HPI R40 Nitro Car Forum
Originally Posted by Rapid Roy
I think this is what fastharry used for his high strength tie rod fix. I think he used the proline ones. These lunsford ones look exactly the same.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEMD2&P=7
Only $1.89 for a pair too.
But I know he used something like this. I just cant seem to find it.
Originally Posted by Artificial-I
I think I have some of those , the inner hole is too small to fit on the big pivot balls. But I tried it with there own pivot balls , except there kinda cheap and arent smooth moving , the plastic in those things are ultra strong , I could see how it would work. Its hard to just screw on the turnbuckles.
happy hunting, hope it works out for you guys
On a side note I just saw this at RC model site.
http://shopping.rcmodel.hk/popup_image.php?pID=2303
Is it really new? or have I just missed it. Looks like it would work.
Hey guys. Ran the R40 this weekend and it was awsome. I decided to run a overdrive set-up. Put the 22t pulley up front and ran a 3mm difference between the front and rear tires. Wow. As far as camber links I havent had much problems with them on this R40. My last one they never held up, as a temp fix I used wire ties to keep them from moving back in on the rod. Also running your clutch to tight can cause the engine to boog down thru the corners. You want a good medium. If it hits to hard you run the risk of kicking out the rear end. I have about 2mm play in my clutch and it works great.. I just need to gear down first gear
Hmm. Maybe its just a really tight fit. Maybe I'm not remembering correctly. My memory isn't what it used to be .
Yup that will happen if its too low , I kinda liked it , lol...but I think I was a little too low, im going to crank it back a little and hopefully find the happy medium.
Well guys,
Looks like HPI isnt having a challenge this year. They dont seem to think that they are getting exposure at the last HPI challenges, or they dont think that they are getting enough.
Where did you hear this? Yeah thats a shame. I know the last hpi challenge last year @ superior was a dud compared to previous years. I think they havent been pushing there cars hard enough. It seems to be all cyclone and hellfire now.
I mean now theres a hara edition out , has hara even driven this version at a major event? At least when it was in production?
If there going to pull back the reigns, another bad move. They should just get used to smaller events until they get a better car that grabs the rc community better. They should also try the reverse and try pumping up there challenges more, add more events or contests. Maybe have some top drivers show up and show how its done. I know they had Thad Garner at one , too bad he didnt drive. But every HPI challenge Ive ever heard of Ive wanted to attend and there all awesome. I would seriously be sadened though if they dont have HPI Challenges anymore.....
I read it hear. Looks like a few of the guys contacted HPI and they wont do it unless they get a few thousand spectators.
Well guys,
In the end, each of us needs to decide which brand is best for ourselfs. For me, I guess I'm just an HPI homer. I feel a bit more comfortable with them as long as they have a competative platform and the R40 can still hang with the best. For now its HPI BABY!!!
Well guys,
damn that sucks, that was one of the reasons I bought my car vs another manufacturer?
Quick question for you guys. What are you running for camber front and rear?
I also redid my rear camber links. Im also going to be running -2.5 to -3 camber in the rear instead of -1.5 as before. This alone is going to bring the turnbuckles deeper into the rod. So this should help with the stripping some and from what I felt when my car was running extreme camber was pretty good. So Im going to jump up a little for next race and see how it goes. Plus this should put an end to the rear camber link problem.
Also if you run smaller diameter tires, does this effect the camber when you goto fix the ride height. Or simply put does changing the shock collar position effect camber?
I run 1 to 1.5 in the front and 1.5 to 2 in the rear. Smaller tires should increase camber. Try pushing down on the suspension and checking the camber to make sure. Let me know how it handles with the new settings.
I try to set my camber so that the tires wear flat. I am not sure if this is the correct way but it seems to work for me. Sometimes you cant get both sides to wear flat but they are pretty close. It normally is about 2 degrees or so in the rear and about 1 to 1.5 in the fron, depends on track.
