Old 11-23-2005, 07:43 PM   #9136
ogreasurada's Avatar
http://www2.towerhobbies.com/cgi-bin...40&FVPROFIL=++
Tower is always a good place for HPI parts too.
ogreasurada is offline   Reply With Quote
Old 11-23-2005, 07:47 PM   #9137
onnetz's Avatar
looking through the list of stuff coming with your r40 I didnt see a rx battery listed..
alot of weight can be saved by getting a lightweight rx battery.. probably more than any other parts..
onnetz is offline   Reply With Quote
Old 11-23-2005, 09:25 PM   #9138
Jye
anyone know a place that sells the real hara edition r40? i see one on rcmart but i wasnt to sure.
Jye is offline   Reply With Quote
Old 11-23-2005, 10:58 PM   #9139
bummy's Avatar
Send a message via MSN to bummy
once you find the problem with the binding steering. let me know my r40 has the same problem. you turn one way and it never centres. real annyoing i think.
bummy is offline   Reply With Quote
Old 11-24-2005, 12:18 AM   #9140
dnitro's Avatar
Remove the steering links. Check the steering blocks if they move freely, also check the center steering mechanism if it moves freely. remove the top plastic cover that shields the front diff/steering plates. If the center steering mechanism does not move freely without the plastic cover, tighten the purple ring that holds down the steering servo saver. Replace the top plastic cover and check again. I've seen this problem in two R40s
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 11-24-2005, 01:48 AM   #9141
Rapid Roy's Avatar
also make sure that the wires arn't getting too close. It's really easy for them to get in the way if you route them the way the manual shows
Rapid Roy is offline   Reply With Quote
Old 11-24-2005, 03:12 AM   #9142
The kit is still on order pending on most online stores. Just be patient.
Old 11-24-2005, 07:51 AM   #9143
Greenbox's Avatar
Most of the time its binding on the hub carriers and pivot balls. IT MUST be able to rock back and forth without any intervention. Remove the steering links and just hold the car forward and the hubs should turn in...then lean the car back and the hubs should turn out. I did this and used a bit of CA on the threads to prevent it from rattling loose. If the hubs stay stiff or move sluggish adjust it to get the proper free movement.
Greenbox is offline   Reply With Quote
Old 11-24-2005, 10:22 AM   #9144
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Dubbed_Monk-Hey man I noticed you live in brooklyn. Do you go to Floyd Bennett? The site is www.frracers.com . You should go there to race the R40. I run mine there also. I'd also like to add to the list the LW 2speed. Combined with the LW shafts they totally make a difference in the car. Despite the fact the gear ratio is a lot taller, the components are much lighter so it allows the engine to spool up quicker.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 11-26-2005, 11:07 AM   #9145
HarKonnenD's Avatar
Can anyone recommend a setup board good for the price? I like the Hudy one as it holds the car up and you can make the adjustments, but it may break the wallet. I'd also like for a radio with spektrum or something like that. If anyone can list some great ones with prices that'd be great...thanks!
Old 11-26-2005, 11:50 AM   #9146
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I have the newly released integy setup station 2 pro.
http://cgi.ebay.com/Integy-Team-Alig...QQcmdZViewItem
Its fair priced , high quality , comes with board that features a level , setup wheels and it all comes in a nice case. Also has some good base instructions on how to setup your car.
Not only do I suggest that , but I suggest buying from them. Thats my local hobby shop, where I bought mine. They are also one of the few people that has it in stock. Also at a great price.
Artificial-I is offline   Reply With Quote
Old 11-26-2005, 12:05 PM   #9147
HarKonnenD's Avatar
Is there a picture how it's setup? Looks good. I'll ask my lhs to rder it. Paypal isnt safe so I have no one to order it since my sister doesn't want to use it. I may need a universal one for my 8th onroad too.
Old 11-26-2005, 12:50 PM   #9148
Moderator
Ill put mine on the setup station and will take some pictures. I believe it works slightly different than the hudy.
You can also get the integy tweak station to round out the package. Basically matching the hudy setups.
Old 11-26-2005, 02:26 PM   #9149
HarKonnenD's Avatar
Ok kewl. I'll be waitin for the pics.
Old 11-26-2005, 05:04 PM   #9150
onnetz's Avatar
anyone purchase from precisionrc.com before?
they have quite a bit of stuff for the r40 at good prices..
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
