Old 09-18-2006, 01:17 AM   #10846
Rapid Roy's Avatar
Yes you will need to buy the 73478 part tree just for that part. If you are hitting stuff, you will eventually need the other parts on the tree. You will have the upper and lower front arms, the rear arm and the rear upright. Extra wheel hexes are always good to have around too. I know your kit comes with the alum. clamping hex's, but you never know what might happen at the races. All that for 7 or 8 bucks.
Rapid Roy is offline   Reply With Quote
Old 09-18-2006, 05:19 AM   #10847
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by boggysv
the noob strikes again!!
well, actually, I popped my steering knuckle last night, and I lost the part shown in the picture.
is it a generic part, or do I have to get the whole set of arms from HPI again?
2nd problem
initially on stock setup, my rears are wearing more on the inside, hence i decreased camber by 4 turns each side. (sorry, i don not have a camber gauge).
now it is wearing evenly, but the rear of the car seems to like to fling out after long sweeping turns. Any remedies?
car is a hara kit, with the AL mid brace, and mazda 6 body, 35F,35R.
Increase rear camber by 1/4 turn back.
The mazda 6 is somewhat a loose body. Try a parma m or stratus 3.1 that alone could cure the problem.
Artificial-I is offline   Reply With Quote
Old 09-18-2006, 05:21 AM   #10848
Moderator
Originally Posted by AMGRacer
I have a new in packet rear swaybar that I bought only a few months ago, so they are still in production. One of the best optional parts for the car, even though it is pricey.
Why is it one of the best?
Old 09-18-2006, 10:28 AM   #10849
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default car
just a ? where did the R40 go im not seeing them anymore i had 1 but they disapeared just curious no intent
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-18-2006, 03:31 PM   #10850
AMGRacer's Avatar
Originally Posted by ProE
Do you have a part number, and where did you buy it from?
I got it from Hong Kong. Not sure of the part number, it is on the Japanese website.
AMGRacer is offline   Reply With Quote
Old 09-18-2006, 03:33 PM   #10851
AMGRacer's Avatar
The ability to change the amount of rear roll with a quick turn of 2 screws is priceless. It is super easy to adjust the rear grip levels without having to change springs etc. Similar to the front blade style bar.
Mike Swauger uses one on his car all the time.
Old 09-19-2006, 09:19 PM   #10852
Thanks, would try it out and report back.
Body wise...the gf wants a M3 body
beter get what she wants first, else I would lose a partner at the tracks.
boggysv is offline   Reply With Quote
Old 09-20-2006, 02:27 PM   #10853
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by 20 SMOKE
$110 OBO IF ANY ONE KNOWS SOME ONE
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-20-2006, 03:29 PM   #10854
Superglue that plastic part into the part #ed 56461. DO NOT get the glue on the beveled part that sits against the ball. You will never loose that part again.
TM, Murnan, RB, Morgan, Nomadio, GQ, Integy, GP, Duratrax, Protoform, Cruisin, Raceday, Wolf
GBagRacing is offline   Reply With Quote
Old 09-20-2006, 06:07 PM   #10855
surreal's Avatar
Trader Rating: 39 (98%+)
Send a message via ICQ to surreal Send a message via AIM to surreal
CA glue does work. I had the same problem.. I lost this part on more than one crash. That cheap little part is worth 8 bucks! Alittle advice - use a REALLY small amount of glue!
surreal is offline   Reply With Quote
Old 09-20-2006, 06:31 PM   #10856
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Well, I think I'mma enter my R40 in the Region 1 Warmup event and the Champ event however I'm still waiting for my setup gauges. Without them it's a trial an error. I may try some front droop to get rid of the steering as I found it effective on my last R40. The car doesn't have much upgrades, but it's still quite a performer IMO. I just need to purchase a sedan body and tires.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-22-2006, 11:55 PM   #10857
I dont understand, why am I breaking belts as if the car hates me?
I heeded the advice given here, and only play on track, yet I broke 2 belts in 2 plays. Heck, I even replaced all the pulleys and belts before this breaking frenzy began. Thank the lord my middle belt is still fine.
1st day, broke front urethane belt after 7 tanks, went home to install used rubber belt, and raise ride height.
2nd day, broke rear urethane belt after 9tanks, front belt still holding up fine.
(rear belt is one perch loose from the middle point)
also, regarding the mtx3 clutch conversion. during the last few tanks on the 2nd day, i had problems launching the car from low speeds. Sometimes it wont even grab after the 2speed shifted. Is that normal for the stock r40 clutch?
Would it be a good time to go for the conversion?
Old 09-23-2006, 12:45 AM   #10858
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
If you're braking belts there could be a couple of things.
1) Check to see that every thing moves freely, belts, shafts, diffs.
2) Check that your wheel diameters are about the same size. Your whole drive train is one mechanism that is connected through belts. If your going in a straight line, the front and rear shafts will rotate at the same RPM (unless your using other gearing). If your wheel diameters differs from front to rear, they will spin at different RPM. This will put alot of strain on the belts and could brake them.
I had the same problem when I used my car for the first time. I fitted new tyres onto the car and the problem dissapeared. In general the rear tyres wear more than the front. When ever I see a difference in the front to rear diameters, I true the front tyres down to the same size as the rears.
The clutch on this car has been talked about many times on this forum. Do a search and you will find alot of posts. Some guys use the stock clutch without any problems. Some fit only the mtx4 grey clutch shoe, and the other guys fit the whole mtx3 clutch kit.
If your clucth has work fine but is slipping now, check the adjustable nut in your clutch, it tends to tighten itself. Loosen it back if this is the problem. So of the post that were made before, mention the use of locktight to keep the nut in a set position.
Good luck with this.
ProE is offline   Reply With Quote
Old 09-23-2006, 04:34 AM   #10859
Moderator
Urethanes seem to snap. I had mine to test around and the rear snapped first race. Swapped back to rubber and im good.
Old 09-24-2006, 11:50 PM   #10860
nitrodude's Avatar
How do you guys got around the fact that the rear body post sit right under the rear wing?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
