Old 12-07-2003, 11:23 PM   #1081
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Anti squat
Anti squat ........should give you more steering late in the corner,
(it will square the corner off) then it will give the car more traction
on the exit of the corner.
If you add what they call kick up in the front (front of hinge pin higher then the rear) you increase your turn in.
0
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-07-2003, 11:45 PM   #1082
Trader Rating: 16 (100%+)
Maybe someone from HPI can chime in to clue us in on if HPI plans to produce an R40 tuning guide?
That sure would be handy..??
With wet weather it is hell to get any track time to reverse enginer the cool options..
NitroLeadFinger is offline   Reply With Quote
Old 12-08-2003, 01:11 AM   #1083
Sorry to bring up a negative tone once again... but I pose this more as a question than a gripe.....
The R40 designers love the "load bearing screw" design, i.e. a part is fastened together and any shear load is also placed on the screw. Take a look at the attached pic for example, the Serpent 710 bulkhead/centermount has a key around the screw hole that goes into the larger hole in the side brace. On the R40, the side brace is simply bolted on with no keys to align it or help bear load.
Aside from the side brace, the R40s top rear front hinge pin brace, shock towers, etc are also like that......
So my question is for those who've driven/crashed the car. Do you get any bent screws?
Nevertheless, the whole car is still very solid and at least HPI keyed the bulkheads to the bottom chassis
boom is offline   Reply With Quote
Old 12-08-2003, 02:33 AM   #1084
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default belt size
can anyone tell me what length rear belt is R40 (in mm please)
also how many tooth on the rear diff pulley
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 12-08-2003, 03:03 AM   #1085
InitialD's Avatar
Default Re: belt size
No idea on the belt size but the rear diff is 46T.
Old 12-08-2003, 05:47 AM   #1086
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
That si one good thing about the car..it is REAL sturdy...MY tc3's,one some board hits,would tweak so you'd have to trim the steering a couple of clicks(Futaba 3pk)....At the HPI worlds,I whacked the boards a few times,and the car never changed direction,and every night it would be in adjustment....the only problem is the rear upper ball cups..the upper rods will compress...but I fixed that problem the first week I had the car..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 12-08-2003, 08:01 AM   #1087
Chewdogg's Avatar
Length: 189mm (7.44")
Width: 5.5mm (0.236")
Teeth: 63
front and rear belt are same size
rear Diff: 46T
Chewdogg is offline   Reply With Quote
Old 12-08-2003, 09:35 AM   #1088
Regional Moderator
Darkseid's Avatar
I see a lot of people asking about a setup guide for the car. Is that because you struggled with finding a good setup for the car, or you simply want a setup guide that fully explains all the changes that can be made on the car?
TLR 22...Tamiya F104...
Old 12-08-2003, 09:40 AM   #1089
Regional Moderator
Darkseid's Avatar
How do the knuckles/rear hubs and pivot balls hold up on the car. I run a pretty consevative line with my nitro cars, and we use corner dots at our track, so breaking knuckles/rearhubs really isn't much of an issue. But just for the sake of knowledge, how prone are they to pull themselves off over the pivot ball? Also, how prone are the pivot balls to bending?
Old 12-08-2003, 10:01 AM   #1090
treky11's Avatar
i think people want a guide that details what handling changes can be made with all of the available tuning options. i know i don't have the time to experiment with them all.
the knuckles are fine. i wacked the boards good a few times. i popped one off once but never bent the pivot ball.
not a problem in my book, hit anything hard enough and it will bend or break. the car is plenty durable.
treky11 is offline   Reply With Quote
Old 12-08-2003, 10:24 AM   #1091
I have had this problem twice, but both times, it was because I hit the board the wrong way. (If there is a right way to hit a board). anyway, never had any problems with the pivot ball bending.
C0NTENDER is offline   Reply With Quote
Old 12-08-2003, 11:16 AM   #1092
treky11's Avatar
Wink
Hey it must be durable. Contender is a total hack! If he can't break it nobody can
Old 12-08-2003, 12:02 PM   #1093
HA HA HA
Old 12-08-2003, 02:11 PM   #1094
The Sleeper's Avatar
The car runs fine the way it is, stock.
I'm just curious as to what all those tuning options will do.
The Sleeper is offline   Reply With Quote
Old 12-08-2003, 03:12 PM   #1095
graphite towers are in stock at Tower, but in limited supply.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
