HPI R40 Nitro Car Forum >
Old 04-30-2006, 02:56 AM
  #10141
jscamry's Avatar
Default howto make my front diff into a solid?
Hey all I was wondering how can I make my front diff into a solid with out using pt#75060 =Rear Solid Axle. Also how would the car react if I used a solid in the front and rear?
thanks Jason
jscamry is offline
Old 04-30-2006, 06:03 AM
  #10142
Formula1fan's Avatar
Originally Posted by Artificial-I
Never had a belt fall off once. But if you do get the problem the CF side brace will fix that with a quickness and reduce a little weight , or if your handy with a dremel just dremel down the slot for the belt tensioner and your good to go.
The only real weak link on the r40 is the rear camber links. Otherwise I didnt have much trouble with the car at all. The only tricky part is the clutch and you can go mugen for $50 for the full set.
Where do you get this Mugen clutch set and what is the part number?
Formula1fan is offline
Old 04-30-2006, 08:46 AM
  #10143
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Ill be racing at stikland. Superior is next sunday. First time to run the r40 on another track. Cant wait. Just put in a regular bearing kit, not sure about the quality but it was 14 dollars and it includes bearings even for your steering. Just missing the really small one.
They seemed pretty smooth to me.
Artificial-I is offline
Old 04-30-2006, 08:47 AM
  #10144
Moderator
It might have been brooklynhobbies, theres a few people out there who stock a lot of mugen on the net. Im not real familiar though I was bouncing around and always see them.
Old 04-30-2006, 11:55 AM
  #10145
onnetz's Avatar
http://nitrohouse.com/parts,_mugen_mtx-3.htm
onnetz is offline
Old 04-30-2006, 07:30 PM
  #10146
Moderator
Ran the car today. All I can say is.... Game , set , match. The r40 moves from just slight throttle blips.
Nitrothugg thanks for the help. That spring payed off. I now can focus on my driving. Thanks again.
Old 04-30-2006, 10:26 PM
  #10147
Rapid Roy's Avatar
thanks Jason
Cleaning putty in the front will work, diff lock lube will make it close to solid too. How come you don't want to use the plug on the front?
Having solid front and rear will probably make the rear too loose.
Rapid Roy is offline
Old 04-30-2006, 10:37 PM
  #10148
jscamry's Avatar
thanks for the info. I did not think that I was able to use the plug in the front since it was made for the rear
thanks Jason
jscamry is offline
Old 04-30-2006, 11:53 PM
  #10149
Rapid Roy's Avatar
JS, Yup the plug works in the front too. You could try front one way and rear solid like the 1/8 guys do. You gotta make sure the front is overdriving the rear with that setup or the car will be undrivable.
Old 05-01-2006, 12:24 AM
  #10150
onnetz's Avatar
Ran the car today. All I can say is.... Game , set , match. The r40 goes from just slight throttle blips.
how was that engine?
onnetz is offline
Old 05-01-2006, 02:25 AM
  #10151
jscamry's Avatar
thanks for the info rapid, so can if i were to run with the one-way in front and solid rear, I not want to have my break set to stop on an dime, correct. But with this setup I would get good a turning radius.
thanks Jason
jscamry is offline
Old 05-01-2006, 09:29 AM
  #10152
Moderator
Ran well, it exhibits very good behaviors. Idles forever , good smoke , smooth powerband. I broke some carbon hinge pins that I got so I wasnt able to run it long and was just starting to tune it. But it was moving really nice.
I brought the rear arms back more too that kinda helped settle the rear. As well I think I love the spool.
Old 05-01-2006, 11:39 AM
  #10153
TT120's Avatar
Default Another R40 Centax clutch victim
Well, after several days of messing with the Centax clutch on my R40 and reading about the issues in this thread, I've come to the conclusion that I will never get this one working correctly and need the Mugen one.
It's the one for the MTX3 right?
TT120 is offline
Old 05-01-2006, 11:45 AM
  #10154
Old 05-01-2006, 12:00 PM
  #10155
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
1mm or .5mm preload, two copper/two silver shims, may need a .5mm shim behind the collet depending on the engine, and try .8mm on the adjuster nut. I ran that setup with no issue on the stock clutch. I only changed because some how some parts got rusted.
P.S. Anyone still run at nanuet? What was their site again? Do they run 8th onroad?
HarKonnenD is offline
