Old 07-24-2006, 12:35 AM   #10621
Rapid Roy's Avatar
Originally Posted by AMGRacer
Here are a couple of pics.
Great racing AMG! Good to see you carrying the R40 torch.
factory racer, Artificial-I uses the Mugen Ti pivot balls on his car from 3 racing.
Rapid Roy is offline   Reply With Quote
Old 07-24-2006, 10:03 AM   #10622
factory racer's Avatar
ok thanks
factory racer is offline   Reply With Quote
Old 07-24-2006, 03:47 PM   #10623
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
If I remember correctly the Mugen pivots I picked up were for the 8th onroad or the MTX4. They work great and are stronger than stock. Indeed a bit longer, but not so much that it's a problem.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 07-24-2006, 11:40 PM   #10624
ok thanks for that info
Old 07-25-2006, 07:45 AM   #10625
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Artificial-I
I got the kyosho v-one-rrr's they are quite a bit bigger , couldnt imagine a 1/8scale having smaller ones , but perhaps.
I know he was running a 1/8th scale and he pulled them out of his box...they could be Mugen...I wasn't really paying attention. Anyways, they went right in perfectly.
I guess the moral of the story is that there's another (more popular) current car that uses the same size pillowballs.
Turbo Joe is offline   Reply With Quote
Old 07-25-2006, 07:49 AM   #10626
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
On that note does anyone have any problem with the standard r40 pillow balls stripping out in hard hits in the plastic arms.
Seems when I had plastic arms I was dealing with this issue. After I went with the CG arms this went away. Im thinking on if I should trim my 3racing pillowballs to the size of r40 or just leave them larger since im probably going to use this on plastic armed hara.
Artificial-I is offline   Reply With Quote
Old 07-25-2006, 05:19 PM   #10627
HarKonnenD's Avatar
AI- Are the CG arms more durable than the stock ones? Where are they sold. I'm trying to get my real car completely ready to hit the roads since I'll be journeying to much farther tracks for other races. For the moment I'll visit my two home tracks. PS YGPM
Old 07-26-2006, 12:57 AM   #10628
Rapid Roy's Avatar
I haven't had any problems with the pillow balls stripping out of the arms. I have had the balls pulled through the steering knuckles once. My last race I caught a rear tire on a joint in the boarder pipes and ripped the hinge pin out of the bulkhead and broke the arm, but everything else was fine.
Old 07-26-2006, 06:20 AM   #10629
Moderator
I guess there more durable. I was told by hpi when I asked them why they didnt have the 2004 here , cg arms etc etc. I was told the CG arms are brittle. But I havent had one issue.
The only issue with using them is.
1. Its harder to thread in the pillow balls cause you have to be very exact and precise, otherwise the arms will bind terribly. I had to take my arms for about 2-3 days or working them really hard to get them to finally loosen enough to be acceptible.
2. I ended up blowing/ripping out my rear lower suspension blocks when I got in accident. Guess it makes it the weak point. The suspension arm shaft ripped right through it. After I replaced it with the 3racing aluminum rear blocks. Havent had one problem since.
But it was pretty funny , I could move the rear hub all around and bend it forward probably a good inch. After with the cg arms and hubs it wouldnt bend forward but maybe 1/10th an inch. Much more solid and I figure probably better at keeping its suspension geometry.
But I havent really had any problems except for the rear camber links. Which I replace with new hpi ends and some lunsford 1mm longer (should have gone more) turnbuckles.
The only thing that really happens is the nut/screw that holds the hubs/knucles against the pillow balls, sometimes come loose and I have to snug it back up to remove that slop. Which I always seemed to have this trouble with plastic arms...probably a little worse.
Old 07-27-2006, 11:15 PM   #10630
Well Artificial-I i went and got a hara edition R40 tonight, also if your ebay deal for the proceed fall's through pm me ill offer you cash for it, also i wanted to know who is runing a .21 in there r40's??? i have a few extra .21's and a few .26's in the box i would like to try on my r40, any personal trials with larger block's???
BB Mods's is offline   Reply With Quote
Old 07-28-2006, 09:51 AM   #10631
im going to pick up my hara r40 tonight sometime
Old 07-28-2006, 10:26 AM   #10632
mine should be here tomorrow
Old 07-28-2006, 07:27 PM   #10633
Dstan's Avatar
Send a message via Yahoo to Dstan
Default r40 .21
Will a .21 fit in a r40?
Dstan is offline   Reply With Quote
Old 07-28-2006, 09:22 PM   #10634
I dont know..im asking the same thing...Mine gets here tomorrow so ill find out, but i do know a .26 fits in a RS4-3
Old 07-28-2006, 11:06 PM   #10635
HarKonnenD's Avatar
Sry, but that is one cluttered chassis.
No, a .21 will NOT fit in the R40. The R40 fits .12s or .15s only. The OS .18s will fit only due to the fact they have the same mounting dimensions as a .12. Any other .18 with larger mounting dimension will not fit. I've seen cars with the .18tz blow away others with other BB motors in it and in turn, a .12 race motor which was designed for the car beat them both.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
