Old 10-23-2005, 02:24 PM   #8971
Hesky's Avatar
Originally Posted by HarKonnenD
I tried a soldering iron and or a heatgun but it seems he ruined the screws. I guess I'll have to try the chisel technique. So basically take a chisel and tap the washer that the screw is sitting in to pop it off? It seems that he used threadlock pretty good as only ONE screw was able to come out.
oh no, that may end up damaging the chassis if you shear the head of the screw off with the chisel. you basically unscrew the bolt by tapping a chisel at an angle in the right direction at the edge of the screw head to unscrew it. its actually not as hard as you think. I guess it could be tricky if you havent got a small enough chisel.
Like ai says if you have a very small wheel cutter bit for a dremel you could cut into the face of the screw head so it can accept a flat head driver. but you may end up leavin a few nice cutting marks on the chassis.
I just hope your m8 didnt use the extra strong red thread lock!
Hesky is offline   Reply With Quote
Old 10-23-2005, 04:56 PM   #8972
Hello
I am just wondering if anybody uses front shock spring on the rear when using the new rear suspention mounts? as if i use the small graphite parts that attach to the arm it seems to make the rear shocks very hard due to the compression, which also make adjusting the droop inacurate, or have i done something wrong?
Brett.w is offline   Reply With Quote
Old 10-23-2005, 06:18 PM   #8973
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by Brett.w
Hello
hey brett....I'm running the std blk springs in there designated places.....2 mm up travel at a 5mm ride height.....my springs are as soft as pie when I push down the car....
how great are genesis chapters one through three?......
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 10-23-2005, 06:28 PM   #8974
Hesky's Avatar
harry what does the biblical account of creation have to do with the r40's rear suspension? I shouldnt have asked
Old 10-23-2005, 06:46 PM   #8975
fastharry™'s Avatar
your question...
bretts sig..
But that Satan was the actual tempter, and that he used the SERPENT merely as his instrument
my attempt at casual conversation....[QUOTE]
Old 10-23-2005, 06:54 PM   #8976
Hesky's Avatar
very good
Old 10-23-2005, 07:08 PM   #8977
fastharry™'s Avatar
hey hesky...where are you,anyhow?>..
Old 10-23-2005, 07:14 PM   #8978
Hesky's Avatar
sunny blighty, (worcestershire in the uk)
Old 10-23-2005, 07:18 PM   #8979
fastharry™'s Avatar
shouldn't you be asleep by now...dreaming sweet dreams of HPI's fifth scale buggy?...
Old 10-23-2005, 07:36 PM   #8980
Hesky's Avatar
ah, na its only just gone 2am here lol and its my week off so much rc bashing to be done!! r40's been put away until the winter series starts up, cant wait for that!
later I will probably be dreaming about finally achieving a double back flip with my revo, that or a situation involving mischa barton off the oc and baby oil
Old 10-23-2005, 07:55 PM   #8981
fastharry™'s Avatar
that possibly could be a little more info than we needed...
Old 10-23-2005, 08:55 PM   #8982
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
It's actually some greyish stuff. It's not blue and it's not Red, but it sure as hell is strong. The whole threaded part of the SG crank is still covered in the rest of the dried up stuff of it.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 10-24-2005, 12:22 AM   #8983
Mr Harry Your knowledge amazes me i was looking for a sig for serpent and googled it and this is what i came up with! i do have to change it, now i drive a r40!
Old 10-24-2005, 01:17 AM   #8984
HarKonnenD's Avatar
I slotted them suckers and yep now I can loosen n tighten em. Think I may try a one way diff for the car to see how it is. Not too sure bout the solid rear axle as yet.
Old 10-24-2005, 05:31 AM   #8985
fastharry™'s Avatar
what made you switch to an r40?....
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
