Old 01-31-2006, 01:13 AM   #9766
Minus's Avatar
Originally Posted by HarKonnenD
So since the difference in diamater has to be 3mm them pretty much useless no because I checked a lot of foams and they are a difference of 2 and not 3. I'm wondering if I can still use it and the oneway I'll be picking up soon. Anyone using that 22 pulley? BTW it goes on the middle shaft or 2speed shaft?
I'm using this 22 pulley and it goes on the middle shaft on the outside.
That's why i make an answer here regarding this 22 pulley
I hope you understood my explanations.
Minus is offline   Reply With Quote
Old 01-31-2006, 02:48 AM   #9767
AMGRacer's Avatar
The 22t side pulley when used should be used with a 2mm split front to rear to keep the drive ratio 1:1. It is beneficial to run a small front tire on tracks with tighter corners as it gives a more agressive front response to the car due to a difference is roll centres front to rear and a more responsive tire with less sidewall. If you run a 2mm split your car is not considered to be overdriving, it is in fact 1:1 front to rear rollout, however your drivetrain itself is overdriven.
You can elect to overdrive your car using the 22t pulley and keeping the tires the same size front to rear, this only really works properly with a oneway up front. If you use a front diff there is a huge extra load on the drivetrain and the car will certainly handle "interesting".
AMGRacer is offline   Reply With Quote
Old 01-31-2006, 06:35 AM   #9768
captian's Avatar
Originally Posted by GBagRacing
General comparison to other pipes you have used. ie: Cvec, RDL, skyline etc....
well i have never used a cvec pipe on my cars before . i find that the novamega-rb - rex=top=max=pipe are pritty much the same. touring and 1/8 scale for that .12 engines and 21 engins classes. and i run both classes. skyline& ths pipes i will tey in practice.and let you know . but what you really need to do is tune the pipe that you want to use to the engine so you get max power when tuning .but make shore the clutch is right on your car so you can get it to the ground.
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-31-2006, 12:13 PM   #9769
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Sounds great. The oneway should be in tomorrow so I'll try it out.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-31-2006, 01:28 PM   #9770
Rapid Roy's Avatar
RC Champ the Japanese shop on this site has those items. If you wanted to "cheap out" you could probably use the top deck, servo mounts and tank without the new chassis plate. It should fit ok................
AMG, I just got an email back from RC Champ about the 2005 parts
"Dear Mr.Imahara
Hello.How are you doing,sir?
Thank you for writing RC Adviser Champ.
With regard to the HPI R40 parts,these parts will be special order items at our shop,so we don't have them in stock.
Also we are not sure these parts are available here in Japan,because I couldn't find these parts number items at HPI Japan website.
If you have any question,please let me know,sir.
Thank you.
Best regards,
RC Adviser Champ
Hirotaka Suganuma"
I asked for pricing and availability of these;
#73110 New R40 Hara Edition Upper Deck (Woven Graphite)
#73925 New R40 Hara Edition Chassis
#87173 Lightweight 2 Speed Transmission Set (0.8M)
#75067 New R40 Hara Edition Aluminum Servo Mount
#87241 New R40 Hara Edition Fuel Tank
I'll keep looking. I'm sure the parts will start showing up soon.
Rapid Roy is offline   Reply With Quote
Old 01-31-2006, 01:30 PM   #9771
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Japan wont have hara parts. It will have 2005 deck , chassis etc. Otherwise all the hara parts can be bought direct from buy hpi on there website.
Artificial-I is offline   Reply With Quote
Old 01-31-2006, 01:54 PM   #9772
Rapid Roy's Avatar
I would think that the part number would be the same between the "2005" asia kit and the "Hara" US version. Maybe AMG could shed some light on this since he has the "2005" kit.
Old 01-31-2006, 02:24 PM   #9773
Moderator
Well I know the kit numbers are different. 818 vs 816. But I did go check a website with the 2005 kit and they were listing the exact same numbers for option parts as the US. So im guessing it is the same.
So im kinda baffled why they arent available from hpi japan , but are available from hpi usa. Normally its the other way around.
Either way if you cant wait , buy hpi has them. Hope this helps.
Old 01-31-2006, 04:05 PM   #9774
Rapid Roy's Avatar
Thanks for looking. I can wait. I really don't get a chance to race much, and my 1:1 project of buying/restoring a 1989 MR2 Supercharged is on the back burner (wife nixed that one). So, I'm upgrading my RC stuff. Maybe a 3PK and spectrum, 2005 spec R40's. Oh well. At least I'll look fast when I hit the track.
Old 01-31-2006, 08:01 PM   #9775
What futuba servos will I need for my r40 ? good ones.....thanks for the help..
impdog is offline   Reply With Quote
Old 01-31-2006, 10:30 PM   #9776
Moderator
Lots to choose from , if you want all digital. S9550 is a good combo of speed/power and lightweight. Plus there compact so they fit better.
If you want regular , s9404 coreless. Want budget s3010 is strong for steering and s3003 for throttle would work.
Ive recently found a new servo to use. Well actually two of them. One is a ko propo , there new budget digital servo. Great price , and speed is great , only thing they are plastic gears..but I think the on-road will be fine with that. The other is some weird company which says they are just like either ko or futaba. Not sure but they are digital , strong and fast like a 9451 but cost 1/4 the price. Im going to order a couple of those.
Old 02-01-2006, 12:38 AM   #9777
AMGRacer's Avatar
"Dear Mr.Imahara
Thank you.
Best regards,
RC Adviser Champ
Hirotaka Suganuma"
Hmmm thats wierd............. Unless the Japanese items have a different part number........... You can try Jet Hobbies, they are the Hong Kong importers for HPI.
Old 02-01-2006, 12:40 AM   #9778
AMGRacer's Avatar
Just checked my instructions. They all say Hara and the numbers are the same as you mentioned. My kit was bought from RC Champ..................
Old 02-01-2006, 10:08 AM   #9779
Rapid Roy's Avatar
Thanks for checking AMG. I guess we are just running into the parts/supply thing with the new kit, although HPI is usually really good about having replacement parts. I do seem to rember severe supply issues with some diff rings or outdrives with the pro3 a few years back. Like AI said, there's always buyHPI if I can't wait.
Old 02-01-2006, 10:21 AM   #9780
Moderator
Possibly check with your lhs and see if they cant order them direct from hpi or something and hopefully can get you at least the regular mark-down from hpis full retail price.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
