Old 12-30-2005, 04:13 PM   #9466
That won't be the case much longer. I'll be ordering mine when I go back to Orlando for the spring semester. I've been practicing with VRC until then, hope it'll help me when I get to race for real.
B.LaFrance is offline   Reply With Quote
Old 12-30-2005, 04:23 PM   #9467
onnetz's Avatar
I dont think VRC is going to help when it comes to the real thing..
happy racing.....
onnetz is offline   Reply With Quote
Old 12-30-2005, 06:04 PM   #9468
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Were you using the usb adapter so you can use your radio. Ive been wanting to get that so I can at least sort of practice.
I hear its pretty good. Only problem I see from VRC is the local superior race is a parkinglot track. Very tight and theres nothing like that on VRC at least from what Ive seen.
I also hear daytonas track has gotten a lot better off-road and on-road. Im going to hit that area up soon.
Artificial-I is offline   Reply With Quote
Old 12-30-2005, 09:59 PM   #9469
Moderator
Question for those who have gotten your R40 clutchs running well. I have always had trouble with slipping on mine.
I switched the grey mugen pad. That seemed to help some but its still slipping. I hear sometimes people talk about a glazed clutch bell. What do you do to combat that.
Also what other tips do you have to get your clutches to run well. Besides going mugen clutch, which I have bought. But I dont give up that easy and want to get the r40 clutch to run well. Or basically give a full run down on what you did or have on there and how you set it up. Maybe im missing something.
Thanks.
Old 12-30-2005, 10:08 PM   #9470
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
not sure if anyone is interested...
http://www.rctech.net/forum/showthread.php?t=94182
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-31-2005, 12:23 AM   #9471
Yep, I've been using the USB adapter and from my limited experience bashing my old RTR Nitro 3 over a year ago, I think this program does a pretty good job of simulating the dynamics of an RC car. There is even a work around in the new version that lets you play dual player over the internet which is quite fun, too.
Let me know how the Daytona track turns out. Do you know if you can just show up with your car and race, or have to be a member of the club?
happy racing.....
I wasn't expecting it to until I saw this thread over on their forums:
http://www.virtualrc.com/forums/foru...id=5&ftid=2153
Maybe the guy was just some prodigy, but getting TQ the first time out makes a pretty good testimonial.
Even if the handling isn't 100% accurate, all of the setup adjustments effect the car realisticaly, so I can at least learn basic setup techniques. And if nothing else, it'll give me a little more confidence when I finaly do start racing.
Old 12-31-2005, 05:56 AM   #9472
Moderator
Yeah I would say its better than showing up at the track without anything. As well would think it would give some confidence for sure.
Also a little update on my clutch. I checked around a few places and saw two big racers talk about this.
If the clutch is glazed they rough it up. Well I thought hey it does look pretty smooth and shiney. So I took some rough grit sandpaper and made scratches going from the inside to the outside of the circle.
They said they would rough up the bell and the clutch shoe. I went ahead and did that and hopefully will get some good results from it.
Old 12-31-2005, 06:39 AM   #9473
bummy's Avatar
Send a message via MSN to bummy
i just loosen the clutch spring off a bit sure it engages earlier, but it engaes with less force pushing it away from clutch bell. so less chance to slip just tune your engine different, i have a r40 o with nova nsr12 s3 and never had it slip not once. even in a full slide. only strip pinnions hehehe.
hope that helps.
o did that steering tip fix, your problem about tighting up your servo saver?
i will get sum pics up soon. so ya can all have a look see.
bummy is offline   Reply With Quote
Old 12-31-2005, 09:55 AM   #9474
The only problem I have with the clutch is that it likes to eat the flanged bearing that goes on the pinion side of the bell. Have to replace it every month to month & a half. Many engines come from the mfg with a collet & no spacer. The most important thing to remember is the spacer that goes between the engine bearing & the collet. If you don't have this spacer you will always have too much slop & slip in it no matter how many of those adjustment shims you use. Hope this helps some of you at least.
GBagRacing is offline   Reply With Quote
Old 12-31-2005, 11:01 AM   #9475
Moderator
hope that helps.
Im going to tear down the front tonight. So far havent noticed any problems for some reason.
Not sure if I just plain ol swapped the servo already.
Old 12-31-2005, 03:01 PM   #9476
bummy's Avatar
here is my r40, would shouw you underneath but it very dirty so maybe later
Old 01-02-2006, 11:56 PM   #9477
Rapid Roy's Avatar
If you are blowing the flange bearing, your clutch is slipping. That's usually what causes that bearing to fail.
Rapid Roy is offline   Reply With Quote
Old 01-02-2006, 11:59 PM   #9478
bummy's Avatar
it is not the bearing it is stripping the 1st gear on the clutch bell.
Old 01-03-2006, 12:02 AM   #9479
Rapid Roy's Avatar
AI- if your clutch is slipping, make sure that your not tightening the spring too much. If the spring can't compress far enough, the clutch shoe won't press hard enough on the clutch bell. I had to get my end play down to almost nothing to get enough travel remaining on the spring to allow solid engagement.
Old 01-03-2006, 12:07 AM   #9480
Rapid Roy's Avatar
I was replying to Gbag in my post.
Are you still having the trouble with your pinions loostening up? If so, did you check the 2 speed like I had posted back a couple of pages? Did you find any problems there?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
