Old 05-15-2006, 10:48 PM   #10276
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default 30k or 10k
I was wondering which do you all recommend on a semi low traction technical track. 10k or 30k in the rear? I was at a local track that was had these conditions and the car was not allowing me to get on it comming out of an corner. Could it be that 30k in the rear would be too heavy? My setup was:
front oil 60wt
toe 1+
camber -2
shocks were mounted front and rear outer most position on bottom abd same for upper part stock shock towers.
rear oil 50wt
toe -3
camber -2
thanks all
jscamry is offline   Reply With Quote
Old 05-15-2006, 11:15 PM   #10277
Rapid Roy's Avatar
front oil 60wt
toe 1+
camber -2
rear oil 50wt
toe -3
camber -2
thanks all
If you were spinning out when you got on the throttle, then yes, the rear end is too tight. You could try the 10K or even go to simple grease. You might even need to go back to the 2 gear diff if the traction is too low.
Rapid Roy is offline   Reply With Quote
Old 05-16-2006, 12:34 AM   #10278
CraigH's Avatar
Any one have a great parking setup for the R40? Also motor recommendation? Mid size parking lot track?
CraigH is offline   Reply With Quote
Old 05-16-2006, 08:12 AM   #10279
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
AMG just posted one.
Silver Spring in front
-2.0 degree rear toe
30k oil in the rear
Front spool / solid
Im guessing the rest stock settings.
Im running a parkinglot track too.
Ive got spool in the front , 4 gear rear diff with 10k oil in the rear , -2.5 rear toe , .5 front toe , -1.75 camber in the front and -2.5 in the rear , running like 64mm to 58mm tires. I adjust rideheight as retrue as the tires go down. Im going to be trying to run a slightly smaller diameter front tire to offset my traction wear since the rear wears faster than the fronts for my next race.
Rideheight im running 5 in the front and 5.5 in the rear.
Im running 37 shore twister tires all around. But im still playing around with those. So far works well.
Artificial-I is offline   Reply With Quote
Old 05-16-2006, 11:36 AM   #10280
Rapid Roy's Avatar
30k oil in the rear
Front spool / solid
I use black front springs and silver rear. I'm thinking there is a difference between the 2005 and the earlier models with the chassis balance. I use stock shock settings with 50wt shock oil f/r. I also use the 4 gear rear diff with 30k but a 2 gear front diff with 100k. I used 37 shore front and rear too.
The other thing could be the grip. I switched to the silver (softer) rear springs for a race with lower traction because the rear was too loose. Until then I had black all around.
Old 05-16-2006, 08:09 PM   #10281
bucknuts's Avatar
Anyone know if any other brake discs fit the R40? Mtx3?? BTW I plan on getting an MTX flywheel, weights and pressure plate. I think the angle of the flywheel might be why the r40 clutch is so hard to get working.
bucknuts is offline   Reply With Quote
Old 05-16-2006, 09:13 PM   #10282
AMGRacer's Avatar
Silver front, black back is the ticket if you are running a spool to restore offpower turnin. Without the spool your setup may be better. I usually use black or gold front and Red proceed rear with a oneway.
AMGRacer is offline   Reply With Quote
Old 05-17-2006, 10:58 PM   #10283
Rapid Roy's Avatar
Ahh, now I understand. Makes perfect sence to me now. I will probably give the spool a try.
Old 05-18-2006, 12:15 AM   #10284
jscamry's Avatar
I have an ealier model r40. I believe that I purchased the car back in 03', I belive when the car was released. What would I need to convert my car to 04' specs?
thanks Jason
Old 05-18-2006, 12:35 AM   #10285
Rapid Roy's Avatar
thanks Jason
04' specs would require;
LW chassis
LW 2 speed
CG front and rear shock towers
Alum. shocks
LW CG upper deck
LW 2 speed and mid shafts
BB steering upgrade
Heat sink motor mounts
TI screw set
05' specs require;
New LW chassis
New CG upper deck
Fuel tank
LW battery pack
Servo mounts?? (not sure you need this)
Alum. shocks
BB steering upgrade
Old 05-18-2006, 01:40 AM   #10286
AMGRacer's Avatar
Or buy Harrys new one he has for sale!! It will cost you way more to convert to 04 or 05 spec, I can guarantee that.
Old 05-18-2006, 04:58 AM   #10287
Moderator
Yup part by part its more exspensive. Get harrys car and build a whole new ride. Leave that one you drive on the streets all the time for the streets and keep the one for the track , track only.
Old 05-19-2006, 09:49 AM   #10288
in2deep's Avatar
Cool
if anyone is interested in a r 40 i have one w/jp mod motor car is stock dont need no upgrades to try to make the car handle i do just fine with it being stock always running up front and have one a bunch of times w/it just my 2 cent's.
in2deep is offline   Reply With Quote
Old 05-19-2006, 08:40 PM   #10289
AMGRacer's Avatar
this is my post with incorrect spelling and no punctuation can anybody else read this without having to re read it several times to work out what the hell i am saying here
Old 05-19-2006, 09:50 PM   #10290
jscamry's Avatar
what??
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
