Old 06-12-2006, 01:13 PM   #10441
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Has anyone tried the alloy servo saver or pully spacers from integy? Just wondering about them.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-12-2006, 10:06 PM   #10442
CraigH's Avatar
Any one know where to get the Hara 1 piece engine mount, the machined pistons, and HPI lower rear arms mounts?
AE TC7.1
AE B6d
AE B64d
CraigH is offline   Reply With Quote
Old 06-12-2006, 10:09 PM   #10443
AMGRacer's Avatar
I got all of those bits from RC Champ in Japan.
AMGRacer is offline   Reply With Quote
Old 06-13-2006, 10:09 AM   #10444
Does RC Champ have an english Translation site? My japanese sucks.
PoPRC is offline   Reply With Quote
Old 06-13-2006, 12:28 PM   #10445
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
What is the benefit of using the one piece engine mount?
ProE is offline   Reply With Quote
Old 06-13-2006, 01:35 PM   #10446
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
if I am not mistaken its just lower CG and may lower temps a bit, I don't know if you would notice it....
J.
jscamry is offline   Reply With Quote
Old 06-13-2006, 01:43 PM   #10447
Rapid Roy's Avatar
Its supposed to keep the portion of the chassis under the engine more rigid so nothing can flex which could cause improper gear mesh.
Rapid Roy is offline   Reply With Quote
Old 06-13-2006, 02:05 PM   #10448
HarKonnenD's Avatar
Anyone tried mtx4-mrx4 pivot balls on the R40? I've noticed HPI sorta..well not to make it sound bad, but "cheated" on the R40 a bit with the weak pivot balls. They say they are steel but I knocked tire sof my car before and or in the same spot...never broken an pivot ball. Therefore I opted for some from Mugen. They are a little longer, but the ball part are the same size and these are way stronger. I'll be using the integy steel swingshafts for the R40 as well since the stockers are made from the same material.
Looking at them ...not the best pic, but they are definately made of lil bits n pieces of metal. Forgot the proper term for it.
While at it I got the Mugen pins as well. The shop was out of the HPI ones. These I'll have to cut which is no big deal.
Here is a comparison. stock top mugen bottom
In the upper arm.
Here is the B4 and after shot from running on Sunday. The TR does have a really smooth powerband...but I'll still get passed around the track easily. A TZ is on the way.
I'm headin upto prospeed this sunday for the fathers day race. Hopefully I have enough spares since I'm buying the TZ modded soon this week.
Old 06-13-2006, 02:41 PM   #10449
ProE's Avatar
looking at the photos, that must have been serious crash.
Just concider the following when you replace them with the mugen parts. There is a saying that says, " a chain is only as strong as its weekest link". I know this is not a chain, BUT.
If you hit something hard, something has to brake. If you replace the pins with stronger ones, they may not brake next time, but something else now has to take all the impact forces, and that part could brake. Next time it could be parts that is alot more expensive.
It could be that the HPI ones are just not strong enough, or bad quality.
Old 06-13-2006, 03:02 PM   #10450
bummy's Avatar
Send a message via MSN to bummy
very well put, i did the same thing with my tc4. made everything all alloy. ie hubs steering titiaunmiun buckles the lot. but left the arms plasctic, that way i only have to have spare arms with me. cause if is such a big hit i break a alloy part then i should not be racing i did the same thing with my r40.
bummy is offline   Reply With Quote
Old 06-13-2006, 03:34 PM   #10451
AMGRacer's Avatar
Check out their forum on RC tech, its below this forum. Its all in english there.
Old 06-13-2006, 03:36 PM   #10452
AMGRacer's Avatar
The Hara mount is just marginally lower than the stock mounts. But as Roy said it basically prevents the engine case from twisting in the mounts and flexing the chassis. Also it prevents the case itself from distorting under load as the case is a very tight fit into the mount itself.
Old 06-13-2006, 03:40 PM   #10453
AMGRacer's Avatar
I have never broken a pivotball, but I have pulled them through the front hubs a few times. I was running some titanium MTX3 pivot balls there for a while which are the same as the HPI ones, they seemed to work perfectly fine. There are also some Hara titanium pivotballs available.
Old 06-13-2006, 05:16 PM   #10454
CraigH's Avatar
I emailed RC champs and they dont have any R40 parts, they can try and get them but no guarantee..
AE TC7.1
AE B6d
AE B64d
Old 06-13-2006, 07:42 PM   #10455
AMGRacer's Avatar
Bizarre. I got mine at least a year ago however, so perhaps they dont deal in much HPI anymore, dunno.
You could try Rainbow Ten in Japan or Jet Hobby in Hong Kong. Or HPI in the US could actually do something for a change, not much chance of that however.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
