Old 06-08-2006, 06:44 PM   #10411
rcrevolution's Avatar
Send a message via AIM to rcrevolution
If thats the case I'll get the G4S cause I can get it for $100 cheaper
rcrevolution is offline   Reply With Quote
Old 06-08-2006, 08:23 PM   #10412
vulso's Avatar
A.I. i have the HPI 12rxs is this an STS motor? If so, do you have the piston and sleeve that would fit it? It turned out my motor problems were my own doing. One of the head screws backed and caused a leak, causing it to loose compression. I got a good year out of it with over 2 gallons through it. However, when I took it aprt to look it over after the race it looks as if the piston and sleeve were pretty well burned up. I took it off the track after the race and temp'd it it was about 320! OOPS! let me know if you can help me out. Thanks.
Could I use this?
http://cgi.ebay.com/STS-12-D5R-P-S-P...QQcmdZViewItem
vulso is offline   Reply With Quote
Old 06-08-2006, 08:25 PM   #10413
vulso's Avatar
Also, does anyone have an opinion of Rocket Science fuel? we got some at the hobby shop and everyone seems to like it. i currently run Byrons and no one likes it!
Old 06-08-2006, 08:27 PM   #10414
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Vulso-The HPI is STS based. It's a pretty good motor to start with.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-08-2006, 08:30 PM   #10415
vulso's Avatar
Ooh yeah it is a very good motor! I liked it alot and it was able to hang with motors that cost twice as much! that's why I want a new piston and sleeve set for it.
Old 06-08-2006, 11:25 PM   #10416
Wohoo Surikarn Chaidejsuriya is attending the worlds so hopefully he will give the R40 a good showing
Brett.w is offline   Reply With Quote
Old 06-09-2006, 06:32 AM   #10417
Default 'mother theresa mouth.'
Originally Posted by Proteus
Dude, slow your roll. Before you start blasting reputable members on this forum, think twice. Especially if your a noob, I wouldn't go around acting like that. People here will be less inclined to help you out. It's true that we always welcome new people, as this helps with growth. But for somebody with a mouth and attitude like that....we just don't need it. I'll be the first to admit that I don't have a Mother Theresa mouth, but there is a time and place to use those words. And judging by your tone and writing, you sound quite young....12, 13? So take the time and patience to learn from the people here that have been doing this for quite some time.
just one thing dude.
nope im not that young, wrong judgement.
and my 'tone'..cant remember i was talking....you 'sound quite young'..
dude...i'm only here to discuss things about my car. not bs..
and the things you wrote..
you think its worth this all.?
i dont need youre comment/ advice.
steven w is offline   Reply With Quote
Old 06-09-2006, 06:36 AM   #10418
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
and i'm sure everyone will rush to talk with you.......
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-09-2006, 07:00 AM   #10419
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Byrons is great , but rocket science could be worth a try. I have a sample of it that I have yet to test. Just do a back to back run.
Artificial-I is offline   Reply With Quote
Old 06-09-2006, 07:12 AM   #10420
:P:P
fast indeed..
just had my post done..and youre the first one replying on my post, at the very same moment..impressive.
now i know why they call you 'fastharry'. :P
Old 06-09-2006, 07:42 AM   #10421
Moderator
Could I use this?
Yeah its an STS motor. Im not sure if it would work , but Id be willing to bet it would. Are you sure the motor is toast though? The leak would have made the motor hot. You can probably try sealing it back up , clean the piston top and sleeve with some metal polish , then with some alcohol , then lube it with some after-run oil and reassemble. Turn both needles 1 turn counterclockwise and retune slowly. You might also want to try cyrul it for a little and keep turning the HSN rich until you get about a tank through it. Then retune and I bet itll run good. If not , let me know Ill get you a discount on that.
Thats the 5-port btw. Id also suggest a new con-rod. Or for a few bucks more you can just toss the motor and go with the newer d3r and I can get you a discount on that. LMK. Im also selling modified versions of the d3r (A.I Modified) versions. Itll definently move fast.
Old 06-09-2006, 10:23 AM   #10422
Originally Posted by Artificial-I
middle mount can be found cheaper. I got the gpm for curiosity. I then thought its a bit different from the hpi and reading from hpi japan said it changes the balance and grip levels for different tuning setups....
Are you using alkaline batteries? Get AAA 5 cell battery hump pack , then just recharge.
I'm using a 5 aaa hump. since I live quite far from the track, and have two packs of batteries. I want to just replace the pack and keep on going (trying to get as much run time as possible)
The middle mount changes the balance??/wow
I dont think I would be able to appreciate that yet, still learning the car.
Thanks for the reply.
boggysv is offline   Reply With Quote
Old 06-10-2006, 11:20 AM   #10423
HarKonnenD's Avatar
Yep, the car came in time for testing sunday. Here it is.
Anyone ran the oneway front and solid axle in the rear...or have a track wide enough to run that setup? It seems most people's tracks are rather small.
Old 06-10-2006, 01:29 PM   #10424
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Sweet, ride!! have fun testing it on sunday
~jason
jscamry is offline   Reply With Quote
Old 06-10-2006, 02:29 PM   #10425
HarKonnenD's Avatar
Definately. I'm gonna reset the car to the settings I had it at which I liked best. Since the 8th I probably won't drive for a while I may just toss the Jr in there. For the moment I do like the Hi 625MG. Not sure exactly when the 8th will be driven, but it's ready to run at any time. Some more suspension parts are going to be purchases and the rc screws kit as well. The LW gear can wait since the gearing is too tall for my liking. Might also go with the stratus body again, but a Lola is included so I'll use and the RX8.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
