Old 01-05-2006, 10:39 PM   #9511
Rapid Roy's Avatar
Oh, and I created a LW upper deck on my 2nd car by tracing the outline on the stock deck and grinding away with my dremel. If any of you end up doing this, make sure you use a resperator. The CF dust is really bad for your lungs. Somebody posted a scan of the LW deck here way back too if you want to search, print and trace.
I plan on running the older cars next year too. I am going to get both up to 2004 specs though (minus the Ti screws). Any of you tried ordering from that fast and furrious hobby shop? There prices are really good.
Rapid Roy is offline   Reply With Quote
Old 01-05-2006, 11:17 PM   #9512
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by Rapid Roy
Hark,
I don't use the .8 2 speed on either of my cars. I do use the LW upper deck on both. It doesn't save too much weight though. What it does do is allow the car to flex just a bit more. I also run only 2 screws in my side brace to create a bit more flex as well. Before any of you start in on me about how a stiffer chassis is always better, this subject was beaten to death waaayyy back. The setup I use right now is similar to the one Hara uses on his R40 and I really like it. It gives me a large sweet spot, so I can keep the car planted easier as the track conditions change durring the day.
Oh no I'm not going rant. That's something I really didnt know. Someone told me they didn't like running the alum side brace because it made the car too stiff. That's why I didnt get mine. How come you don't use the LW 2speed just wondering? Is it maybe that since its soo small that using the shorter gearing options make it too torque? I've kinda seen that here and it requires going a lot easier on the throttle.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-05-2006, 11:47 PM   #9513
Rapid Roy's Avatar
I don't use the LW 2 speed because I'm cheap
With 2 cars plus extra gearing it comes to a pretty large sum. When I bought the 2 cars used, they came with every pinion available almost X2 and enought parts to build 2 more 2 speeds. I haven't ever needed to replace any parts yet cause I don't race enough. Might be able to go to a race this Sunday though.
Old 01-05-2006, 11:50 PM   #9514
HarKonnenD's Avatar
OOooohhhhhhhhh. HAHAHA! Thought it was some sort of preference as I didn't drive with the stock 2speed too long myself. The thing just wouldn't shift for me.
Old 01-06-2006, 04:34 PM   #9515
AMGRacer's Avatar
Originally Posted by Jye
whats the diffrence in the hara and 2005 edition.
As far as I have been able to tell the only difference is the rear body posts are different.
AMGRacer is offline   Reply With Quote
Old 01-06-2006, 04:56 PM   #9516
Jye
2005 kit comes with everything on the hara edition?
Jye is offline   Reply With Quote
Old 01-06-2006, 06:05 PM   #9517
AMGRacer's Avatar
As stated above as far as I can tell. I will have it in my hands Monday.
Old 01-07-2006, 01:11 AM   #9518
HarKonnenD's Avatar
Lightbulb
Anyone using a small battery pack in their R40 instead of those big stick packs? I've robbed the CD3 pro of this (as well of its awesome centax clutch ) and was wondering how will it affect the handling in the R40. I felt it was best if I secured it properly to the direct center of the battery door.
Old 01-07-2006, 02:35 AM   #9519
can anyone tell me that on the 2005 spec the rear arms are different it has 3 holes one for the upstop one for droop and what could the other one be for. It is located directly opposite the droop screw towards the front of the car
Brett.w is offline   Reply With Quote
Old 01-07-2006, 03:13 AM   #9520
AMGRacer's Avatar
That hole is a forward droop screw hole that you can use instead of the rear hole. In fact this is a better one to use since it is easier to access the screw. The rear droop screw is mighty tough to access.
Old 01-07-2006, 03:16 AM   #9521
AMGRacer's Avatar
Short answer is yes. I have been doing that for about 18 months. Make sure you remove the battery case from the chassis and cut the front off it. Cut it where the pin sticks up. Make sure you dont put the battery right to the back of the door or it will hit the bottom of the tank, put it about halfway.
Old 01-07-2006, 03:24 AM   #9522
Thanks for the reply
Old 01-07-2006, 03:35 AM   #9523
AMGRacer's Avatar
Also if it has the two rear swaybar mounting points I would suggest that you use the outside one. The inside one provides only marginal leverage on the actual swaybar itself, I have always felt the outside one is the better.
Old 01-07-2006, 11:49 AM   #9524
HarKonnenD's Avatar
AMG- Sooo...from this pic cut the case like right where the pins are and left the rest on it or something? Sry I don't really understand.
Old 01-07-2006, 12:20 PM   #9525
Rapid Roy's Avatar
Hmm, now you got me thinking. I've got a Serpent 705 with a AAA battery pack. I wonder if it will fit? It is the 4+1 configuration. Kinda like a L shape.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
