Old 09-05-2006, 02:24 PM   #10801
Rapid Roy's Avatar
Originally Posted by HarKonnenD
What silicone wt is everyone using in their R40 for the rears? I've started driving mine with the OS .12TR and it does seem to be a bit faster, but a tad bit harder to control. I used the included oil for the front diff in the rears with the 4 gear mod which is probably been screwing it up. Still using the stock clutch and takeoff is pretty snappy IMO so no need to change. When I have the $$ I'll also join thet 05 Hara club.
If the rear end is too loose, then you need to lighten up the oil in the rear diff or fill it only half way. On loose parking lot or low traction conditions running just grease with the 4 gear mod is too much, so it really depends on how much grip you have. The other thing you can do is to go to silver (softer) rear springs. I raced on a different surface last year and was having oversteering problems. I knew the rear diff was too tight, but I put on silver rears and it handled great, so I left it that way.
Rapid Roy is offline   Reply With Quote
Old 09-05-2006, 05:39 PM   #10802
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Thanks for the tip guys, I'll give it a whirl tomorrow weather permitting.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-05-2006, 07:55 PM   #10803
hey i was wondering if any of you r 40 guys out there have an extra set of part number 72274. it is the servo saver shaft. i have a bunch of spare parts and i was going to put together a second r40 and thats aobut the only part i dont have and hpi is on back other for a few months. can any of your guys help me out?
thisisagame24 is offline   Reply With Quote
Old 09-06-2006, 06:22 AM   #10804
surreal's Avatar
Trader Rating: 39 (98%+)
Send a message via ICQ to surreal Send a message via AIM to surreal
Good luck with that. I have a backorder on this item since May .
surreal is offline   Reply With Quote
Old 09-06-2006, 06:24 AM   #10805
surreal's Avatar
Originally Posted by fastharry
fastharry -
I am intrested in purchasing a good scale. Where can I get this scale in the picture above?
Old 09-06-2006, 06:58 PM   #10806
TonysScrews's Avatar
UPDATE!
HPI R40 1/10th On-Road screw kits are now in stock!
HPI R40 1/10th On-Road 220-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Kits will begin shipping Friday, September 8th, 2006.
Thanks and best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 09-07-2006, 03:52 AM   #10807
moot's Avatar
Originally Posted by moot
is the 2005 edition a good rubber car?i need a new car to run on concrete.its either an r40 or an fw05
anyone?
moot is offline   Reply With Quote
Old 09-07-2006, 04:43 AM   #10808
gonz's Avatar
Send a message via Yahoo to gonz
just curious guys .....
is Hara participate in the IFMAR world champ in Aussie ....?
tx
gonz is offline   Reply With Quote
Old 09-07-2006, 05:44 AM   #10809
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I dont think he has even raced the r40 this year. I think his game is pretty much focused on the cyclone.
Artificial-I is offline   Reply With Quote
Old 09-07-2006, 05:47 AM   #10810
Moderator
anyone?
Says on the box , meant for foams. But ive heard of people running them on rubber , with what success , Iam not sure. I would gather underdriving the rear belt pulley one step to keep that rear in check and go from there.
If your track is also used to converting setups to rubber im sure you can get it going. The downside though , there is no rubber setups avaiable from hpi. All you can hope for is personal setups.
Old 09-07-2006, 05:54 AM   #10811
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by surreal
fastharry -
http://shopping.rcmodel.hk/product_i...oducts_id=4925
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-07-2006, 10:34 AM   #10812
Rapid Roy's Avatar
I have run rubber tire with good results. Usually in low bite or dusty track surfaces where the foams just won't hook up. I run pretty close to stock settings, the only change I make is to use a little less camber.
Old 09-07-2006, 04:05 PM   #10813
ToddB's Avatar
Default HPI R40 For Sale
Dont miss this deal new 1/2 season on '04 R40 all hop up's and 2 cars worth of spare parts w/motor. I/M me for full details. Thanks
Smac Trac, Evolution Raceway
ToddB is offline   Reply With Quote
Old 09-09-2006, 12:32 PM   #10814
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Anyone tried a solid front diff? What is the advantages of a solid diff over normal diff and oneway.
I know the oneway has better drive out of the corner than a normal diff. (but no braking).
I've used 50k oil on the diff to stiffen it up and it helped alot. I've also build a solid diff today, but would like to know what the advantages and disadvantages are for a solid diff.
ProE is offline   Reply With Quote
Old 09-09-2006, 06:35 PM   #10815
HarKonnenD's Avatar
I remember some saying the solid rear in the front pulls the car more in turns like a oneway, but remember the wheels are moving at the same rate of speed. They both will have the same amount of traction whether on and off power. I have the oneway and 4 gear diff and indeed the car is a lot faster in the turns and better than diffs on all 4s. It is beneficial to have a setup system now though and definately try different oils. I'm only running the OS .12tr, but in a lightened R40 the TR is fairly impressive and also being on 30 %. I had ideas of selling the old one again for a newer kit now that my paychecks can now be going towards RC. Fast harry, Sry about before, but it wasn't me burning you - just that every time I had some $$ it had to go somewhere else first...90% of the time was to the credit card bill my mom get since she was kind enough to let me use it twice to pay off my car insurance. If I did have the $$ in hand I'd buy your Hara in a heart beat. I appologize again man. Regardless, there's been too many shifts in race scheduling for nitro onroad so I may just take a break from it and join the elec scene. I've been thinking of a Pro 4 or some other elec onroad. I have an ELEC offroad on the way, but soon will get a buggy and onroad.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
