Old 09-22-2005, 05:17 PM   #8866
Rapid Roy's Avatar
Originally Posted by Hesky
really, I best learn japanese pronto then
thanks roy
The only thing the kit doesn't include are the TI screws. Still, you end up saving a lot of money.
Rapid Roy is offline   Reply With Quote
Old 09-22-2005, 05:25 PM   #8867
Hesky's Avatar
ah, I though the price I've seen was to good to be true lol. I skimmed through the list of what you get and read R40 titanium screw set (#A368) and thought damn thats 60+ dollars already.
just checked again properly this time after your post and now it reads "* R40 titanium screw set (#A368) it is not included in conversion set." doh
but yeah like you say, you still save alot
Hesky is offline   Reply With Quote
Old 09-22-2005, 07:36 PM   #8868
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by bummy
so get sum setup sheets from hpi?
and change the front what? shock tower?
yes in the manual it said .5-.8mm but it still doesnt seem t change?
get the front and rear shock towers......follow the build procedure in the book...set the car up in a "standard mode".......5.5 mm rear height,5 mm front...3 degrees toe rear,1 degree toe out front.....2 degrees camber front,3 rear........put the 4 gear conversion in the back diff if you have a good traction track..if not,just use the grease that came with the kit...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-23-2005, 07:50 AM   #8869
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Yeah, the only reason you would want the cf shock towers is so you can use the setup sheet everyone else uses or posts, well that and they are lighter weight. I havent seen a standard one yet. It also gives you more shock stroke in the rear by including an extra piece to attach to the lower arm.
Reason why it should be pretty much #1 on everyones list. So you can use the good setups.
Artificial-I is offline   Reply With Quote
Old 09-23-2005, 04:05 PM   #8870
bummy's Avatar
Send a message via MSN to bummy
ok no worries i will get them shock towers soon. cheers.
bummy is offline   Reply With Quote
Old 09-24-2005, 12:38 PM   #8871
evostyle's Avatar
Trader Rating: 102 (98%+)
Default RCModel in Hong Kong.......
I received a HPI R40 2004 kit from RCModel that had the factory seal cut opened. As soon as I saw that I new there would be problems. Unfortunely, I was right. NO Super chassis! and so far a plastic parts tree missing. I am really pissed I thought I would let you guys know just in case anyone else plans on ordering from these guys. You should demand in the remarks of your order that the kit be factory sealed just as it should be!!!!
I'll keep you updated as to weather they fix the problem.
Here is my letter to RCMODEL:
Order #RC-108322
I just received my package from the post office. It is in good shape and unopened. However, my HPI R40 2004 kit factory seal had been cut open. And now I am missing parts! This is no joke. I am missing the CHASSIS and so far plastic parts tree HPI 73479 This is completely unacceptable!!!!!! Why in the world would you send me a opened kit. I am extremely dissappointed with your store. I expect a chassis (HPI 73924 light weight super chassis) and HPI 73479 to be delived overnight / 2day as soon as you read this. I will continue to build the kit and will update you if I have any more missing parts.
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 09-24-2005, 03:11 PM   #8872
Hesky's Avatar
hum thats pretty unlucky dude, I've know of shops opening boxes to get a certain part that they dont currently have in stock and then replace it at a later date. perhaps this is most likely the case, I mean it would be a bit silly to think the purchaser wouldnt miss the most costly component in the kit! right??
I've delt with rcmodel b4, with no problems but I must admit they have communication issues, quite a few emails relating to my present orders went un answered.
Old 09-24-2005, 07:32 PM   #8873
bummy's Avatar
i to have dealt with radio models and never had a problem, i thought it was great.
Old 09-24-2005, 08:39 PM   #8874
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
One of the reason why I refuse to order overseas and such other places. I buy my cars in the LHS so I can to look in the box.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-25-2005, 12:37 AM   #8875
evostyle's Avatar
Default missing parts
I just received email from RCModel / Terence Lam. He said that the supplier sent him the kit with the seal broken and he forgot to check it before it left the store. He said he would get the replacement parts right out. I'm glad it's getting taken care off without any problems.
Old 09-25-2005, 12:38 AM   #8876
bummy's Avatar
my hpi under steers at high speed? and i still cant get it into second gear.
the smaller gear does not free spin? i did the adjustment of 5 turns out on springs.
but it looks like the larger gear purple housing is rubbing on the inside or the other housing were the 2 speed clutch runs so it doesnt spin free.
sorry if my explaniation is hard to under stand.
Old 09-25-2005, 02:02 AM   #8877
Suspended
Send a message via MSN to rinkeberg
would all you guys race 235mm class if it had all that 200mm has now?
rinkeberg is offline   Reply With Quote
Old 09-25-2005, 03:55 AM   #8878
Tighten the 2-speed screws until it's flush so the second spur rotates freely. try that.
Light003 is offline   Reply With Quote
Old 09-25-2005, 11:40 AM   #8879
HarKonnenD's Avatar
If they had more brands of 235mm classes now and it got popular again, sure I'd give it a run. Otherwise, I have my 8th onroad to run right now.
Old 09-25-2005, 10:43 PM   #8880
BatJam1's Avatar
Whats the difference with the 2004 Edition than the other editions .Also some one told me that the R40 is a very heavy car is thaT TRUE
BatJam1 is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
