Old 03-19-2007, 07:12 PM   #11236
astra power's Avatar
Originally Posted by fastharry
yes......I usually change tires,caster,and rear toe b4 I do anything else....
yep i tried tyres first, then played with caster which made things worse, but have yet to touch the rear toe. I really think the shocks arent suited to the track, just from seeing the way my car handles compared to the other guys out there
Originally Posted by Rapid Roy
I found I need more rear grip, so I use either black or silver springs in the rear with the black fronts, 50 Wt shock oil with stock pistons all around. 5mm/ 5.5mm f/r ride height (ya my chassis is really scraped up) 1.5/2 deg camber f/r, 0/3 toe f/r. I use the 4 gear rear diff and a 2 gear front dif with 30000 rear and 100000 front. Both diffs 3/4 full.
Oh, I run at a medum to low grip parking lot track thats fairly technical with 140' straight.
Thanks Roy, it sounds like our tracks are pretty similar but mine sounds a bit grippier and with less straight. What tyres are you using? I find that the only corner my car likes is the left hand sweeper at the end of the straight which is high speed on trailing throttle, it then understeers into a left hairpin before drifting out of a right 90 degree corner. The rest of the lap is all understeer, 2 hairpins and a sweeper back onto the straight. I'm at full lock through the sweeper and the understeer compromises my speed onto the straight
astra power is offline   Reply With Quote
Old 03-19-2007, 08:01 PM   #11237
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I actually read an interesting article a few years back...it said,to get more steering,turn down the dual rate a touch....when you have the tires turned lock to lock,they will actually scrub in the corners without getting traction....no traction,no steering...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-19-2007, 10:31 PM   #11238
Rapid Roy's Avatar
Good point. I was taught to have only enough steering to get around the tightest corner of the track.
astra,
I use 37 shore all round. I'll use 35's if I can get them. My LHS stocks mostly 40's and 42's for the permanent track. Not much nitro action at the parking lot races in the area, but I like the people there.
Have you tried running 1 degree toe out in the front? You can also disconnect you front sway bar. I don't run one.
Okay, after re reading your last post, it sounds like you need more on power steering. I have a great chart that I'll upload that will help. I just need to get to the office cause its not on my home computer.
Rapid Roy is offline   Reply With Quote
Old 03-20-2007, 03:55 PM   #11239
Thanks Roy, that chart would be great. I'll give the sway bar trick a go too
Old 03-20-2007, 04:41 PM   #11240
fastharry™'s Avatar
read it...learn it......know it
http://www2.towerhobbies.com/cgi-bin...&I=LXEGG9&P=ML
Old 03-20-2007, 04:42 PM   #11241
fastharry™'s Avatar
Old 03-20-2007, 07:57 PM   #11242
nitrodude's Avatar
Rapid Roy, does ultimate carry R40 parts? I was thinking of making a trip up there to stock up on parts, but its a long drive for me to come back empty handed. I mainly need spurs and pinions for the lightweight 2sp, I will be running mainly at SVM and need some taller gears.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-20-2007, 08:31 PM   #11243
stefanos's Avatar
fastharry i need to buy this? couse i dont see anything else on your link :P
HPI R40 2003 with Rx12 HPI engine and exust
Hpi R40 Hara edition with STS E12exr and Skyline Exust
Futaba 2PL
stefanos is offline   Reply With Quote
Old 03-21-2007, 05:56 AM   #11244
damn! how often do you guys throw belts? I thought my car got a little understeery towards the end of the final last weekend!
Old 03-21-2007, 06:39 AM   #11245
fastharry™'s Avatar
you don't need to buy anything.....Which kit do you have,again?..
Old 03-21-2007, 07:38 AM   #11246
stefanos's Avatar
its on my sing :P r40 2003 and r40 hara
Futaba 2PL
Old 03-21-2007, 08:13 AM   #11247
fastharry™'s Avatar
well then,the only steering option you need is the ball bearings that came with the HARA kit...the metal upgrade kit is nice,but you have to do some shimming....I like the brake arm because it puts a ball cup at the pivot point onthe linkage,rather than slipping the linkage into the brake arm hole...and that eliminates the slop...
Old 03-21-2007, 11:24 AM   #11248
Rapid Roy's Avatar
Here ya go. (shhhh, just don't tell the serpent guys)
Old 03-21-2007, 11:29 AM   #11249
Rapid Roy's Avatar
Give them a call first. Thats a long haul for you. Hopefully Moto won't pick up the phone 714 921-0424
You can also try Tony's hobbies in West Covina. They are my secret supply shop when I can't find the part anywhere else. 626 917-5290
Old 03-21-2007, 11:54 AM   #11250
stefanos's Avatar
thnx harry the only problem now is how to get the parts :P all the hooby shope here in greece are super expensive and ignorant ppl that dont care about the customer :P
Futaba 2PL
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
