Old 11-08-2006, 12:25 PM   #10951
srsly, I think my car is a lady.
The clutch/oneway or whatever problem it was....disappeared today.
( I did absolutely nothing! I swear)
I just wanted to move the car a little to double confirm the problem before trying out proE's method, but it ran sweet and nice.
3 tanks go by, everything was fine.
halfway on the 4th tank, the car juddered, followed by a grinding sound.
retrieved the car, 2nd gear was stripped half bald, 3 tooth missing on first gear
They were fine before this?!?!
I checked for clutch play before filling in the 3rd tank ( major stop ) and it was fine. I rechecked it after the incident, and it's totally crap.
not a big fan of voodoo, but can anyone suggest a remedy for this jinxed car?
so much problems, I dont even know where to start asking.
boggysv is offline   Reply With Quote
Old 11-08-2006, 12:40 PM   #10952
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Are you sure you are driving your car and not mine. Sounds very much like my car just after I bought it.
I also had problems with my clutch at first then the two speed, and guess what followed the two speed. Stripping second gear.
The first time I stripped second gear was when my gears didn't mesh up correctly.(to big a gap)
The second time it happened was when the engin moved.
The third time was because of a small rock that landed between the gears.
Then......only then did most of my problems end. I must admit that without all the help that I got from this forum, my car would be on a shelf in the garage.
Now I will not give this car up for any other car. I can keep up with most of the mugens and serpent on any day.
The nice thing about all the problems that your having now is that you are learning all the ins and outs of this car. When you start racing it, no problem will be to big to sort it out quickly.
ProE is offline   Reply With Quote
Old 11-09-2006, 03:34 PM   #10953
Default R40 suspension guide
Hello, I bought a HPI R40, but don't know how to adjust the front stabilizer and the rear sway bar?
Do you know some suspension guide?
Tks
papalegua is offline   Reply With Quote
Old 11-09-2006, 04:35 PM   #10954
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Papa:
Here you go , its on hpis website.
http://www.hpiracing.com/graphics/in...0/R40-P44o.jpg
http://www.hpiracing.com/graphics/in...0/R40-P27o.jpg
http://www.hpiracing.com/graphics/in...0/R40-P28o.jpg
As for the rear bar its as simple as buying the rear sway bar set.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFPZ9&P=7
Artificial-I is offline   Reply With Quote
Old 11-09-2006, 04:36 PM   #10955
Moderator
Also you can find the entire manual here.
http://www.hpiracing.com/instructions/instruct-r40.htm
For hara supplemental sheets , search up this thread...ill be posting the link soon on my site as well for safe keeping.
You can also find some info on the r40 stored at http://pro-hobby.net
Old 11-22-2006, 10:29 PM   #10956
Deeds's Avatar
Since the R40 is no longer sold...how long do you think HPI will provide parts for the Hara version?
I'm debating what to do. Keep it, or move on.
Thoughts?
Deeds is offline   Reply With Quote
Old 11-23-2006, 02:12 AM   #10957
Rapid Roy's Avatar
Thoughts?
Where did you get this information from? I still see the Hara version listed on HPI's site.
Rapid Roy is offline   Reply With Quote
Old 11-23-2006, 07:33 AM   #10958
Deeds's Avatar
No, I meant the standard R40 in not being sold any more. It's only a matter of time for the Hara version to be discontinued.
Old 11-23-2006, 09:31 AM   #10959
Deeds's Avatar
Are the HPI wheels prone to bending? I had a hard wreck during my last race. I thought the axle was bent, but after taking it apart it seemed fine?? The wheel wasn't cracked but wobbles now?
Do you guys run the HPI foams? If not, what is your preferred brand?
Old 11-23-2006, 10:23 AM   #10960
Trader Rating: 24 (100%+)
Talking
try power x tires you can get them from this guy tee. call him (954) 344-7895 tell him randy told you to call and he will give you a great deal on a set of 10pair under 100.00 shipped
RANDY SMOOTH is offline   Reply With Quote
Old 11-23-2006, 01:39 PM   #10961
Rapid Roy's Avatar
You don't need to worry about parts. You should be able to get parts for a couple of years after the kit is discontinued.
Old 11-23-2006, 03:57 PM   #10962
surreal's Avatar
Trader Rating: 39 (98%+)
Send a message via ICQ to surreal Send a message via AIM to surreal
I use to run HPI foams, but they seemed to chunk a lot. I switched to Jaco nitro shoes and they seem to be of better quality and are less prone to chunking.
I think any brand of tire can bend in a crash. The cheap way to fix the problem is to take the bend out with a heat gun and then balance the wheel. Obviously the easier way is just to replace it.
Take care.
surreal is offline   Reply With Quote
Old 11-23-2006, 05:28 PM   #10963
Moderator
As is with all kits. Im sure a new nitro on road car would be out before hpi discos the hara. At least I would hope.
Old 11-23-2006, 06:21 PM   #10964
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I enjoy the R40, but still going to try a new car next year. There are parts I would get IMO to get rid of all the wobble and beef it up a bit. If you are worried of less part support in the future then stock up now. There are still companies that make aftermarket parts for this car though bare in mind.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 11-24-2006, 07:56 AM   #10965
Deeds's Avatar
Two quick questions that were covered in this forum:
1. Which parts are needed to switch to the Mugen clutch. I'm glad to hear there is a solution to the R40 lazy clutch.
2. One track I run on is really small. I want to get rid of the front one way. I could get the spool. Is it better to put the spool in the front or rear?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
