Old 01-03-2006, 12:19 AM   #9481
bummy's Avatar
Send a message via MSN to bummy
yes one of the 2 speed shoes was cracked, so i got sum on order. as well as new pinion and clutch bell.
not coming loose as such stripping the thread. like over tightining
bummy is offline   Reply With Quote
Old 01-03-2006, 12:33 AM   #9482
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Does anyone have a manual as to how to install the steering kit upgrade? I purchased some rubber sealed bearings for mine and installed 4 of them. I believe they go in the right spot since they all fit correctly. Though, I've had some centering problems and I know it's not the servo. So far it seems to center a bit better and the idea now is maybe it had to do with some breaking in. Anyone else still running their original R40 or jumping onto the Hara? I plan to stay with my upgraded original.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-03-2006, 06:00 AM   #9483
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
if I remember correctly,one of the berings was a real odd size....did you install the same size bearing in all 4 spots?...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 01-03-2006, 12:13 PM   #9484
HarKonnenD's Avatar
I have two bearings of the same size where the two spacers got in the part 73482, one sitting on top of it, and odd sized one sitting on top of the servo saver. Having the wheels center properly was mainly after turning left. I may need to re-adjust something and get rid of the sub trim. Funny with the subtrim it centers better than no subtrim at all. I'm using a JR Z-1. BTW my turbo head button came in so I'm gonna get it and slap it on the RB V12 Rody.
Old 01-04-2006, 04:56 AM   #9485
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Default new r40
Just recieved my R40 2005 ed. Going to start building the car now.
ProE is offline   Reply With Quote
Old 01-04-2006, 08:49 AM   #9486
HarKonnenD's Avatar
Awesome man. Post pics when you're finished.
Old 01-04-2006, 11:10 AM   #9487
Rapid Roy's Avatar
It sounds like you are getting some binding. Have you tried using a different servo? Try isolating each moving part and check for interference.
Rapid Roy is offline   Reply With Quote
Old 01-04-2006, 11:46 AM   #9488
HarKonnenD's Avatar
Lightbulb
The steering seems fine and does the servo movement. I'll probably just drop in the digital servo from the 8th into the R40 and or get another digi servo for the R40 to save the time. Hitecs can go for sale or something afterwards. The futaba S3003 makes a great throttle/brake servo.
Old 01-04-2006, 12:10 PM   #9489
Rapid Roy's Avatar
I hear you. I really like my Hitec servos. I have 7 of them. They are a really good value, but just don't seem to be as bullet proof as I would like them to be. They have worked fine for me for the last 7 or 8 years (I have had a couple go bad on me) since I only race local club races and I race in the sportsman class. I am in the process of replacing all my servos with Futaba to match my radio gear. The Hitec servos did allow me to get into rc at a time when money was really tight. Now, I have enough money, but much less time to mess with stiff that doesn't always work perfectly.
Old 01-04-2006, 12:54 PM   #9490
HarKonnenD's Avatar
Yeah. Actually when I went to go run today the centering problem seemed to disappear. However I think I may go back to the stock gears as the shorter pinions with turbo has a bit too much punch. A more accurate test would be better with the stock pinions anyway since thats been used more often. Tuning was never an issue today with the turbo plug as it started up nice n easy just like always.
Old 01-05-2006, 12:57 AM   #9491
Rapid Roy's Avatar
I have had the exact same thing happen a few times. The problem seemd to just go away. Oh well
Old 01-05-2006, 04:05 AM   #9492
HarKonnenD's Avatar
Rapid-Are you still using the stock gears on the LW .8 2speed? I tried the 20/26 although there is a 7 tooth difference between the stock pinions and a 6 tooth between spurs. I had the shredded gear but that was due to the screw coming out of the engine shaft. Still though the new gears I had were too punchy and had me sliding all over.I'll try another trial run maybe today if the weather is ok.
Old 01-05-2006, 09:47 AM   #9493
fastrcracer's Avatar
Default R40 Hara Edition parts
Does anyone know where to find the Hara edition parts to upgrade the old R40 to Hara Specs ?
Please advise and thanks.
fastrcracer is offline   Reply With Quote
Old 01-05-2006, 10:02 AM   #9494
Jye
www.towerhobbies.com they have all the option parts
Jye is offline   Reply With Quote
Old 01-05-2006, 10:24 AM   #9495
onnetz's Avatar
I believe you are mistaken....
onnetz is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
