cgi.ebay.com/ws/eBayISAPI.dll...link:middle:us
who has good tires?
Old 04-09-2007, 12:21 AM   #11359
Rapid Roy's Avatar
who has good tires?
Those are really good tires. BTW, Pro-Hobby is AI's ebay store so you can get both your tires and pipe from him.
Rapid Roy is offline   Reply With Quote
Old 04-09-2007, 09:12 AM   #11360
thanks / ill order some any idea what number to get for asphalt running.
Old 04-09-2007, 09:23 AM   #11361
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
40 should be a good start , but look at it how much you want to grip with how much you want the tire to last a parkinglot is low traction so a 35 would suite best but wear and tear can cause them to chunk easier the lower you go , 40 should put up to the asphalt more , while giving at least enough grip. Surely more than rubber tires if you tried that.
Some parkinglots are smooth enough , normally a freshly coated black one. But either way bashing normally puts 30 minutes on a car in no time so the higher the shore the longer you can play for cheap.
So its really up to you. Another note is fronts should be slightly higher in shore. Reasons is the rear tires provide most of the forward traction while front tires provide turning and a tighter provides more side bite, so it should turn better. People play around with the balance for many reasons. Some run harder in the rear to make rear wheel tire stay the same diameter as the front.
The rears like to wear faster than the front , if you let that get out of range too far the rear will spin of more and more and soon your car wont drive worth a bit as it keeps overdriving the car , thus making it spin the rears faster than relative to the front which is obvious itll put it into a spin upon power.
Artificial-I is offline   Reply With Quote
Old 04-09-2007, 09:28 AM   #11362
Moderator
BTW this week a new pro-hobby store is opening. Its going to rock , also have better prices than ebay.
Old 04-09-2007, 01:12 PM   #11363
is this you store /you seem to know your stuuf oh great intellegents.
Old 04-09-2007, 05:29 PM   #11364
CraigM's Avatar
Trader Rating: 34 (100%+)
Will there be international shipping?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-09-2007, 10:22 PM   #11365
Rapid Roy's Avatar
Okay guys! I've been picking up the bits and peices to convert my car to '05 Hara specs and I have everything except the aluminum servo mounts. Will the stock servo mounts for the original R40 work? The aluminum ones are very slim, maybe I need to dremel down the stock one to make it work.
Old 04-09-2007, 10:42 PM   #11366
CraigM's Avatar
Could be difficult, but not impossible. The standard r40's forward mount has a post where the screwhole would be on the hara mount, so there will be a few mm offset from the deck hole compared to the hara mounts. You will also run into trouble with the rearward mount because the standard car uses the throttle servo's bracket as a spacer for the rear mount, so if you use the same mount on the hara top deck you'll need to find a spacer to put under it or your servo wont be level.
Old 04-10-2007, 12:11 AM   #11367
Rapid Roy's Avatar
Looking at the pictures, I think you are right. I'll just wait untill my stuff arrives and take a look. I'm thinking that the servo mounts from my racer 2 look just like the hara ones.
Old 04-10-2007, 05:31 AM   #11368
Talking pipe
hay guys i have the .18 os motor is this the best pipe for me
.12 VR12 Plus One Piece Outlaw On Road Pipe
Old 04-10-2007, 05:58 AM   #11369
CraigM's Avatar
Yeah the Hara's look really standard, I'm pretty sure you could harvest just about any kit you have lying around
Old 04-10-2007, 06:47 AM   #11370
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the racer v2 mounts are too short,and only secure the servo with one screw per side..the hara mounts drop the servo 1/4 inch below the top deck with 2 screws per side....
http://www.hpiracing.com/graphics/instr/nr2/nr2_18.jpg
http://www.hpiracing.com/products/en/75067.html
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
