Old 04-17-2006, 09:56 AM   #10051
Rapid Roy's Avatar
Originally Posted by 1615danny
hi can anybody please help ive got my old rc going again it hasnt been run for 9 month it all goes well given it a good run every time i open her up she dies on me can u please help THANKS ALL
Can you be a bit more specific. Also please use punctuation. Its hard to figure out what you are even asking.
Rapid Roy is offline   Reply With Quote
Old 04-17-2006, 05:53 PM   #10052
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Got my hara parts in today. Oh yes they look nice. Ill be weighing them tonight using them next month.
I also picked up the aluminum middle mount setup. Has anyone tried these? Cant wait , also got a lot more parts that im retrofitting onto the car.
Will let you guy know how that goes.
Artificial-I is offline   Reply With Quote
Old 04-18-2006, 09:43 AM   #10053
Moderator
Interesting. I for some reason figured the new hara super chassis would be about the same weight as the old super chassis.
Weighed it and it weighs 108G (hara05) VS 92G (super chassis / 04)
Im guessing most of the new weight loss then is from just the removal of the battery box and rx box. Also just got some lightweight digital servos on the car. Dropped 15g from it , so now im at 1635G. Woohoo.
Old 04-18-2006, 11:34 AM   #10054
Rapid Roy's Avatar
The weight gain is understandable since there is no cutout in the middle for the battery cover. I guess that piece of alum. weighs 16 grams
Old 04-18-2006, 12:18 PM   #10055
Moderator
Yeah , I guess I figured HPI would do some more cutouts in the chassis elsewhere to compensate. I was expecting a few grams but I guess not that much.
I held b.lafrances 05 and it was pretty lightweight compared to my kit which had quite a few lw parts on it over the 05. Guess well see once they go on. I did like the rx box though , going to miss that from the 04. But otherwise kinda wonder how its so much lighter.
Old 04-19-2006, 04:33 PM   #10056
I need to find out what exshaust pipe would be good for the novarossi rs-12 TS1 motor going in our R40 thanks for the help...
impdog is offline   Reply With Quote
Old 04-20-2006, 09:10 AM   #10057
Moderator
Figured we havent really done this yet and some of us cant scan sheets so easily so. Here we go. Some stuff is cut out, feel free to add anything extra you find important on your setup.
R40 Setups & Questions:
Front:
Width:
Tire:
Ride Height:
Camber:
Toe:
Spring:
Oil & Piston:
Rebound:
Bump Stop:
Sway Bar setting:
Diff:
Rear:
Width:
Tire:
Ride Height:
Camber:
Toe:
Spring:
Oil & Piston:
Rebound:
Bump Stop:
Sway Bar:
Diff:
Overall:
Body:
Motor:
Pipe:
Fuel:
Glow Plug:
Clutch Setup:
Gearing:
Track Condition:
Questions:
What do you adjust the most:
What do you find is the key to your setup:
What have you tweaked to get the most from your R40:
What do you think is the weakest point on the R40:
What part or parts have you broken the most:
What things give you the most trouble on the R40:
Feel free to add anything extra to your responses.
Old 04-20-2006, 02:21 PM   #10058
Front:
Width: 26mm
Tire: Hpi Pro Foam 40sh
Ride Height: 5mm
Camber: 1.5
Toe: +1
Spring: Black
Oil & Piston: 50w
Rebound:
Bump Stop:
Sway Bar setting: Horizontal
Diff: Oneway
Rear:
Width:30mm
Tire:Hpi Pro Foam 40sh
Ride Height: 6mm
Camber: 2
Toe: 3
Spring: Black
Oil & Piston: 60
Rebound:
Bump Stop:
Sway Bar: 2mm
Diff: 30,0000
Overall:
Body: Stratus 3.1
Motor: O.S tz
Pipe: Skyline
Fuel: Hobby Direct 16%
Glow Plug: P6
Clutch Setup: 1mm from the end (black shoe)
Gearing:
Track Condition: Medium grip/ Ashpalt
Questions:
What do you adjust the most: Spring position
What do you find is the key to your setup: Car is good out of the box i try to learn track first
What have you tweaked to get the most from your R40: nothing
What do you think is the weakest point on the R40: rear ball joints
What part or parts have you broken the most: no majors at the moment!
What things give you the most trouble on the R40: Reciver placement
Droop is 7, rear and 2 front (Hudy set up)
Brett.w is offline   Reply With Quote
Old 04-20-2006, 06:37 PM   #10059
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
has anyone converted an 04 yet using the tank,chassis and upper deck?..Are there any other parts needed(esp steering set up,reciever and battery placement..etc)......just want to know whether to convert mine...or buy a whole new car....thank you as always,gentlemen....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-20-2006, 07:15 PM   #10060
Moderator
I will be next month. But all my parts are already here.
You need upper deck , chassis , gas tank and servo mounts.
This will total 170 from hpi-racing direct , the only place I know of who carries the parts.
Otherwise its about 419 for the hara kit in the us and 360 for the 05 kit from asia , plus shipment.
I have way to much on my 04 to do another car so im sticking with the 04 and just upgrading it.
Old 04-20-2006, 08:58 PM   #10061
Registered User
OB42TC3's Avatar
Horizonhobby.com has all the parts needed. I didn't use the deck b/c I want to keep a slight right side weight bias b/c the quickest turns on US tracks are rights. The tank seems to be the biggest difference, and some light modification of the old deck was required to get the new tank to fit.
OB42TC3 is offline   Reply With Quote
Old 04-20-2006, 10:15 PM   #10062
Moderator
I never check there. Good to know though. Too bad they seem to all be out of stock at horizon and saying till june. Looks like its a good bit cheaper too, not the full retail hpi charges for who knows why.
Old 04-21-2006, 11:21 AM   #10063
Rapid Roy's Avatar
The only thing I could find at horizon was the Hara top deck. Do I need to call instead?
Old 04-21-2006, 11:34 AM   #10064
Moderator
There site is pretty accurate about stock, theres nothing really there. Also you need to search by part #'s to find it. I think hpi is being stingy. As well no one seems to have in stock the competition shocks for quite some time.
Old 04-21-2006, 07:59 PM   #10065
Send a message via AIM to AXRAY
Default r40 setup
does anybody have a good set up,for parking lot type surface,and gearing for a Novarossi .12. I need help.
AXRAY is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
