HPI R40 Nitro Car Forum
#9391
Originally Posted by Turbo Joe
Anyone have any extra LW pinions they want to trade? I seem ot have a few extra 20, 26 and 27T pinions...looking for 21, 28 and 29T.
It's interesting to me that the gears can work like that. It's not so much the major diameter that determines the mesh, it's the contact area...and there's no way to fake that by making the ODs all the same.
I guess it's just a matter of keeping the lash towards the tight side, eh? Sometimes it'll be tight, sometimes it'll be loose...but it must be strong enough to work, right?
#9392
Originally Posted by fastharry
you can run any spur with any pinion....as long as they match up on the gear chart........the gaps don't need to be the same....you can run the lowest 1 st combo with the highest second...
This chart shows them all as meshing for the 1.0.
http://www.hpiracing.com/graphics/in...0/R40-P45o.jpg
The only one I know of that will NOT work are:
22, 23 and 24 1M 2nd gear pinions. They must be used with the 76952 2nd gear spur since the 1M teeth face area could not be "deformed" enough to keep the same OD.
#9394
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
What do you mean by match up on the chart harry? You mean that some pinions wont mesh with some spurs?
I just meant use the chart so some newbie doesnt take a 2nd gear pinion and use it as a first gear pinion...
#9395
#9398
I tried the 625mg servo, the only non futaba servo I tried. For some reason it was really slow and had a rebound on one of the sides. Every now and then it would just kick back in after you went left or right.
Im not sure if its cause I was using futaba rx with it....but I was amazed at how slow it was. My stock s3003 was lightning fast and responsive compared to it.
I think it was just a defect or compatibility issue....but just thought I would give you a heads up. Test the servo outside of the car first.
#9400
never bought from here before but they do have a few r40 (including cf towers and one way) parts and they're all 50% off...
http://www.fastnfuriousrc.com/all_prodmanf.php
#9401
http://www.pro-hobby.net/tech/setup/...etup_sheet.jpg
Here is the Akira R40 Setup sheet from the 2004 edition kit as promised.
Enjoy.
Enjoy.
#9402
just got my upgrades today..
cf towers
cf side brace
lw shafts
hpi lw chassis
solid axle
didnt get the lw 2speed yet but that will be next...
what a difference between the stock chassis and the lw chassis.. its like night and day.
I've thought about doing the aluminum shocks but I've never had a prob with the stock ones so I dont see a need for them other than the bling factor..
I didnt install the solid axle yet because I want to see if I can tell a difference in handling with the lighter parts..
cf towers
cf side brace
lw shafts
hpi lw chassis
solid axle
#9403
The solid axle is lighter than the stock diff, but also makes both rear wheels spin at the same rate whether you're going straight, turning, etc. You notice a big difference in acceleration when using the LW 2speed with LW shafts. The chassis also knocks off 30grams I believe and the shock towers knock off a total of 6 or 8 grams. I'll try to find that conversion for ya. BTW everyone my LW chassis came in! I'm go to purchase it tomorrow and see if the oneway and brace is in as well.
#9404
cf towers
cf side brace
lw shafts
hpi lw chassis
solid axle
cf towers
cf side brace
lw shafts
hpi lw chassis
solid axle
#9405
