Old 02-27-2006, 10:51 PM   #9931
AMGRacer's Avatar
Originally Posted by Proteus
Thanks for the info. One more question, should I swap over my carbon susp arms too?
Hmmmm Im probably gonna have to take the 5th on that one. Here is my long winded theory on how useful they are. If you are driving on a surface/track that is high grip and you are generating sufficient forces that the arm itself begins to deform (more than acceptable) against the spring/swaybar forces, and that extra deformation is causing excessive uncontrolled weight transfer then yeah they probably will help. I have found them useful on a large sweeping and fast track where the car was feeling ugly mid corner due to uncontrolled suspension arm flex. Going stiffer on this track really sharpened the car up mid corner. I suspect its a case of try and see........
AMGRacer is offline   Reply With Quote
Old 02-28-2006, 11:48 PM   #9932
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Ok , spoke with Mike Swauger. So this is how it goes for the mugen clutch shoes.
Hardest to Softest
Red --> Yellow --> Grey
Quick Overview:
Grey is 1.5 hours of use, most snap.
Red and Yellow are very similiar in grip and wear with 3.5-4.0 hours of use, with yellow giving a little more snap.
Basically this is why all team hpi driver use grey pad. Most grip / snap. But quick wear rate. Now you can pick and choose now. No one in the mugen thread knew, they all had completely mixed up opinion....and I thought the mugen boys were on top of their game.
Artificial-I is offline   Reply With Quote
Old 03-01-2006, 02:56 AM   #9933
AMGRacer's Avatar
Hardest to Softest
Quick Overview:
Thats quite amusing because it is opposite to the advice I was given!! But I gotta say I am going to go with Mike on this
Old 03-01-2006, 11:03 AM   #9934
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I agree, Mike is the man!
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-01-2006, 11:17 AM   #9935
Moderator
Yeah I was looking to talk with either him or someone at mugen. Called mugen first to see who I could talk with and I hear , Mugen Seiki this is Mike.
I was like double score.
I also bought his used clutch set off ebay. Sure enough he was running the grey. Mike also used to drive the R40 and I heard he had a setup sheet out there somewhere. Would be nice if we could track that one down.
Old 03-01-2006, 01:32 PM   #9936
Send a message via MSN to Nitro guy.
Talking
hey guys, im new to the forum! I race at www.adurtouringcars.com with my r40, well im just about to start my second year of racing with my new r40 i just bought! Got it all set up and put a hpi .12rxs engine in it with a mielke tuned pipe. Just thought i'd introduce who i am so i dont leave you in the dark! My name is Glenn, im 15 and i am into the more serious side of racing (going to be doing a few national meetings) this year aswell! I also own a hpi pro 4 that i also race! er..... Just got my clutch set up on my r40 and need to take it for a road test tomorrow and tune the engine!
Just wondered if you guys could update me with whats going on in this forum at the moment as i am a member of every other forum it seems, but this has the biggest and best thread on r40s which is where i will be spending my time! Cheers guys! p.s who are you and what stuff have you got in your car and where do you race? cheers!
Nitro guy. is offline   Reply With Quote
Old 03-02-2006, 08:44 AM   #9937
also on my r40 i have an engine with an sg shaft! Do you use the bearing to put behind the clutchbell with an sg shaft? cheers!
Old 03-02-2006, 02:40 PM   #9938
http://videos.streetfire.net/hottest...C36B4E0747.htm
mgtman is offline   Reply With Quote
Old 03-02-2006, 03:15 PM   #9939
Moderator
That video is from hpiracing europes. Always good to watch though.
Old 03-02-2006, 03:49 PM   #9940
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default ?
whats up ARNO
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 03-03-2006, 09:13 AM   #9941
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Default 2 speed
My car does not go into second gear. Looking at the image, should I tighten or loosen the screws and which ones. The top and bottom, or the two on the side.
ProE is offline   Reply With Quote
Old 03-03-2006, 07:50 PM   #9942
Moderator
Make sure there is a hairline crack between the two shoes. Basically to where you can barely see light through it. Make sure that the screw on top and bottom equate to half of that gap so they have equal pressure.
Then back the side screws all the way out till they almost can get touched. This should be a good initial setup to get a shift. Then go inward for later engagement and outward for quicker.
Old 03-03-2006, 09:35 PM   #9943
vulso's Avatar
Originally Posted by AMGRacer
I stripped mine, and was using a brand new driver at the time. Stripped both of them in fact. Dont worry about getting replacements get these: Z423 Work much better and have a much tougher head area.
AMGRACER would these work instead? I stripped mine and need replacements.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLW3&P=7
vulso is offline   Reply With Quote
Old 03-06-2006, 05:00 PM   #9944
at first my 2 speed didn't shift but it was because it was to tight..loosen it up a little making sure its equal on both sides.
Also, has anyone ran their R40 without the sway bar? If so how does it run, I run my R40 in 2 side by side parking lots, one is about the size of a football field and is pretty smooth and the other lot is about 2 football fields and is a little more bumpy.
RS4-R40 is offline   Reply With Quote
Old 03-06-2006, 05:34 PM   #9945
Moderator
Wow thats a big parkinglot. Are there any concrete parking slabs around or anything to catch your car with or is it pure open parkinglot. Sounds like an excellent auto-x track , racing track.
Have you ever tried laying down some cones. Get someone with a stop watch and your set.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
