HPI R40 Nitro Car Forum >
Old 05-05-2006, 05:51 AM
  #10201
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by Rapid Roy
I have done this a couple of times at the permanent track near by. Never at the parking lot races. It has to do with the boarders that want to grab the wheel. I don't think its just the R40 though. I had the same problem with my 705 before I got the R40's. Maybe you could look a ways back on this thread and look at fastharry's car. I'm pretty sure he had gotten the aluminum knuckles to solve this very problem.
you mean these?....
these little beauties are available at our buddies "very own" on line hobby shop...pro-hobby....run by our mod ARTIFICIAL ONE...... www.pro-hobby.net
fastharry™ is offline
Old 05-05-2006, 06:28 AM
  #10202
That is one thing i have not had problems with. Never bent a dog bone or broke a front hub. I have pulled a pivot ball thru one of the front hubs but the car has been bullet proof for the most part for me. I try to stay away from to much aluminum, you just wind up breaking more stuff
BallPy is offline
Old 05-05-2006, 09:15 AM
  #10203
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Only thing is accidents do happen, and unfortunately the front dogs do snap really easily - they don't bend. I'll see what I'd get.
HarKonnenD is offline
Old 05-05-2006, 10:19 AM
  #10204
vulso's Avatar
Your not kidding!
I race on on a large parking lot with large diameter PVC pipe hooked together with straps. I do 'POP' the pipe every now and again. I only break a few things, several dog bones, pop the pivot ball out of the hub and the side belt falls off now and again. i run the P-dub bumper which takes alot of impact and disapates alot of the energy. These are acceptable to me because their controllable by how I drive and easy to fix. I would stengthen these areas up more but the energy would be transferred to something else which could more difficult to fix. I do have sveral CVDs in the pit box!
vulso is offline
Old 05-05-2006, 10:44 AM
  #10205
HarKonnenD's Avatar
I'm awaiting feedback from that guy who has the R40. He runs the car consistently and seems to have no problem with it. I'm amazed at how fast the car is with the stock setup, then again he is running a Sirio Evo 3. I'll see how much it will cost me for the package I'm trying to look at vs the other car someone is offering me. I'm in a debate over these two and I may need a new engine for my 8th onroad as well for racing. I'll have one practice and one race engine. Time will tell, but I'd much like to get back into the sedan scene.
Old 05-05-2006, 01:04 PM
  #10206
I must have got one of those good ones. I have never broken a dog-bone..well once but that was when I let someone else drive my car (BIG MISTAKE). I have noticed that the side belt stretches quick, are there any other belts out there that are better than the ones it comes with (Doesnt HPI have upgrade belts?)
BallPy is offline
Old 05-05-2006, 01:31 PM
  #10207
HarKonnenD's Avatar
They did seem to wear a little bit, but not by that much. I adjusted the side belt tensioner for more tension.
Old 05-05-2006, 01:36 PM
  #10208
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Ive never snapped a dog bone , never poped a pivot ball , I have had the metal #50461 part that covers / holds the arm on the pivot ball come loose sometimes. Hasnt done that in awhile after the first assembly.
And the rear camber links strips. Thats about it for me. I do bend dog bones though....I normally replace but lately dont really care. Unless its real bad and noticable. I have the p-dub bumper and this is probably helping some now too.
But other than that , my old rdlogic pipe seems to take more damage than the car. My new pipe has yet to been touched. I think the new stratus 3.1 body might be a little more protective of it. My stinger barely exits the body.
I will be trying out the titanium swingshafts and steel from GPM when they come in. I only wonder if they are any stronger. Im actually not sure what the stock ones are....their pretty lightweight. I believe I also had a set of used 3racing swingshafts....they were quite a bit heavier. I wonder if any of these would hold out longer.
Artificial-I is offline
Old 05-05-2006, 02:40 PM
  #10209
ProE's Avatar
Default 2 Speed Gears.
I just bought a complete set of gears for the 2 Speed combination. Looking at all the gear combinations that is available, is there any specific combinations that I need to use? or could I match them up as I want to too get a desired gear ratio? Example, could I match the 21T pinion with the 58, 59, 60 and the 27T with and of the 52, 53, 54 T gears?
Secondly, how do you set the gap onthe pinion gears to the two speed gears. Do you mate them all the way or do you leave a small gap between them when assembling the engin to the car?
ProE is offline
Old 05-05-2006, 02:58 PM
  #10210
Moderator
You dont want them to touch. Basically think of like 1.5 sheets of paper distance. Then roll the car and listen it should roll free and not make a tight scratchy sound. Good way to hear the sound is too intentionally set it too tight....
Old 05-05-2006, 07:59 PM
  #10211
nitrothugg's Avatar
Lightbulb
i went through a stretch where i broke 3 dog bones in one race everytime i tapped the boards...come to find out i had the set the servo saver too tight after a rebuild...loosened it a little and the easy breaks stopped.
just another thing to check on your own setup
nitrothugg is offline
Old 05-05-2006, 09:25 PM
  #10212
HarKonnenD's Avatar
I had the servo saver at the stock setting. Don't see how setting that too tight or looser will stock breaking the dogsbones. I'm gonna see what deal I can get for that R40 kit.
Old 05-05-2006, 11:22 PM
  #10213
Rapid Roy's Avatar
You can use any combination of pinions and spur gears as long as you keep the 1st gear pinions with the 1st gear spurs, and the 2nd gear pinions with the second gear spurs.
An easy way to set the gear mesh is to roll a strip of 20 lb paper between the gears and get it the mesh as tight as you can. When you remove the paper, the gears should spin freely.
Rapid Roy is offline
Old 05-06-2006, 12:18 AM
  #10214
nitrothugg's Avatar
im thinking if the servo saver is too tight then there is no "give" on the wheels during impact.
Old 05-06-2006, 11:49 AM
  #10215
ProE's Avatar
Default 2 speed
Bummy,
i seem to have a problem, everytime my car goes into second gear, then i go to take a corner and slow down i have no drive at all. untill the engine rpm goes back to idel and car has stopped. then it is fine, if i keep the power on it , is fine wont loose drive,untill i back off ,iam confused cheers.
I had the same problem today with my car on the two speed. How did you fix this?
ProE is offline
